Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Conductive Material for Keyboard Membrane Repair
  1. #1
    Retro Girl Staff Moderator SkydivinGirl's Avatar
    Dec 2008
    Raleigh, NC
    Age
    44
    185 (100%)
    Default Conductive Material for Keyboard Membrane Repair
    Hey everyone,
    I'm trying to find a conductive material to repair an SX-64 keyboard membrane. For those of you who have not seen an SX-64 keyboard membrane, it's basically a large rubber membrane that connects to the control board via a row of contacts on both the rubber membrane and the board itself.
    The problem I'm having is that the row of connectors is not getting a good connection. If I put pressure on that row then the keyboard works perfectly. I've already tried cleaning all the contacts but the problem persists. If there is some sort of material that I could use to re-coat the contacts on the membrane then I think the problem would be solved. Is there anything like that available?
    Thanks guys!
    Heather
    Promoted to Level II Solder Tech and Hackery Padawan
  2. #2
    Amibayer! Bryce's Avatar
    Aug 2012
    Germany
    Nordrhein Westfalen
    68 (100%)
    You could try using conductive silver paint. This is great for repairing keyboard foils and would probably be fine for fixing the contacts too.
    Bryce.
  3. #3
    Keeper of the Valiant Turtles. Amibayer! thecellartroll's Avatar
    Aug 2011
    Scotland
    Edinburgh
    36 (100%)
    I haven't tried this but I think it would work...
    http://www.ebay.co.uk/itm/Electrical...item4d04064755
    Commodore VIC20 & SD2IEC, 64x5 & Chameleon, 64Cx4, C128, Plus4 & SIDcard C16, C16@64K, Sinclair Spectrum+ 128K & divIDE2k11 +2 +3 ZX81 &ZonX, Amstrad CPC 464x2 6128x2 6128+, Acorn RiscPC 600 (StrongARM + 586), Electronx3, +1, +3, BBC Master128 + MMC & Valiant Turtle, C64 DTV, Atari 800XL.
  4. #4
    Amibayer!
    SpeedGeek's Avatar
    Jan 2011
    Wisconsin
    Age
    54
    21 (100%)
    @Heather
    The conductive silver paint is good for repairing PCBs but will likely wear down to quickly for a keyboard application. So the conductive rubber is a better (or longer lasting choice). Digi-Key sells this but you can usually find better price on other-bay.
    Kevin
  5. #5
    Aug 2012
    Germany
    Nordrhein Westfalen
    68 (100%)
    I understood that tha problem is with the connector tags (ie: the edge connector on the foil) and not the actual buttons themselves. If it's the buttons, then yes, conductive rubber is definitely a better choice, but for the connector tags, which will only be re-connected once, silver paint should be fine.
    Bryce.
  6. #6
    Positively negative VIP
    Amibayer!
    Justin's Avatar
    Sep 2008
    Cheltenham UK
    Cheltenham
    139 (100%)
    i have used car heat screen heater element repair stuff before with great success (silver conductive paint)
    Official Amiga Walker
  7. #7
    Dec 2008
    Raleigh, NC
    Age
    44
    185 (100%)
    Bryce is correct, I'm looking to repair the conductors for attaching the membrane to the board so it won't be moving. I may opt for the conductive rubber. Any chance someone could send me a link to it on Digi-Key? I searched but couldn't find it.
    If I can't find something suitable then I might try the conductive paint.
    Thanks guys!
    Heather
  8. #8
    "Takai desu ne." -"Jinsei da." VIP
    Amibayer!
    protek's Avatar
    Feb 2008
    Finland
    Oulu, Pohjois-Pohjanmaa
    Age
    44
    62 (100%)
    Graphite from pencil would do the trick. I fixed a broken trace of a Spectrum membrane ribbon with a pencil.
    AMIGA 4000 060/50, AMIGA 1200 030/50, AMIGA 500, C128D, C128, C64C, C64, C16, Vic-20, Atari 520 STE, Atari 65 XE, Philips NMS-8250 MSX2, Sinclair Spectrum +3e, Sinclair Spectrum 48k, Amstrad CPC 6128, Apple Macintosh Classic, Apple IIGS, BBC Master, Memotech MTX500
  9. #9
    Dec 2008
    Raleigh, NC
    Age
    44
    185 (100%)
    Might have to try that for a quick fix.
    Thanks!
    Heather
  10. #10
    Amibayer!
    SpeedGeek's Avatar
    Jan 2011
    Wisconsin
    Age
    54
    21 (100%)
    @Heather
    Thanks for clarifying that. In that case, the conductive silver is a better choice for an edge connector because it has lower electrical resistance than conductive rubber. Digi-Key no longer stocked the conductive silver the last time I checked but a search on other-bay should turn something up at a reasonably good price.
    Kevin
  1. Closed Wanted: Amiga 600 keyboard membrane (Blue) or full keyboard assembly
    By RetromanIE in forum Found Archive
    Last Post: 22nd August 2012, 07:48
  2. Closed Key for the Blue Keyboard Membrane
    By keitha in forum Found Archive
    Last Post: 29th July 2012, 19:36
  3. Keyboard Membrane repair
    By scrappysphinx in forum AmiOracle
    Last Post: 16th July 2012, 23:35
  4. Closed QL Keyboard Membrane
    By tokyoracer in forum Found Archive
    Last Post: 26th April 2011, 17:54
  5. Closed A500 keyboard or membrane
    By karletto66 in forum Found Archive
    Last Post: 27th February 2011, 01:15
Tags for this Thread
