Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: Guide to setting up Internet access via MiamiDX on A1200 with Netgear MA401
  1. #1
    Online Gangster Amibayer! fitzsteve's Avatar
    Aug 2009
    Sevenoaks, Kent
    Age
    40
    1014 (100%)
    Blog Entries
    2
    Default Guide to setting up Internet access via MiamiDX on A1200 with Netgear MA401
    I posted this guide over at EAB and at the request of Zetr0 I am also posting here
    Enjoy!
    Guide to setting up Network/Internet connection on A1200/A600*
    This guide is the basic steps that I followed to setup Internet access on my A1200 with the following hardware, if you have different hardware the some of the steps may also differ. This guide only covers the automatic detection of settings; there will be a further guide for setting up manually should you encounter a problem.
    This guide also assumes you have basic knowledge of navigating your way around the Workbench and have the facility to transfer files to your Amiga.
    Hardware used in this guide:
    A1200 with 3.1 Rom and 68030 Accelerator + 64mb Ram
    Netgear MA401 16bit PCMCIA WiFi Network Card
    Note also tested on *A600 with 3.1 Rom and Apollo 630 + 32mb Ram running CWB ADV* (You will need at least an 020 on your A600 for this guide)
    Software required:
    Classic Workbench ADV SP, CWB Full & CWB ADV
    MiamiDX – Included with CWB however requires installation.
    The Prism2 driver is also available from Aminet.
    Download links:
    http://classicwb.abime.net/index.htm
    http://aminet.net/driver/net/prism2.lha
    Optional File's (Recommended for A1200)
    http://aminet.net/util/boot/CardPatch.lha
    http://aminet.net/util/boot/CardReset.lha
    Getting started:
    Assuming you have installed Classic Workbench, the first thing we need to do is install MiamiDX and the Prism2 drivers.
    Power on the Amiga and follow the steps below:
    • From the main workbench screen double click on the transparent ‘Drawers’ Icon that is at the bottom of the Workbench screen, this will bring up a menu with a selection of options.
    • Click on ‘My Files’ and browse to the ‘Install’ Folder
    • You should see an Drawer for MiamiDX 10 browse to this drawer and run the installer.
    • Follow the on screen instructions and complete the install to your chosen location.
    • Assuming you've downloaded the Prism2 archive and transferred it to your Amiga we need to install this now.
    • Locate the archive ‘Prism2.lha’ and extract the contents to a temporary location.
    • Navigate to the Prism2 folder and run the installer, following the instructions on screen.
    • We now need to modify the startup-sequence and enter the SSID and network Key that will be used to connect to the access point.
    • Locate your startup-sequence file, this will be in SYS:S/ *I suggest making a backup of this file in case anything goes wrong*
    • Open the file and locate the following line: “run >NIL: C:CardReset TICKS 50”
    • Leave a space below this line and then enter on a new line the following:
    C:SetPrism2Defaults SSID xxxxx KEY xxxxxxxxxx
    • SSID is the name of your Network, mine is BeBox KEY is the 10 digit network key that you use to connect, I did not enter any dashes or spaces in the key. **Some people have reported problems with Alphanumeric keys, so you may need to change your key to Numeric only however my key is Alphanumeric**
    • Your network security must be WEP, WPA is not support by the Prism2 driver.
    • Now save the file and power down your Amiga
    In the next section we will setup MiamiDX with its built in Wizard. Insert your Network Card into the PCMCIA slot and Power on you Amiga. Follow the below steps:
    • Locate the directory you installed MiamiDX to and run ‘MiamiInit’ this is the setup Wizard.
    • Read the welcome message and press continue.
    • Choose 'Ethernet, Cable/ADSL modem' from the options below and press continue.
    • Choose ‘Other’ and press continue
    • Enter prism2.device and the ‘Device’ field and press continue
    • At this point MiamiDX should find your IP Address/Subnet Mask, press continue
    ***If MiamiDX did not find your settings its possible you entered your Network ID or Key wrong, you may wish to check these and try again.****
    • Assuming it found your IP Address press Return
    • Assuming it found your Subnet Mask press Return
    • MiamiDX should now find your default Gateway, press Return
    • It will now verify with the DNS server, my provider did not appear to support DNS recovery, I just hit ‘Skip’
    • Give your connection a name and press Return
    • Enter your name and a username and press continue, if you don’t want to print your settings i.e if you don’t have a printer uncheck the print box or else like my first try MiamiDX will probably crash now…
    • Your settings should now be saved and the program should close
    Now that the default settings have been detected we can run MiamiDX and get online.
    • If you need to, navigate to the directory where you installed MiamiDX and run ‘MiamiDX’ from the Icon.
    • Press ok and now right click, from the project bar choose settings and ‘Import settings from MiamiInit’
    • Press OK.
    • You should see a message that the settings have been imported.
    • Press ‘Online’
    • You should see a message telling you that you are online.
    Now you can test your connection out by running a Web Browser, AWeb is pre installed on CWB ADV SP, right click and choose Run>Programs>AWeb. Type in a web address and see how you get on!
    Remember before exiting Miami to save the settings as default so you don't have to import from Miamiinit each time.
    Good Luck, hopefully you can now enjoy Web browsing on your Amiga.
  2. #2
    Repairer Extraordinaire Amibayer!
    AmiDev
    Administrator
    TheCorfiot's Avatar
    Mar 2008
    Wales
    Age
    52
    227 (100%)
    Steve
    Excellent Tutorial my friend...
    Guess who's earned a Sticky
    TC
    Ritchie Blackmore's Rainbow June 2016, I Was There
  3. #3
    Aug 2009
    Sevenoaks, Kent
    Age
    40
    1014 (100%)
    Blog Entries
    2
    Quote Originally Posted by TheCorfiot View Post
    Steve
    TC
    Thought I would give something back to this fine community
    Steve.
  4. #4
    Ya' Like it Retr0? VIP Zetr0's Avatar
    Nov 2007
    Age
    45
    137 (100%)
    @Steve
    Fantastic Stuff!!!
    A huge thanks for posting!!!
    8)Flux Mastah' Zee8)
    50 L337 1'M W1R3FR4M3
  5. #5
    The 1 That Ribbits VIP
    Amibayer!
    cosmicfrog's Avatar
    Aug 2008
    Leek, Staffordshire Moorlands
    Age
    52
    80 (99%)
    Blog Entries
    1
    plagiarism
    don`t look now but some one called Fitzsteve over at EAB has written something very similar
  6. #6
    Aug 2009
    Sevenoaks, Kent
    Age
    40
    1014 (100%)
    Blog Entries
    2
    Quote Originally Posted by cosmicfrog View Post
    plagiarism
    Just sharing the Love Froggy
  7. #7
    BANNED
    Amibayer!
    Witcher1979's Avatar
    May 2010
    Westleton, Suffolk, UK
    Suffolk
    Age
    40
    153 (100%)
    Worked first time on my 3.1 install
    Thanks Steve
  8. #8
    Amibayer! maniades's Avatar
    Jan 2010
    Spain
    Madrid
    2 (100%)
    Just as a curiosity, it can be made work in a bare A1200, without turbocard (I did it xD) although, you end up with around 50kb free memory. A solution (in case you want, somereason to conect wirelessly in a bare 1200), is to use amitcp with some hacking so it can make use of prism2... If someone is really interested, I can dig to see how I did it in its time xD I think I even have a picture around xD.
  9. #9
    Nov 2007
    Age
    45
    137 (100%)
    that would indeed be very interesting indeed!
    AmiTCP is also compatible with the A600 =D
    I would be interested to see how you redirected (piped) its default coded serial modem input to use the PCMCIA NIC =)
  10. #10
    we live as we dream. Alone. VIP
    Amibayer!
    mjnurney's Avatar
    Aug 2010
    england
    Milton Keynes
    Age
    48
    182 (100%)
    Excellent work Steve , I'll be going thru your guide this weekend if my netgear 401
    Stand by for tantrums and hissy fits!!
  1. Replies: 10
    Last Post: 7th June 2011, 11:43
  2. Closed Netgear WG311T WiFi 108MBPS PCI
    By J.T.Kirk in forum Sales Archive
    Last Post: 8th May 2010, 16:27
  3. Replies: 14
    Last Post: 25th March 2010, 03:56
  4. Closed swap:i got a netgear wg511 v2 for a usb wifi card
    By jimbob005 in forum Sales Archive
    Last Post: 6th February 2009, 21:06
Tags for this Thread
