Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: C64 Case Clip repair
  1. #1
    Inactive Member balford's Avatar
    Feb 2014
    Ireland
    Dublin
    9 (100%)
    Default C64 Case Clip repair
    So I picked up a nice early C64 breadbin earlier this week. Unfortunately, while functionally perfect, the case clips at the back were all broken, so the case was flapping about by the front screws.
    That's no good, I thought, and went looking for a solution.
    A quick Google returned a potential solution in a product called Polymorph
    Plyable in hot water, it sets when cool to the consistency of nylon plastic. I picked some up on the way home and got to work!
    First the granules are mixed in hot water:
    Once mixed, the Polymorph can be removed and moulded to the desired shape. I put the two case halves together (minus the motherboard and keyboard for ease of access. A top tip here is to smear the areas of the case to be molded lightly with Vaseline, as we don't want the Polymorph to stick just yet. Here's one clip part way through molding.
    Give things about 20 minutes to cool off in place, the Polymorph will have turned completely white. It's important to not remove them too soon as doing so risks distortion in the finished clip if they haven't completely cured.
    Then, thanks to the Vaseline, we can simply pop them out. Make sure you keep track of which clip goes where as each clip will be moulded perfectly to its case counterpart:
    Trim them to size:
    Clean both them and the case to remove all traces of the aforementioned vaseline, then glue them in place with liberal amounts of superglue and allow to set:
    Here's a close up view of one of the clips, as you can see it's a very good fit!
    And finally a shot of the completed patient
    Hope this helps people!
    B
  2. #2
    Underwelmist! Inactive Member
    Amibayer!
    Macc's Avatar
    Apr 2012
    Staffordshire
    Age
    46
    34 (100%)
    Good work B!!!
  3. #3
    Inactive Member sputnik's Avatar
    May 2011
    Barnsley, Yorkshire
    18 (100%)
    Looks good. I am hoping to do something similar on my Amiga(s)!
  4. #4
    Perpetually Perplexed Inactive Member
    Amibayer!
    BluesBrothers's Avatar
    Oct 2013
    Greater Manchester
    Age
    45
    123 (100%)
    Very cool B, a really excellent job. Where would you obtain some of this Polymorph? Is it the sort of tackle you can buy readily?
    BB
  5. #5
    Feb 2014
    Ireland
    Dublin
    9 (100%)
    Cheers all I picked this up at my local Maplins, €11 for a 150g packet which I reckon would do about 10 C64's.
    B
  6. #6
    Video Game Merchandise Collector Inactive Member
    Amibayer!
    NinjaRabbit's Avatar
    May 2013
    South Gloucestershire
    21 (100%)
    Blog Entries
    42
    Brilliant repair work, this.
    Polymorph is one of the brand names under which "Friendly Plastic" (as I believe it's known in North America) is sold, correct? I heard of the stuff a while ago, whilst reading some handicrafting-related articles, and saw a mention that the low melting point can pose an issue when it's used in warm environments. I don't imagine that a C64 would run warm enough to melt clips made from Polymorph, but I'd be very interested in how it holds up over time, and on hot days, etcetera.
    "No need to design a new game - just change the graphics in these few basic designs and put a picture of Indiana Jones on the box! You'll never have to think again!"
    --Jeff Minter, Llamatron Readme
  7. #7
    Amibayer!
    Oct 2013
    Greater Manchester
    Age
    45
    123 (100%)
    Quote Originally Posted by balford View Post
    B
    I know what I'll be doing with my weekend
  8. #8
    Confused retro man Amibayer!
    Staff Moderator
    scrappysphinx's Avatar
    Jan 2008
    Nottingham
    Age
    35
    495 (100%)
    100g for about 3.15 posted via ebay (buy it now)
    http://www.ebay.co.uk/itm/100g-Polym...item43c7ee3294
  9. #9
    Amibayer!
    Oct 2013
    Greater Manchester
    Age
    45
    123 (100%)
    Quote Originally Posted by scrappysphinx View Post
    Damn it that means I have to be patient and wait for it through the post
    Ah, top man, cheers. I probably should have been less of a lazy sod and looked myself
  10. #10
    Feb 2014
    Ireland
    Dublin
    9 (100%)
    Yes, but postage would have been more to Ireland, plus I'm an impatient bugger, and it would have meant you good folks wouldn't have had this thread till this time next week
    B
  1. Wanted Clip-on Heatsink & fan
    By bitcpy in forum Amiga
    Last Post: 2nd September 2013, 02:03
  2. Wanted A600 keyboard Clip
    By hsc in forum Amiga
    Last Post: 6th August 2013, 20:49
  3. Case front bezel repair
    By ajk in forum Photo Booth
    Last Post: 18th December 2010, 21:08
  4. A4K case repair
    By Justin in forum Photo Booth
    Last Post: 2nd March 2010, 21:34
Tags for this Thread
