Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: A2091ToFast: Even more A2091/A590 speedup possible!
  1. #1
    Amibayer!
    SpeedGeek's Avatar
    Jan 2011
    Wisconsin
    Age
    57
    22 (100%)
    Lightbulb A2091ToFast: Even more A2091/A590 speedup possible!
    A2091ToFast V2.5
    Original code by Chris Weber 1998 (Aminet). Updated and enhanced by SpeedGeek 2015.
    INTRODUCTION:
    A2091ToFast copies the A2091/A590 ROM code into Fast memory similar to the CPU FastROM command but does not require an MMU. This allows it to work with many other CPUs which don't have an MMU or free the MMU to perform other tasks. More importantly, it can speed up the execution of the SCSI driver code by SEVERAL HUNDRED percent!
    Note: Zorro2 Fast memory and Zorro2 ROMs operate at the same bus speed so there is no benefit to using A2091ToFast on a "Bog Standard" 7 MHz 68000. However, unlike the Zorro2 ROMs the Zorro2 Fast memory can be cached so the L2 cache on some 68000 accelerators (or the L1 cache on 68020+ accelerators) may still realize some benefit.
    I've uploaded RSCP images showing PIO speed on my system is now a little faster than original DMA speed (and much faster than ROM based PIO speed). Enjoy!
    P.S. If I were AndyLandy I would not be surprised it's possible to squeeze a few more drops of performance from our trusty old C= SCSI controllers!
    P.P.S. Another thread will posted on EAB to satisfy non-Amibay member download issues.
    Attached Thumbnails Attached Thumbnails A2091TOFAST_PIO.PNG   A2091ROM_PIO.PNG
    Attached Files Attached Files
  2. #2
    decrunching Inactive Member
    Amibayer!
    Paul_s's Avatar
    May 2010
    Lancashire
    Age
    42
    120 (100%)
    Thumbs up
    Excellent mod.... you should change your name to Dave Haynie
  3. #3
    Extr3m3ly l33t Amibayer!
    Staff Moderator
    mfilos's Avatar
    Mar 2008
    Glyfada/Athens
    Age
    41
    72 (100%)
    Cheers SpeedGeek. Ima try it and report back
    Visit my Amiga Blog: http://www.mfilos.com
    - A600: Vampire V2, 128MB, A604n, 16GB CF, Indivision ECS, RapidRoad USB, Ratte's auto RTG/ECS switch, Gotek w/HxC-LCD + Slim floppy (internal)
  4. #4
    Inactive Member Patrikax's Avatar
    Jan 2013
    Sweden
    Umeć
    11 (100%)
    Haven't checked what the code actually does, but the os does not execute driver code on zorro2 cards from their rom.
    The content is copied into system memory at boot and ends up in whatever fully autoconfig memory that has the highest priority, which should be your fastest ram unless you have a quirky mem-expansion. Just check under devices in say sysinfo to see what's the case.
    If you have a quirky expansion the driver could end up I'm chipmem though.
  5. #5
    Acceleration! Treasurer
    Amibayer!
    Site Developer
    Administrator
    AndyLandy's Avatar
    Aug 2009
    Southampton
    Age
    38
    107 (100%)
    Quote Originally Posted by SpeedGeek View Post
    With guys like you around, the sky really is the limit! It wouldn't surprise me if one of these days you'll have an Amiga running a 500MHz 68k CPU core and a custom Zorro bus that runs at 1:1 with it!
    Awesome stuff on the mods there. It never ceases to amaze me what folks (you in particular) seem to be capable of making our old hardware do!
    Thinking about accelerating your A1200? Check out my buyer's guide.
    Projects past and present: Amiga 2000/030 | Amiga 3000/040 | Amiga 4000/060
  6. #6
    Amibayer!
    SpeedGeek's Avatar
    Jan 2011
    Wisconsin
    Age
    57
    22 (100%)
    @Paul_s
    I might be able to pull that off in U.K. but here in U.S.A. I could easily get sued for defamation of character, slander, theft of intellectual property, etc.!
    @mfilos
    I didn't even know you had an A2091/A590 my friend! But I'm happy to see your full report: mfilos = Beta tester par excellence!
    @Patrikax
    Sorry, most expansion ROM drivers don't get copied into any memory (the Guru ROM being a notable exception here). What does get copied in memory is the ConfigDev info for the device and a jump table for any libraries or task structures used by that particular driver.
    @Thread
    Here is some interesting info from the Amiga RKRM:
    "The A2091, A590 and A3000 drivers always do programmed I/O for data transfers under 256 bytes or when the DMA chip doesn't support the required alignment."
  7. #7
    Jan 2013
    Sweden
    Umeć
    11 (100%)
    Are you sure about them not being copied to system ram in the general case?
    It's very long time since I messed with that stuff, but I remember that there were provision even for supplying the driver rom as 4-bit wide rom (indicated somehow via autoconfig) and the 68000 could not run code directly from such a rom.
    So got the impression that in the general case stuff was copied. Of course you should be able to do solution where you point to the rom instead in a small init code (if it is presented as 16-bit on the bus), letting the CPU execute directly from it and save a little bit of memory.
  8. #8
    Inactive Member banana's Avatar
    Sep 2011
    Switzerland
    Binningen-Basel
    Age
    55
    0
    Thank you
    I'll give it a try next weekend.
    :rainbow:Amiga + C64 :rainbow:
  9. #9
    Amibayer!
    SpeedGeek's Avatar
    Jan 2011
    Wisconsin
    Age
    57
    22 (100%)
    Quote Originally Posted by Patrikax View Post
    Yes, I'm quite sure. In post #1 I've uploaded an RSCP image for ROM based PIO on the same system. It takes several minutes to run the test and the results speak for themselves!
    Also, it appears as though you have confused Auto-Config ROM with expansion driver ROM.
  10. #10
    Jan 2013
    Sweden
    Umeć
    11 (100%)
    Not saying that the A2091 doesn't run the code directly from the rom - it is after all a card with double eproms (odd/even) design which would be a quite unecessary if the rom data is just copied to ram.
    However, the general case - zorro2 cards usually only have one 8-bit rom with very slow access time (200ns). Even with the logic to deliver it 16-bit at a time to the cpu to allow execution to even take place, it would result in slow execution times of the driver code even on a plain 68000 and should be a well known performance problem of cards with cpu-intensive code, say PIO-only cards.
    I found the rkrm libraries part I remembered about the copying (DiagArea):
    http://gega.homelinux.net/AmigaDevDo....html#32-3-3-1
  1. Closed A590 / a2091 rom 7.0
    By oldman1000 in forum Sales Archive
    Last Post: 19th January 2014, 10:48
  2. Closed 2mb for A590/A2091
    Last Post: 23rd October 2013, 16:06
  3. Sold A590 / a2091 rom 7.0
    By Berry in forum Sales Archive
    Last Post: 5th May 2013, 08:49
  4. Closed A590/A2091 DMAC and Ram controller - ICs for A590/A2091
    By posylus in forum Found Archive
    Last Post: 8th October 2012, 08:25
  5. A590/A2091 rom
    By bobsmith2012 in forum AmiOracle
    Last Post: 6th October 2011, 13:56
Tags for this Thread
