The main hard drive (MASTER) works fine.
The 1GB CF/IDE on slave gets found OK on HDINSTTools and I can partition it and format OK without problems.
Then I switch off the A2000, take out the CF and load it in WinUAE, and it is seen exactly how I did it on the A2000 with names, partitions and all fine.
I copy stuff to it and put it back in the Amiga.
Load up WB3.1 (using a bootdisk as Tandem is non autoboot)
I cannot see the CF drive on the workbench unless i go back in hdinsttools which sees the drive and the partitions but i have to reformat them again using same hdinsttools for it to be seen on the desktop and be usable on the A2000 again. Of course i lose all the stuff i copied to the partitions which defies the whole point.
I dont know what im doing wrong.
