Results 1 to 3 of 3
Thread: Leaving feedback for your transactions.
  1. #1
    Acceleration! Treasurer
    Amibayer!
    Site Developer
    Administrator
    AndyLandy's Avatar
    Aug 2009
    Southampton
    Age
    38
    107 (100%)
    Default Leaving feedback for your transactions.
    Here's a simple step-by-step guide to leaving feedback for your transactions on Amibay.
    To leave feedback for a member, look at their avatar at the left of any message from them:
    AndyLandy
    Above Average
    AmiDev
    Administrator
    Feedback: 15 reviews, 100%
    Click on the number of feedback reviews (15 in this case) then click:
    Submit Feedback For XXX and fill in the form.
    Hit 'Submit' and you're all done!
    Thinking about accelerating your A1200? Check out my buyer's guide.
    Projects past and present: Amiga 2000/030 | Amiga 3000/040 | Amiga 4000/060
  2. #2
    Amiga fanboy Inactive Member
    Amibayer!
    rkauer's Avatar
    Dec 2007
    Age
    54
    110 (100%)
    But first you need to copy the thread address (from the navigator/browser bar), then proceed to Andy's guidance.
    16 Amigas at home :D
    3x C= 64 :smile:
    1 VIC-20 :smile:
  3. #3
    Lead Moderator
    Administrator
    keropi's Avatar
    Dec 2007
    Ioannina
    Age
    41
    159 (100%)
    Detailed feedback instructions:
    1. Click in the Feedback rating , under a user's name
    2. This will take you to the following screen, now you need to click the "Add FeedBack for ......" link
    3. You will be in the next screen, where you will actually leave your feedback.
    a. Select from the first drop-down menu your role in the transaction (buyer OR seller OR trade).
    b. Select from the second drop-down menu your rating on the transaction (positive OR neutral OR negative) , this has direct impact on the person you are rating as it can raise , leave the same or lower their feedback rating.
    c. Leave a small comment in this field, this will be viewed by all in the member's feedback page. (look at the "Rating Summary" list in the bottom in the previous picture)
    d. Fill the "Deal thread URL" field. This is just the url of the trade thread you are rating. Only closed ads can be rated.
    For example the address for this thread is: http://www.amibay.com/showthread.php?t=5133 , so just copy it to the field.
    e. This large field is used to leave detailed feedback for a transaction. It can hold information that can only be seen by the seller, buyer and the Amibay staff. Usefull for adding private information in cases of bad trades or just to extend your thoughts of how awesome your experience was on Amibay
    That's it! an easy process that helps the Amibay community and shows your appreciation
    Aacheron and slk486 are my heroes
    A1200D mfilos ed. : ACA 1231/42 , Indivision MK2 , IDEfix Express , Subway , PicoPSU 120w custom 3.9 ROM/OS
  1. FeedBack
    By Zetr0 in forum AmigaKit.com
    Last Post: 15th October 2010, 21:25
Tags for this Thread
