REDUCED to 55 Euros + P&P
Selling my iBook G4.
It is a 12" Model with PPC G4 1.2Ghz CPU, 512MB RAM and 30GB HD.
OS X Leopard 10.5.8 installed.
The Good
Excellent battery with lots of life left in it.
Case & screen in very good condition.
Boots up and runs perfectly.
DVD Superdrive works perfectly.
All ports USB etc.. work fine.
The Bad
The backlight of the screen does not always work. When it does work it works great. I think it might be a loose cable as if the screen is tilted a lot down it works every time.
The Airport extreme only works if it is positioned next to the router. The problem is due to the antenna being disconnected. I can't connect it because the plug of the antenna is not the same as the airport extreme. I think at some point the screen was changed (including the antenna) to that of the 1.33Ghz model which has bluetooth & wifi antennas with different plugs. Works fine with a USB wireless dongle.
Sale includes the laptop, box and power supply (not original).
I'm looking for 55 Euros + P&P
The Good
The Bad
