It would be nice for you to release the board files and let those of us that are waiting and can make them have a chance to do it. This design has been around since 1992 more or less. Any thought on this?
I would like to order 2 Kickstart Switchers for the Amiga 1000 PAL system. Is there any soldering required? Will it work with an Amiga 1000 which has a RAM-expansion mounted in the CPU socket? Thanks for all replies!
Seller hasn't had a shipment go out in about 11 months off the second batch. We can speculate as to why, with my guess being RL events taking priority in life.
if You need a quick solution - i can help You out with relocator/dual kickstart switcher from here: https://www.amibay.com/showthread.php?94167-Amiga-A500-A1000-A2000-CPU-relocators
these fits nicely in both: PAL and NTSC A1k and also working perfectly,
However, if You need an automatic switcher - i recommend to be patient
regards,
Thanks for your interest. I back on Amibay since some days.
The offer is not dead. Ihave to answer to a lot of PM and to update the first post of the thread with the new interests.
I have received the new pcb of the switchers and I'm going to work onto.
Your guess is the good one!
Everything is back now in order, so I have again time for the switchers & also my Megachip project.
I have begun again to ship Megachip (assembled& kit).
I have some switchers already assembled. I have to test them before to offer them here.
I have assembled and tested my last design of the automatic Kickstart swither and it's working perfectly.
And as always, Automatic means no uggly hole onto the Amiga case. Switching with the keyboard.
This week-end, I'll read all posts of the thread to contact interested members.
Some are ready for shipment.
Pictures here of the A1000 running Silkworm with the Automatic KS Switcher. Onto the second picture, you can see the switcher connected to the A1000 thanks to my devel pcb I use to test the switchers.
