ZIP to SIMM adapter for the A3000D
Hello,
if solaris is still interested, this adapter is ready to be sent.
Otherwise, Amigo-Mexicano that is, more or less, second in line.
Postage to Mexico, with tracking, is about 12-13 Euro; to Germany, less, about 6-8 Eur.
If less cost, i will send refund.
Cheers
stefano
Hello,
about improvement on speed on ram-access, with this device, i have spooked about 'setramsey'. It won't work; there is speedRamsey, but it needs Ramsey rev G (from A4000): it works with 60ns simm and there is an improvement of 10% on speed of the computer. Anyway this adapter is for A3000D, that is equipped with a different revision of Ramsey. You need to check compatibility with DMac.
On my A3000D there is a Ramsey G, from an unknow A4000D: i will do test and post here results.
Cheers
Stefano
Hello,
i have installed 'SpeedRamsey' (it is on AMINET). Look at the pictures: the new setup requires 60ns memory SIMM.
Values before...
...and after...
On sysInfo the comparison is done with an A3000 with the fastest ZIP parts.
Remember, 'Ramsey' from Amiga 4000 is needed (rev G), because rev D doesn't this function...and now you can say 'goodbye' to the ZIP sticks.
I ask to the users that has declared interest, at least, to declare his decision to leave this sale.
Thanks in advance
Hello,
this good piece of hardware is still for sale. there is two pieces on sale.
Regards
Stefano
Declaring interest in 1 piece of A3000 memory adapter including logic chip supporting 16MB memory.
Hello,
received payment from nvana; the adapter will be sent ASAP.
Another part is for idav.
The two adapter now on sale are pictured here.
Please, with this adapter avoid this
Regards
Stefano
Looks like I was too late but I am declaring interest in 1 A3000 ZIP-to-SIMM adapter including logic chip supporting 16MB memory if you do another run of them.
Hello,
the two adapters are gone to nvana and idav. To others, please wait a little and stay tuned to this thread.
I state armitage as first in line for the next part done.
Regards
Stefano
Hello,
feedback left for the boths buyers. Item for nvana already sent. idav please wait a little (end of festivity!).
Regards
Stefano
Hello,
sent today the adapter for user idav.
I will return here when new part are ready. I consider the last request as first in line.
Regards
stefano
Hi!
Received today the adapter. Now 2 challenges, find a free slot to spend time on my A3000 and try to put it in the right way :)
Hi!
Hello,
keep me informed; so, tell me everything (the good and the worst, if the case)!
Regards
Stefano
Hello,
i have done two new adapters. They look very well, with a semi-transparent look! Good for the new owners!...and, there is another different thing...watch the pictures!
I ask to the users of this board, if they have declared interest in the past, at least to declare to leave this sale.
Another important thing: tell me if you are in needing of a strenght angled simm socket (to use on the original case of the A3000D), or if a vertical one is ok.
Thanks in advance.
Price is 40 Eur each + postage (about 7 Eur inside Europe).
Regards
Stefano
Still interested in one adapter for A3000D with support for 16MB! PM to follow.
Hello,
'armitage' you are first in line. I will send PM with infos about cost of the postage.
Another adapter is for sale.
Regards
Stefano
Hello,
the buyer can specify if the adapter will go in a A3000D inside a PC tower: in this case the adapter will be sent with a simm socket not angled, but vertical, if not a problem!
One adapter is still for sale.
Regards
Stefano
Hello,
received payment from 'armitage'! The adapter pictured will be sent ASAP.
Another one is on sale: you can specify if you are in need of a solution that fit on a A3000D case, or not!
This adapter has a semi-transparent look! ...And look strong enough for your A3000D!
Cheers
Looking forward to upgrading my RAM! I did have a couple questions:
1) Is there anything I should look for (or avoid) when buying a 16MB SIMM for the adapter?
2) Once the adapter is installed, do you recommend I remove my Z2 8MB expansion card? Will it hurt performance to leave it in since it's not a Z3 card?
Thanks!
