Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 45
Thread: Getting to grips with a Rock Lobster.
  1. #11
    Mega AmiMod
    Staff Moderator
    keropi's Avatar
    Dec 2007
    Ioannina
    Age
    40
    156 (100%)
    Default Re: Getting to grips with a Rock Lobster.
    nice job r0jaws !!!! Another amiga rescued!
    Aacheron and slk486 are my heroes
    A1200D mfilos ed. : ACA 1231/42 , Indivision MK2 , IDEfix Express , Subway , PicoPSU 120w custom 3.9 ROM/OS
  2. #12
    Positively negative VIP
    Amibayer!
    Justin's Avatar
    Sep 2008
    Cheltenham UK
    Cheltenham
    142 (100%)
    fantastic m8, really impressed, well done
    Official Amiga Walker
    join us on Facebook
    https://www.facebook.com/groups/170601321614/
  3. #13
    Mondeo Man VIP
    Amibayer!
    r0jaws's Avatar
    Jan 2008
    Boston, Lincolnshire
    Age
    45
    160 (100%)
    The Rock Lobster goes from strength to strength.
    Received an AlfaData Alfa Power Expansion from Rudi. For those who don't know what it is, it provides upto 8Mb Fast RAM and access to IDE ports.
    What makes it a bit special is that it has both a 40 AND 44 pin IDE connector with internal power supply available. This means that it can have an IDE hard drive and CD ROM hooked up simultaneously.
    It can also be powered entirely by the 500, but also has a power brick for hungry hard discs, or for when you have a CDROM attached.
    I have fitted this with a 4Gb CF Card with WB 2.05 installed, and it does not require the power brick as well, leaving you with a less cluttered desktop.
    It also has switches on the front enable you to switch the RAM or Hard Disc on and off as you wish.
    The only problem I have, is that I miss identified my ROMs as 2.05, I only have a 2.04 ROM! Unfortunately, that doesn't have the patch enabling it to boot from IDE. Bah!
    However, once I get these installed, and maybe even get hold of some patched 1.3 ROMs, I'm sure she will be good to go.
  4. #14
    Ya' Like it Retr0? Inactive Member
    Zetr0's Avatar
    Nov 2007
    Age
    45
    137 (100%)
    ROMS you say
    Looking great r0jaws!!!!
    8)Flux Mastah' Zee8)
    50 L337 1'M W1R3FR4M3
  5. #15
    Amiga fanboy VIP
    Amibayer!
    rkauer's Avatar
    Dec 2007
    Age
    53
    110 (100%)
    Not a problem if the A500+ have just 2.04 ROM, Phil.
    The device will boot straight away with the 2.xx ROM, but not with 1.3 without some little hack or with a slightly modified 1.3 ROM.
    Just to remember the old times, all you need to do is setting a 1.3 partition using the tool from the A2091 install and then save changes to the RDB. This will make the first partition bootable (don't forget to put a copy of the AlfaData SCSI/IDE device into the EXPANSION drawer!). After that, all partitions you want to be available to the 1.3 ROM must be mount-listed. Pretty much the same for 2.1, IIRC. But 2.xx just need the wanted at-boot partitions saved to the RDB.
    Have a lot of fun with this piece of retr0-licious hardware history.
    16 Amigas at home :D
    3x C= 64 :smile:
    1 VIC-20 :smile:
  6. #16
    BANNED Kin Hell's Avatar
    Nov 2007
    U.K.
    Cornwall
    Age
    57
    48 (100%)
    Nice one r0jaws.
  7. #17
    AmiNerd VIP
    Amibayer!
    chiark's Avatar
    Jan 2008
    Yorkshire
    85 (100%)
    I think an A500 or 500+ with KS1.3 will boot the alfapower without any problems at all... Apologies if I'm missing your point here rkauer
    I don't think you need the stuff in the expansion drawer either, as the driver is loaded at boot from the autoboot roms...
    (I know we're not talking about gayle emulation devices which would need 2.05 or a 1.3 with scsi.device embedded here )
    1k + Xebec + Spirit Insider | GBA1k | 3k | 4k | 500 + Spirit HDA-506 | 500 CSA030 +i68k | CDTV | 1200 ACA1230/56
    www.binarydevotion.com
  8. #18
    Amiga fanboy VIP
    Amibayer!
    rkauer's Avatar
    Dec 2007
    Age
    53
    110 (100%)
    You remember the old-school days? At least the RDB must have the (auto boot and necessary at boot time) partitions and file systems saved into for proper operation.
    Other partitions and devices can be invoked by mount list.
    But as I remember, the device driver must be tossed inside the expansion drawer even for those who have the ROM in memory (or was it from kick 1.2 time?). My memory fails on this...
    3x C= 64 :smile:
    1 VIC-20 :smile:
  9. #19
    AmiNerd VIP
    Amibayer!
    chiark's Avatar
    Jan 2008
    Yorkshire
    85 (100%)
    I do remember the old days . I stil live 'em . This is my experience/memory: I could be wrong...
    A lot of controllers from the old days didn't support RDB so had to have a single partition with particular geometry or used a non-standard RDB-style approach which only mounted 1 partition. The Spirit HDA-506 is like this.
    If the controller supports RDB, I believe it should mount everything under 1.3. I think. Certainly the SupraDrive mounts 3 partitions under 1.3 without an apparent mountlist... I'll give this another check to see what exactly is happening
    The device driver is needed in the Expansion drawer is for 1.2 boot disks for hard drives, or for other devices which don't have enough space to load their drivers (such as bridgeboards, which do need the right driver in expansion).
    I could be horribly wrong!
  10. #20
    Acceleration! Amibay Treasurer
    Amibayer!
    AmiDev
    Administrator
    AndyLandy's Avatar
    Aug 2009
    Southampton
    Age
    38
    107 (100%)
    If you need a Kickstart 2.05 ROM, I can send you a 37.300 for the cost of postage. Alternatively, you have enough FastRAM that you could put Kickstart 3.1 in there and install Workbench 3.5/3.9
    Actually, I might even have a spare 2MB ChipRAM expansion for the A500+ lying around somewhere if you are interested.
    Thinking about accelerating your A1200? Check out my buyer's guide.
    Projects past and present: Amiga 2000/030 | Amiga 3000/040 | Amiga 4000/060
  1. WTB: Chuck Rock
    By orange in forum Amiga
    Last Post: 12th July 2009, 01:15
