Found A590 Power Supply
flashjazzcat
Rating - 0%
0   0   0
Tyne and Wear
Hi - just obtained an A590 hard disk with no PSU. Could probably fab one up, but I'd be interested in a cheap original if anyone has one on offer. :)
Does it? Mine was the A500 fitting on the a590 I'm sure (ish)
It's a simple job to change to plug if the voltages / amps are the same.
If you search on here in AmiOracle, I did post the pinouts for the A590, so that you could use an A500 power supply, as that is what powers mine.
Cut the square plug off, wire a 4-pin DIN up and Robert is your Uncle.
Edit: Found the pinouts - my thread was over at EAB. You need a four pin DIN plug and it wires up as follows...
Pin 1 - Red (+5v)
Pin 2 - Black (0v)
Pin 3 - NC
Pin 4 - Brown (+12v)
White (-12v) - not connected - cut this off and tape the cable over, to prevent a short.
I hope that this helps.
attachment.php
