Closed 4 x c64 motherboard, working, without SID
Mohican
Hungary
Budapest
I have for sale four C64 motherboards.
Test will come ...
Price is
- 15€->12€ /each
- 24€->22€ for 2 pieces
- 40€ for all 4 pieces
I can add Nano SwinSID for the boards; + 10€ / each
+ Postage + Paypal Fees or Bank transfer
Declare interest in one C64 motherboard.
Depending how much is the shipping costs to Portugal?
Declare interest in one C64 motherboard 250469 REV B.
Depending how much is the shipping costs to Italy?
Declare interest for the two ones remaining, please quote shipping cost to Mexico.
If someone backs out, please let me know which ones you have available, to choose 2 of them.
Thanks!
Shipping cost for 1 piece:
- to EU, 14€, registered, priority, up to 1kg.
- outside EU, 16€, registered, priority, up to 1kg.
Shipping cost for 2 pieces:
- to EU, 18€, registered, priority, up to 1,5kg.
- outside EU, 20€, registered, priority, up to 1,5kg.
I can send packages to EU via DPD too and some reason the shipping cost
can be the same or lower than 18 or 20 € for 2 or 4 motherboards, but
it depends on destonation country.
I have a faulty C64 system board, black screen, ASSY. No. 250407, can I use my SID on any of the above system boards? Are the SID's compatible between C64 boards?
Nope, the old 6581 SID will not work out of the box in those short boards, which are intended for 8580 SID, but you can replace three components to adapt it. Namely:
1- The 7809 voltage must be replaced by one 7812, as the old SID uses 12V instead 9V of the 8580;
2 & 3- two small capacitors in the SID circuit, C10 e C11. SID 6581 uses 2x 470pF instead of 2x 2.2nF.
Correct! If the SwinSID is made in 6581 emulation you must replace both capacitors in the mobo, nothing more.
SwinSID does not use 9 or 12V.
C64C motherboard 250469 REV B available? tested & working?
Declaring interest in 1 board.
Preferably rev-b!
Or at least one with support for real-pla.
Shipping to the Netherlands.
