Closed 68060 adapter for 68040 socket
fiat1100d
Italy
Modena (MO)
Hi! I am looking for an adapter which lets you to put a 68060 CPU into boards which are provisioned for 68040 only, e.g. for putting a 68060 on a WarpEngine.
I saw elsewhere that there are shematics/PCB layouts around but would like to buy a finished product.
Expense
Expense
I was looking recently at such a device. They are often more expensive than a new accelerator board! Probably due to scarcity, I think a homebrew job is the way to go!
I wonder if this is a project for Kipper2k? I'd buy one in a heart beat if they were for sale!
I would, too! Better if with "embedded" code for 68060 compatibility, so that it could be a drop-in replacement for almost any 68040 board. Otherwise I read that some other Flash memory board must be used for the Amiha to execute the required instructions (something related with caches management).
Seems like this is a dead end for a quick plug and play solution unless they sell you a rom solution to make it bootable...
I would try to modify the WarpEngine ROM, since I have the ROM from an Apollo 4060 and I know some instructions need to be executed at boot to change CPU/FPU status or something like that.
Found this (still opened) thread, can be closed for me since I bought an anapter here on Amibay some times ago.
