Page 54 of 56 FirstFirst ... 44450515253545556 LastLast
Results 531 to 540 of 557
Thread: GBA1000 rev4 Build Log
  1. #531
    Amibayer! ajk's Avatar
    May 2010
    Finland
    Helsinki
    192 (100%)
    @protek
    It's hard to say, I did it over several days a little bit at a time. A lot of it has to do with the hassle of dealing with so many different components and keeping everything sorted out. I'd say that if you have a good space to work in, all the components nicely organized (so you don't have to search for things) and so on, one weekend is enough to complete a board.
  2. #532
    icepick94's Avatar
    Feb 2012
    USA
    Los Angeles, Ca
    45
    0
    I have bought a blank PCB rev 4. I broke out my microscope and soldering rig. Let's see if I can still solder and build stuff! With that being said, I have some questions that I hope someone can answer.
    1. Is there anyone left that can either program all my chips or sell me programmed chips? Is there a link to the files that need to be programmed and is there a preferred programmer?
    2. I am thinking of running a 3.1 ROM. Will that work or should I stick the 2.04 ROM?
    3. Do I need to run a A1000 PS or will an ATX one work? I have read that you can convert an ATX PS but what I want is opinion. Is it a good idea and will it work?
    I am sure that I will have more questions. Thanks to everyone for putting this thread together.
  3. #533
    May 2010
    Finland
    Helsinki
    192 (100%)
    The GALs can be programmed with all manner of inexpensive programmers so they should not be a problem. Similarly there are lots of Lattice ISP programmers (or clones of them) available on eBay, although I can't recommend any one in particular as I didn't program the ispLSI1024 myself (didn't have a suitable adapter and couldn't be bothered to make one ) I'm sure there are also people in the US who have built these and already have the programmers.
    3.1 works fine, that's what I'm running in mine.
    I elected to use an A1000 PSU since it's the best fit for the A1000 case. But pretty much any PSU can work, there is a jumper on the board for the Tick signal which is only present in the original PSU.
  4. #534
    icepick94's Avatar
    Feb 2012
    USA
    Los Angeles, Ca
    45
    0
    I bought most of my parts from the Mouser parts list the one of you fine gentlemen posted. I have a question about one of the parts. I ordered qty 100 of 623-2512067007Y3. This part is coming up as a 70 ohm 3A FB 1206 package. It looks like this was ordered for the 150 ohm FB that goes in multiple locations. Will this part work or should I order an actual 150ohm FB?
    https://www.mouser.com/ProductDetail...WgDrI9bthl5Q==
    The project also listed qty 6 of 810-ACH32C-100-T. Where do these go? I cannot locate them on any build sheet. Mistake in the project lsit on mouser??
    Thanks!
  5. #535
    piacc64's Avatar
    Mar 2011
    Italy
    Piacenza
    120 (100%)
    i found this in my old order to Mouser, 875-HI1206T500R-10
  6. #536
    icepick94's Avatar
    Feb 2012
    USA
    Los Angeles, Ca
    45
    0
    Does anyone have part numbers for R26, C59, C80, and Q1?
    R26 - 1K Trimmer Pot 4 pole
    C59 - 1-5 pF Trimmer 3 pole
    C80 - 5-40 pF Trimmer 3 pole
    Q1 - 32Khz Oscillator for the RTC. 2 pole.
    Thanks!
  7. #537
    icepick94's Avatar
    Feb 2012
    USA
    Los Angeles, Ca
    45
    0
    I am almost ready to fire this beast up. I just finished soldering the 16 ram chips onto the board. Its looking sexy!!
    I have figured out how to program my GAL chips. The issue now is the lattice. I can make the adapter but my MiniPro programming software does not have a template for this chip. Anyone have a recommendation of what software or what template to use for programming the lattice chip?
    Anyone?
  8. #538
    icepick94's Avatar
    Feb 2012
    USA
    Los Angeles, Ca
    45
    0
ID:	134007Getting there!! Getting close to firing it up!
  9. #539
    bootsie's Avatar
    Jul 2011
    Northants
    11 (100%)
    Nice. Did you manage to get the ispLSI1024 programmed?
    Amiga 1000, GBA 1000, BBC Micro, ZX80 - see my blog at http://bootsiescomputers.com
  10. #540
    Trotzki's Avatar
    Jan 2017
    Deutschland
    NRW
    45
    2 (100%)
    Hi Icepick, where did you get the missing parts ?
    I am also searching for the sockel PGA128
  1. GBA1000 Build Project
    By hese in forum Photo Booth
    Last Post: 6th August 2013, 17:05
  2. Wanted GBA1000
    By Astral in forum Amiga
    Last Post: 21st January 2013, 16:13
  3. Sold GBA1000
    By lopos2000 in forum Sales Archive
    Last Post: 7th November 2011, 13:09
  4. Closed Gba1000 pcb
    By Astral in forum Found Archive
    Last Post: 18th September 2010, 07:30
