Results 1 to 10 of 10
Thread: A3000 front LED Board
  1. #1
    Goatlizard SpodSpod's Avatar
    May 2011
    Oxfordshire
    24 (100%)
    Default A3000 front LED Board
    Hi all
    I'm after an LED board for my A3000. The tracks on my existing one were knackered, I tried to repair it by using short wires between the pins on the LEDs and where they needed to go on the board itself, and although it worked briefly I accidentally broke the LEDs off when trying to do a better fix
    So please, if anyone has an LED board for an A3000, then please let me know!
    :ninja: New Amiga games! ::[B]Moebius Goatlizard[/B]::[B]Carpet Capers [/B][SIZE=1](wip)[/SIZE]:::ninja:
    Download from [U]blackjet.co.uk[/U]
  2. #2
    Amibayer! tlosm's Avatar
    Jul 2012
    Italy
    Bari
    Age
    45
    83 (100%)
    Blog Entries
    1
    Quote Originally Posted by SpodSpod View Post
    Hi all
    I fix mine using the +5v leds hi power , you have to use only the left part of the circuit it is the part for the hd, the right isnt necessary is the power led . and need only Red and the middle black for work (if i remember good) the hhd led need the middle black and the left black for work.
    You just need to put the original led on the case of the a 3000 & fix that with transparent clue strong (here we have attac).
    ciao
    luigi
    Check all my things in sell on Amibay :thumbsup:
  3. #3
    May 2011
    Oxfordshire
    24 (100%)
    That's interesting advice, thanks. I can use hot glue I suppose to stick them in place. BUT I need some LEDs as I broke them, I guess they're the same size as those found on an A500? Will that work as a drop in replacement?
  4. #4
    Jul 2012
    Italy
    Bari
    Age
    45
    83 (100%)
    Blog Entries
    1
    No the amiga 500 Leds are bigger exactly the double size, the a4000 are the half.
  5. #5
    Amiga fanboy VIP
    Amibayer!
    rkauer's Avatar
    Dec 2007
    Age
    54
    110 (100%)
    A3000 use ordinary rectangular LED.
    A couple placed correctly over a perfo-board cut in the correct size is a perfect replacement and invisible after case closed.
    16 Amigas at home :D
    3x C= 64 :smile:
    1 VIC-20 :smile:
  6. #6
    Jul 2012
    Italy
    Bari
    Age
    45
    83 (100%)
    Blog Entries
    1
    Default new led ...
    yes, i did it the same and have better led quality
  7. #7
    May 2011
    Oxfordshire
    24 (100%)
    Sounds like an easy thing to then. I'll try your suggestions, thanks all
  8. #8
    Jul 2012
    Italy
    Bari
    Age
    45
    83 (100%)
    Blog Entries
    1
    make only attention when you soldering dont make cable or part of it touch the metal of the case or you will make an elettroshock to the machine.
  9. #9
    May 2011
    Oxfordshire
    24 (100%)
    Sounds like you're talking from experience!
  10. #10
    Jul 2012
    Italy
    Bari
    Age
    45
    83 (100%)
    Blog Entries
    1
    No bed experience like this but the circuit is very close to the case and can do this if you are not really accurate, is better prevent this
  1. Wanted Front bezel A3000
    By Zorro in forum Amiga
    Last Post: 17th April 2017, 19:16
  2. Closed A3000D front chassis plastic and/or LED board
    By 8bitbubsy in forum Found Archive
    Last Post: 15th September 2011, 15:20
  3. Closed A3000 plastic front Brand NEW
    By Amiga-Digital in forum Sales Archive
    Last Post: 24th May 2011, 23:52
  4. Found A3000 front panel & floppy cover
    By strim in forum Found Archive
    Last Post: 15th April 2011, 11:07
  5. Closed A3000 front
    By cv643d in forum Found Archive
    Last Post: 20th October 2010, 15:17
Tags for this Thread
