Page 5 of 101 FirstFirst 1234567891555 ... LastLast
Results 41 to 50 of 1009
Thread: Tapuino, the $20 C64 Tape Emulator
  1. #41
    galax's Avatar
    May 2014
    Canada
    Toronto, ON
    2 (100%)
    Default Tapuino, the $20 C64 Tape Emulator
    When you click 'upload', do the transmit and receive LEDs flash on the Arduino? Do you have the correct model (Uno, Mega, Leonardo etc.) selected in the software? I would first try uploading a really simple program that just flashes the LEDs or something to make sure that the Arduino is working OK.
    http://galax.xyz
  2. #42
    stephenfalken's Avatar
    Jan 2014
    Lancashire
    11 (100%)
    Quote Originally Posted by galax View Post
    Yeah cheers I have tried that already. Tested the blinky LED and also transmitting serial text to make sure it's working. Model is a Nano clone and is selected in the software. The LEDs flash as expected when uploading.
    Regards
  3. #43
    sweetlilmre's Avatar
    Jan 2013
    South Africa
    KwaZulu / Natal
    34 (100%)
    Quote Originally Posted by stephenfalken View Post
    Hi mate.
    I got my parts today and have literally thrown it together on these small breadboards just to test it. I haven't yet hooked it up to the C64 as I want to make sure it's working first.
    However, I am currently not getting any activity from the device and was wondering if that is normal without it being connected to the C64?
    Everything is powered and I have double/triple checked all the connections, but still getting nothing on the display. Is this supposed to draw power from the C64 or do you power it via the USB port?
    Thanks in advance!
    Regards
    Attachment 73074
    There is a blocking initialization issue with I2C i.e. the screen which will lock the chip up.
    This usually occurs if you have the LCD wired incorrectly, make sure you have the SDA and SCL lines correctly, try swapping them if you get no joy.
    Do you get any output over the serial monitor via the Arduino IDE? If not then an I2C problem is highly likely.
    I'll put some debugging in to the code now and push it so that serial gets set up and prints appropriate messages.
    Let me know
    -(e)
  4. #44
    galax's Avatar
    May 2014
    Canada
    Toronto, ON
    2 (100%)
    Sorry just had to check the obvious
    The instructions say "Caution: Do not connect the Nano to both the C64 and PC" - what is the problem with that?
    http://galax.xyz
  5. #45
    Jan 2013
    South Africa
    KwaZulu / Natal
    34 (100%)
    Ok,
    If you pull the latest code:
    On the serial console you should see:
    Starting init sequence
    I2C init OK
    Init...
    If you don't get to "I2C init OK" then I2C is not correctly wired.
    -(e)
    You'll be feeding power into the C64... generally a bad practice
    I need to look into some protection circuitry for that (if possible)
    -(e)
  6. #46
    galax's Avatar
    May 2014
    Canada
    Toronto, ON
    2 (100%)
    Would a diode on the power from the C64 be enough? That's what I do... Would it be possible to detect USB or C64 power?
    (Edit: I use Tapatalk on my phone to access the forum, it pops up a notification on any replies )
    http://galax.xyz
  7. #47
    Jan 2014
    Lancashire
    11 (100%)
    Wow you guys reply really fast! LOL
    I've just tried an LCD example sketch and without changing any wiring at all I can print text to the LCD no problem!
    Will have a look now at the latest code! Thanks!
    Regards
    Hmm
    All I am getting in the serial monitor is "Starting init sequence". Nothing else...
    As for the issue with the power, how do you power the Nano when connected to the C64? I am currently using your original breadboard layout which shows only 3 wires going to the datasette port.
  8. #48
    Jan 2013
    South Africa
    KwaZulu / Natal
    34 (100%)
    Regards
    Hmm
    Ah okay then this is definitely an I2C issue. Which library did you use to print on the LCD?
    I believe the problem is that the I2C backpack you are using has a different I2C address to mine.
    Look in config.h and find the "LCD_I2C_ADDR" define.
    Check that this is the same as the address you used in the other library, I bet its different
    -(e)
    A diode should do it as far as protecting the C64 (possibly, diodes might need to be put on several lines and there is also the 0.7V drop across the diode which might impact), but its still not a great idea to power from 2 different sources.
    -(e)
  9. #49
    galax's Avatar
    May 2014
    Canada
    Toronto, ON
    2 (100%)
    Quote Originally Posted by sweetlilmre View Post
    -(e)
    I connect an Arduino to the C64 user port data pins and USB at the same time. I think a common ground and diodes on the user port pins should be enough safety- leave the C64 Vcc disconnected from the Arduino.
    http://galax.xyz
  10. #50
    Jan 2013
    South Africa
    KwaZulu / Natal
    34 (100%)
    Check out the 2nd blog post I've got all the wiring there, I take power from the 5V line on the Datasette connector and wire it to the 5V line on the Arduino (not vIN).
    I'll update the breadboard diagram later.
    -(e)
  1. Wanted Cbm 64 tape deck
    By owen2471 in forum Commodore
    Last Post: 21st September 2013, 18:43
  2. Sold TAKEN: C 116 with tape
    By antonikaroly in forum Sales Archive
    Last Post: 23rd August 2013, 19:19
  3. Sold C64 Tape Bundle
    By morcar in forum Commodore
    Last Post: 11th July 2013, 00:44
  4. For Sale Tape Drive
    By alpehut in forum Other
    Last Post: 21st April 2013, 12:17
  5. Closed Zx 16 microdrives tape with box
    By Virge in forum Sales Archive
    Last Post: 11th July 2011, 20:07
Tags for this Thread
