I have a nice sata 120gb hard drive in my Amiga (using a sata to pata adapter works great). I have setup the first partition for Workbench of 2gb and have installed SFS on the RDB (all partitions will use SFS). I would like to use the rest of the drive to make some big partitions (bigger the better as I want the least amount of partitions using the most space possible).
What do I need to do so that applications such as Opus, HDToolbox and even Workbench windows display the correct available drive space? I'm reading I have to use a patched scsi.device file but is that all that needs to be done? The way i'm reading you simply take a patched scsi.device and copy it to devs but that sounds too simple to be all that is needed?
So can someone point me in the correct direction for stable big partitions and the correct reporting of drive space please?
