Page 1 of 10 12345 ... LastLast
Results 1 to 10 of 97
Thread: Amstrad / ZX Spectrum +3 Floppy Drive Hack.
  1. #1
    VIP Chinners's Avatar
    Oct 2009
    North Yorkshire
    189 (100%)
    Default Amstrad / ZX Spectrum +3 Floppy Drive Hack.
    Well, I recently acquired an empty floppy case from Clueless - probably a bit of a strange request you may think? Well, here's why.
    1st. Take one standard PC HD Floppy. Here's a black facia one I got from evilbay for a few quid.
Name:	101 - Floppy.jpg
    Now, I need to make sure it only operates in Low Density mode. This is easily achieved by shorting out the High Density Floppy sensor. This means that even if a High Density disk is inserted, the drive thinks it is low density, so no need to tape over the hole any more.
Name:	104 - Floppy Override.jpg
    Now. The drive's ready signal needs to be "always on" for the Amstrad and Spectrum to recognise. A solder bridge from ground to pin 33 sorts this out. Plus, due to the physical hardware of the CPC drive, I need to be able to manually select which head of the 3.5" drive to use (The CPC / +3 floppy drives were single sided - the disks were flipped to change side). if Pin 32 is grounded, Side B is selected, otherwise Side A.
    Also and the ability to select "primary" or "secondary" floppy will be a nice thing to have. Grounding pin 12 makes the drive secondary, leaving it open makes it primary. Leaving it open has the added benefit of seemingly overriding the internal drive. This is totally optional, but as the drive is only ever going to be used for Low Density floppy disks, I thought this would be a good idea.
Name:	105 - Floppy Solder.jpg
    Next - power. Neither the +3 or CPC had a power out for external floppy drives, so I need to power this somehow. I had an old phone charger, which had a mini usb connector on the end, and guess what - its 5v, ideal for the drive unit.
Name:	202 - Mobile Phone charger.jpg
    The wire from the charger connected to one of these will make the IDEAL floppy power source.
Name:	201 - Power.jpg
    Getting data signals to and from the drive would be useful. Fortunately, the "Drive B" port on the back of both the Spectrum and CPC 6128 is identical to an old style 5.25 floppy connector, so you need an old skool PC floppy cable with both 5.25" and 3.5" connectors on it:
Name:	301 Oldskool Floppy Connector.jpg
    And after a bit of butchering, the cable looks like so, - perfect for connecting the drive.
Name:	302  butcher it.jpg
    Right. Fun time! Out with the Dremel and drill - its time to attack the unit Clueless kindly supplied. Lets have a game of Spot the Difference.
    Before:
    After:
    I have added 2 5mm holes to stick the rocker switches I have bought through, and "widened" the old floppy connector jack hole, so the new ribbon cable can fit without being folded.
  2. #2
    Oct 2009
    North Yorkshire
    189 (100%)
    Continued.
    Right, I need to block some holes, and narrow the ribbon cable hole slightly, just to make it look a bit more professional. Araldite and bits of metal cut from floppy disk shutters will sort this out:
    (please note - the wife was annoyed I used her best kitchen scissors for cutting metal, so if you do this, don't tell the owner of the scissors!)
    Now, lets go overboard with a glue gun to make sure things dont move:
    And finally, time to put the case unit back on.
    Hmmm. That will not do. Look at the colour of that. Its supposed to be attached to a Black Spectrum, or a Dark Grey CPC. Time to dig out a can of "Retr0Dark"... (ok, Ford Mercury Grey spray paint will do!)
    And, once it's stuck all back together.
    Front:
    Ahh, that colour is much better.
    Back:
    Does it work? Well, on my floppy driveless CPC:
    The Floppy drive side select works. This floppy has Jack The Nipper on Side a, and Renegade on side b
Name:	402 Floppy drive select works.jpg
    And yes, games load in. Neat!
Name:	403 Game loading.jpg
    I now have one fully working, self powered 3.5" floppy drive for my CPC6128, that can be drive A or B with the flip of a switch, and can select sides at the flip of another switch. I built something similar over a year ago when I had my Spectrum +3, and yes, it worked perfectly on that!
  3. #3
    BANNED Kin Hell's Avatar
    Nov 2007
    U.K.
    Cornwall
    Age
    57
    48 (100%)
    Awesome work.
    How about editing the title of this brilliant work to suggest PC to Amstrad/Spectrum Floppy Hack or similar.
    Best wishes,
  4. #4
    Amibayer! clueless's Avatar
    Oct 2009
    West Yorkshire
    48 (100%)
    Thats turned out really well. Some nice modding indeed, good to see what you were up to.
  5. #5
    6級 [Rokkyū] VIP
    Amibayer!
    J.T.Kirk's Avatar
    Aug 2008
    Hellas
    Chania, Crete
    211 (100%)
    Congrats! Really nice modda.
    You are standing at the end of a road before a small brick building. Around
    you is a forest. A small stream flows out of the building and down a gully.
    > GO EAST
  6. #6
    Oct 2009
    North Yorkshire
    189 (100%)
    Quote Originally Posted by Kin Hell View Post
    Awesome work.
    Best wishes,
    I did try, but I can see how...
    (ok, I looked slightly harder and found it.!)
  7. #7
    Ya' Like it Retr0? Inactive Member
    Zetr0's Avatar
    Nov 2007
    Age
    45
    137 (100%)
    @Jasey
    NICE!!!!!!
    8)Flux Mastah' Zee8)
    50 L337 1'M W1R3FR4M3
  8. #8
    (Not actually from Tokyo). VIP
    Amibayer!
    tokyoracer's Avatar
    Jun 2008
    Age
    30
    172 (100%)
    If you ever consider selling one of these (or making them for peeps) please let me know!
  9. #9
    Nov 2007
    U.K.
    Cornwall
    Age
    57
    48 (100%)
    It looks like one of the Mods is going to have to change the main title as it still lists as a "Floppy Drive Hack". This appears to be something to do with the Pre-title selection options.
  10. #10
    Elite ranking Inactive Member
    Amibayer!
    meega's Avatar
    Nov 2007
    2
    5 (100%)
    It's an awesome mod.
    Flying Spaghetti Monster wrote: noodle noodle noodle
    I am not a democracy.
  1. Closed A1010 floppy drive controllers - for towering floppy drives
    By Astral in forum Sales Archive
    Last Post: 18th June 2013, 13:40
  2. Closed Amstrad 6128 Case, maybe floppy drive too.
    By Chinners in forum Found Archive
    Last Post: 30th March 2010, 16:42
  3. Found External Floppy Drive
    By Chris S in forum Found Archive
    Last Post: 17th February 2010, 20:14
  4. floppy drive hack - confused
    By jvdbossc in forum AmiOracle
    Last Post: 8th January 2010, 14:59
Tags for this Thread
