Page 60 of 82 FirstFirst ... 105056575859606162636470 ... LastLast
Results 591 to 600 of 815
Thread: Solution for external Flicker fixer?
  1. #591
    Wears pants, sometimes... Inactive Member
    Amibayer!
    thgill's Avatar
    Nov 2008
    Cincinnati, OH
    Age
    44
    28 (97%)
    I see a pal/ntsc switch on that unit. I wonder if it can pass 50hz through it to the display?
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
  2. #592
    Inactive Member sweetlilmre's Avatar
    Jan 2013
    South Africa
    KwaZulu / Natal
    35 (100%)
    Quote Originally Posted by thgill View Post
    Yes it can, which makes for smooth scrolling on my PAL A500.
    Another nice feature is that the SCART audio channels are sampled and muxed into the HDMI stream.
    That's the good news so far. I couldn't wait for my super-SCART cable from Oge so I wired up a quick and dirty one with no cleanup hacks.
    The results have been somewhat mixed... Colours seem a bit off (power on screen looks blue-ish instead of white). The HxC disk list looks a bit fuzzy.
    I've attached some somewhat crappy phone pics for an idea.
    If I get time I will try to clean up the signal a bit and see if I can get better results.
    Attached Thumbnails Attached Thumbnails image001.jpg   image002.jpg   image003.jpg   image004.jpg   image005.jpg
  3. #593
    Inactive Member
    Amibayer!
    velourfog's Avatar
    May 2012
    Sweden
    RAM:
    40 (100%)
    Looks pretty nice to me, but maybe hard to tell from cell phone pictures.
  4. #594
    djos's Avatar
    Jun 2012
    Melbourne
    12 (100%)
    Looks ok so far, any vertical banding at all or ghosting around the cursor in workbench?
    :rainbow: 500 w/ KS1.3/3.1, 1Mb Chip-Ram, CF-IDE w/4MB Fast-Ram, FDD Selector, HxC RevC Floppy emulator :rainbow: Amiga 600 w/ KS1.3/3.1, 2Mb Chip-Ram, 1GB CF-HDD :rainbow: 1200 w/ KS3.1, ACA1220 26Mhz 128MB w/ RTC, 4GB CF-HDD, Roland MT-32 MIDI Synthesiser :Commodore: 64 w/ 1541 Ultimate-II + Tape Adapter, JiffyDOS, 1541 Disk Drive, 1531 Datasette, Flyer Net Modem
  5. #595
    Jan 2013
    South Africa
    KwaZulu / Natal
    35 (100%)
    Quote Originally Posted by djos View Post
    Sorry forgot to add that info in. There doesn't appear to be any cursor banding or ghosting.
    Do you have a set of tests you'd like me to try out while I am waiting for a decent cable?
    -(e)
  6. #596
    djos's Avatar
    Jun 2012
    Melbourne
    12 (100%)
    Excellent, I imagine the Colours will improve once you have a good quality scart cable connected.
    I'm gonna grab one of these now myself, native 50hz output is a major feature I want!
    If you look back at my posts there is a drive speed test that used high res interlaced mode that failed on the VGA converter.
  7. #597
    djos's Avatar
    Jun 2012
    Melbourne
    12 (100%)
    Ok I went back thru my posts and found it, RSCP (RawSpeed Controller Performance Test - from AmiNet) - the screen just becomes an unstable mess on the AV-1M so hopefully the SCART-HDMI converter can handle it properly?
    ---------- Post added at 08:38 ---------- Previous post was at 08:34 ----------
    Quote Originally Posted by sweetlilmre View Post
    On the AV1M and the GBS-8220 the lowercase "m" on the HxC screens looks fairly ordinary, in your pics it looks like it is much better defined.
    One thing you do need to do tho is set the output to a 4:3 mode or make sure your TV doesn't stretch the pic from 4:3 to 16:9 as that will skew the results - all Amiga Output is in the 4:3 aspect ratio.
  8. #598
    Amibayer!
    thgill's Avatar
    Nov 2008
    Cincinnati, OH
    Age
    44
    28 (97%)
    Definitely test High res laced output.
    That seems to be an achilles heel of a lot of these kind of devices.
  9. #599
    Jan 2013
    South Africa
    KwaZulu / Natal
    35 (100%)
    Wouldn't that be > 15Khz i.e. require pass-through?
    I'll see if I can give this a test this week some time.
    -(e)
  10. #600
    Amibayer! ajk's Avatar
    May 2010
    Finland
    Helsinki
    223 (100%)
    Hi-res laced is still a normal 15kHz video signal, as is super hi-res. Only the Productivity etc. modes use another frequency.
  1. Sold External flicker fixer/Scan Doubler
    By the-topdog in forum Sales Archive
    Last Post: 17th October 2010, 02:32
  2. Closed Scandoubler Flicker Fixer *external*
    By Drummerboy in forum Found Archive
    Last Post: 28th January 2010, 03:40
  3. Closed WTB External Scandoubler/Flicker Fixer: Scandex, ToastScan..
    By xenon in forum Found Archive
    Last Post: 15th September 2009, 13:09
  4. Closed Wanted: External Flicker Fixer / Scan Doubler
    By systmcrsh in forum Found Archive
    Last Post: 18th October 2008, 20:03
Tags for this Thread
