Page 1 of 98 123451151 ... LastLast
Results 1 to 10 of 976
Thread: Useful Amiga Cables & Adapters
  1. #1
    a.mi.goun's Avatar
    Jan 2012
    Czech Republic
    Prague
    563 (100%)
    Default Useful Amiga Cables & Adapters
    I have for sale some useful Amiga Cables and Adapters:
    Some of them I sell in other threads, here you can find them better sorted.
    Payment: Paypal gift or SEPA Banktransfer. Prices do not include shipping costs.
    * Clicking over a cable/adapter title (or icon near the title) will show larger photo.
    ITEMS CONSTANTLY ADDED THRU TIME. RECENTLY ADDED ITEMS ARE MARKED *NEW. ALL CABLES/ADAPTERS LISTED ARE CURRENTLY AVAILABLE for SALE.
    Amiga Video RGB to VGA Adapter
    - Allows connecting Amiga native Video to LCD monitor with just a VGA cable. If that monitor supports 15 kHz mode (like BenQ BL702A or BL912), you will get a great picture comparable to a scandoubler. More info here. Includes cut db25->23pin connector. For deluxe adapters and more options check here.
    Price:
    10,5 €
    Amiga Video RGB to VGA Cable
    - An alternative to Amiga Video RGB - VGA Adapter is completly modified SVGA cable for even more comfortable and easiest way of connecting Amiga to BenQ BL702A / BL912 or any other 15kHz compatible monitor. (Please note that for bigbox Amigas such as A4000 and monitors other then BenQ BL702A / BL912 you need buffered sync signal). Buffered sync is for extra 5 €. Includes precisely modified db25->23pin connector, nice DB23 clone. For deluxe cables and more options check here.
    Price:
    15 €
    Amiga Video RGB to GBS 8200 (8220 or HD-VC9900) Cable
    - This cable will connect your Amiga to GBS 8200 Video Converter. Also compatible with GBS 8220 and HD-VC9900. High quality shielded videocable. You can choose either round cable (to connect to VGA in) or a flat type cable (to connect to P11 connector). Comes with 680 Ohm resistor on CSync as recommended. Includes cut 25->23pin connector.
    Price:
    14 €
    SCART-VGA (CSync) Cable Adapter *NEW
    - This cable adapter can be used to connect your Amiga (and other retro computers/consoles) to GBS-8200 (and similar) video converter or BenQ BL702A or BL912 monitors assuming you already have SCART cable (wired for CSync) for your computer/console. Optionaly I can also add an audio output (in case your computer/console only outputs audio thru scart).
    Price:
    14 €
    Minimig / MiST / MiSTer SCART Cable
    - Allows connecting Minimig, MiST and MiSTer to TV/LCD with the SCART input. SVGA grade videocable with ferite filters for perfect picture.
    14 €
    Minimig / MiST Video Cable for Commodore 1084S Monitor
    - Allows connecting Minimig or MiST to Commodore 1084S D-Sub 9pin Video Input. Cable will work with Philips CM 8833-II monitor too.
    Price:
    10 €
    Commodore 1084(S) and Philips CM8833-II RGB-Video Cable
    - Amiga RGB-Video Cable for Commodore 1084(S) monitor and Philips CM8833-II. Options are: 1/ Commodore 1084S-D1 (or Commodore 2002 or Phillips CM8833-II) monitor with DSUB(Canon) connector (photo). 2/ Commodore 1084S-P1 monitor with DIN connector (photo). Includes my precisely modified dsub connector, near perfect db23 clone.
    Price:
    15 €
    Amiga SCART cable
    - Gives great picture on TV / LCDs with SCART connector. For deluxe SCART cables follow thread here.
    14 €
    Amiga CD32 RGB SCART cable
    - RGB SCART cable for Amiga CD32. CD32 must have the 8pin MiniDIN connector, that provides RGB signals. Only the French CD32 had that connector, others have 4pin MiniDIN (where only SVideo signals are present).
    17 €
    Ratte Auto Switch Video Cables
    - Cables for Ratte Auto Switch. Options are: 1/ Indivision ECS 10pin to Ratte Switch 10pin (5 €), 2/ Cable from amiga VGA input (either scandouber eg. A3000 internal VGA, or a graphics card output) to Ratte 10pin port (11 €), 3/ Cable from Amiga native output (RGB Video port) to Ratte 10pin port (photo) (useful when you have 15kHz compatible monitor) (12 € modified 25-23 connector)
    Price:
    11 €
    DataSwitch Amiga Solution
    - Allows multiple Amigas on one table share one Keyboard, Mouse, Joystick, Audio with the help of a manual DataSwitch. More info here in my other thread.
    ADF-Copy Adapter Photo1, Photo2, Photo3
    - Comfortable solution for writing and reading Amiga floppy disks from PC with USB port by Dominik Tonn based on advanced Arduino compatible controller. Among its unique features is the ADFDrive that allows working with the floppy disk as it was an USB thumbdrive. Also HD floppy disks support and recently added flux-level support for reading disks into SCP format. Nice java-based GUI with lots of useful features. And compatible with various Operatining systems, not only Windows. Price for the adatper is 43 €, optionaly Micro USB cable 1,5€, straight Floppy cable 1 €, USB power cable for floppy drive 5 €. When you like it consider donating to the Dominik thru his website!
    43 €
    Arduino Amiga Floppy Disk Reader/Writer v2.2
    - Another solution for writing and reading Amiga floppy disks from PC with USB port by Robert Smith. Can read and write ADF files to(from) disk with easy to use program from Windows. Price for the adatper is 28 €, optionaly Mini USB cable 1,5€, straight Floppy cable 1 €, USB power cable for floppy drive 5 €.
    28 €
    Greaseweazle FDD Reader/Writer *NEW
    - Great solution for writing and reading (not only) Amiga floppy disks from PC with USB port by keirf. Working on a flux level, it can read and write SCP, HFE file formats to(from) disk and also write IPF files to disk. That means it can even duplicate originals. Conversion among other formats (including ADF) is of course possible. When you like to converter consider donation to keirf! Price for the adapter is 21 €, optionaly Micro USB cable 1,5€, USB power cable for floppy drive 5 €.
    21 €
    ADTWin Cable
    - Allows writing Amiga disks from PC with Parallel port (for more info check ADTWin website). Built according to the most recent scheme. Optionaly USB power Cable to power the Floppy drive for 4 € or a set of ADTWin Cable, USB Power cable and Floppy Drive for 21 €.
    Price:
    10 €
    Cable for connecting GOTEK as external floppy drive
    - With this cable you can connect GOTEK floppy as external floppy drive. Gotek is powered directly from external port just like any regular external floppy drive. Cable features genuine 23pin dsub connector. Many cable colors available to choose from in my original thread here.
    15 €
    A500/500+/1000/2000/3000 Bootselector
    - For A500, A500+, A1000, A2000, A3000 users I can also offer a boot-selector, that can allow booting from the external Gotek (or regular external floppy drive). This means no need to remove internal drive and still have option to boot from external drive. The adapter connects to CIA (B) slot. You just remove the CIA chip, place it in the adapter socket and put the adapter in place. With the switch you can select if internal or external drive is bootable. When external drive is bootable, internal drive becomes invisible. Simply - you can have either DF0 (internal) + DF1 (external) or just DF0 (external). On bigbox Amigas drives just swap being all visible and accessible.
    17 €
    Amiga - SEGA MegaDrive Pad Adapter
    - Allows safe and correct function of MegaDrive pads on Amiga and C64 (swapped 5V /Select lines + resistor and all signals connected thru diodes). Please note that connector of the adapter does not fit directly to A600/C64. Also note this will not make a full-feature replacement to CD32 joypad, megadrive pad will work only as a standard joypad with 1-2 button support.
    10 €
    Amiga - SEGA MegaDrive Pad short Adapter
    - Allows safe and correct function of MegaDrive pads on Amiga and C64 (swapped 5V /Select lines + resistor and all signals connected thru diodes). This adapter fits A600/C64 perfectly. Please note this will not make a full-feature replacement to CD32 joypad, megadrive pad will work only as a standard joypad with 1-2 button support.
    10 €
    SEGA MasterSystem LightGun/Phaser 3050 - Amiga Adapter *NEW
    - Allows connecting SEGA MasterSystem LightGun/Phaser 3050 or compatible to Amiga to play supported WHDLoad modified games with it.
    10,5 €
    Amiga - IOMEGA Zip100 Parallel Port Drive Adapter
    - Allows connecting parallel port ZIP drive to Amiga (uses Amiga parallel and Joystick port), I can include my ZIP100PP Boot driver disk depending your Kicktart ROM if you wish. For use in big-box Amigas ask me for making longer joystick cable. New improved version now includes shielded cover and passthru joystick connector that can be made to fit A600 as well.
    16 €
    ParNET cable
    - Allows connecting 2 Amigas for transfering data
    (files can be accesed thru NET: device in system)
    12 €
    Serial Nullmodem cable
    - Allows connecting 2 Amigas for playing supported multiplayer games or for transfering data. Can come as 3wire or 7wire (for faster transfer rate).
    Cable can be also made with small COM connector for connecting Amiga to PC. 3wire cable price 9 €, 7wire 11 €.
    9 €
    Easy 1541 Cable
    - Allows connecting Commodore 1541 (and compatible) drive to Amiga to transfer files etc.
    10 €
    Frodo IEC Cable
    - Allows connecting Commodore 1541 (and compatible) drive to Amiga and use it by Frodo C64 Emulator to to transfer files or run the C64 software directly from the drive.
    14 €
    Amiga-PS2 Mouse Cable Adapter
    - Allows connecting standard PC PS2 mouse to Amiga. Adapter can come with either PS2 or USB connector (Mouse still has to support PS2 protocol). All adapter types are listed here.
    18,5 €
    A600 mouse/joystick port adapter
    - This adapter allows connecting devices to Amiga 600 mouse/joystick that normally would not fit because they use larger connector. Cable version also available.
    4,5 €
    Joystick UP & Fire Swap adapter
    - With this adapter you can swap your joystick's 'UP' direction & 'FIRE' button, so that you can press fire button for jump and the fire is routed to second fire-button (if present). Useful in jumpy games like James Pond 2 Robocod, where most people prefer FIRE button for Jump. Only way is to swap the signal lines and that is what the adapter does. You can decide whether you want swap: UP to Fire1, or UP to Fire2. You can also decide if you want original 'UP' connected or disconnected. Default mapping is UP to Fire1, Fire2 to Fire, original UP disconnected. Connector is compatible with A600 and C64 too.
    6 €
    Amiga "low-space" mouse/joystick port cable extender & adapter
    - This special 9pin Dsub (canon) cable extender allows connecting devices mice/joysticks to Amigas where there is very little space near ports that prevents fitting normal connectors. Also useful in towerized amigas to extend the connectors. Connector will even fit to A600 mouse port, so this cable can be also used as A600 mouse port adapter. You can decide length of the cable.
    5 €
    Parallel port laplink cable
    - This parallel port cable allows easy filetransfers between Amiga and PC through direct Parallel port connection. PC Drives are mounted on Amiga as Devices which allows easy file management. You need an old PC otherwise timeouts may occur. Long filenames are supported thanks MSDOS 7 or FreeDOS and DOSLFN. Kickstart 2.0+ is needed to run PC2Am. Software in action is presented here.
    10 €
    Paradise Amiga-PC Parallel port cable
    - This parallel port cable allows fast filetransfers between Amiga and PC through Paradise software. The latest version of the software adds direct usage from Windows.
    10 €
    PS2 Keyboard - Amiga Mini Cable Adapter
    - Allows connecting PS2 Keyboards to bigbox Amigas such as A2000/3000/4000 or CD32/CDTV. Follow my original thread here for more info.
    17,5 €
    CDTV Keyboard to CD32 (and A4000) Cable Adapter
    - This cable allows connecting CDTV Keyboard to Amiga CD32 (and A4000).
    10 €
    Blizzard vision / Cybervision PPC VGA Cable
    - Cable which connects internal Blizzardvision (BPPC) or Cybervision (CVPPC) graphics cards to Monitor. You can decide the length of the cable (default 35cm).
    9 €
    Indivision ECS or AGA MK1 internal Scandoubler/Flickerfixer cable
    - Cable which connects internal Indivision ECS (or Indivision AGA MK1) to Monitor. You can decide the length of the cable.
    9 €
    Indivision AGA MK2 4000/CD32 internal Scandoubler/Flickerfixer HDMI cable
    - Cable for Indivision AGA MK2 4000/CD32 (not cr) with HDMI connector (female).
    18,5 €
    Indivision AGA MK2cr internal Scandoubler/Flickerfixer VGA cable
    - Cable for Indivision AGA MK2cr with VGA connector. You can decide the length of the cable, default is 30cm.
    11 €
    Indivision AGA MK2cr internal Scandoubler/Flickerfixer HDMI cable
    - Cable for Indivision AGA MK2cr with HDMI connector (female). The HDMI cnnector can be installed in place of removed RF modulator (you can fix the connector in place easily be using strong double sided tape) or mount on a bracket etc.
    Three types of cables now available: Cable1, Cable2 (with small HDMI socket), Cable 3 (with larger HDMI socket panel mount type and can be detached to small HDMI plug)
    24 €
    Indivision AGA MK2cr internal Scandoubler/Flickerfixer DVI cable
    - Cable for Indivision AGA MK2cr with DVI connector (female) providing both analog and digital signal just like the original cable. Can be used as a replacement for a broken original cable. Default cable length is 30 cm. Can be made longer or shorter if needed.
    Optionaly I can supply with smaller and low profile DVI connector (photo) for +1 €.
    17 €
    DCE internal Scandoubler/Flickerfixer cable
    - Cable which connects internal DCE Scandoubler/Flickerfixer to Monitor.
    10 €
    Amiga 4-Player Adapter
    - This adapter allows connecting 2 more joysticks to Amiga to parallel port for playing multiplayer games such as Dynablaster and many others (list of supported games for example here). Also on PC you can use the adapter with PPjoy driver (for windows XP and older) to use amiga joysticks as digital joysticks. Adapter is wired to support also the second button.
    9 €
    Amiga Floppy DF0 Terminator
    - This adapter removes the delay when floppy drive is not connected to internal floppy drive port.
    3,5 €
    Amiga 4000 IDE Terminator
    - This adapter removes long delay when you reset Amiga and you do not use any IDE Devices. Useful when booting from other controller such as Fast ATA/SCSI etc.
    3,5 €
    Blizzard SCSI-Kit IV internal cable
    - Internal SCSI cable for Blizzard SCSI Kit IV. Allows connecting one scsi 50pin device, default length 35cm. Custom cable (eg. longer cable or connect more scsi devices) on request.
    12 €
    Blizzard SCSI-Kit IV original cable *NEW
    - Original SCSI cable for Blizzard SCSI Kit IV with the external DB25 female connector. Can be made with male DB25 connector as well if requested.
    10 €
    Paravision SX-1 external HDD cable
    - With this cable you can connect standard 40pin IDE device to external HDD connector of the Paravision SX-1 expansion for CD32. As the port provides also +5V, the cable offers posibility to power devices that are ok with just +5V (ideal for CF card adapters).
    18 €
    Squirrel SCSI ext-int cable
    - With this cable you can connect internal SCSI devices such HDD's to Squirrel PCMCIA SCSI controller.
    8 €
    CF-IDE 44pin Female Adapter *NEW
    - Adapter to connect Compact Flash Card to 2,5" 44pin IDE port. Perfect for A1200/600 and for Terrible Fire TF328 or 330 cards as it connects directly to IDE port- no need for cable.
    10 €
    IDE 2,5->3,5 Adapter
    - With this adapter you can connect 3,5" IDE cables into internal A1200/A600 IDE connector. Power cable provides +5V power if needed.
    5 €
    DIN - PS2 Adapter
    - With this adapter you can connect old DIN keyboard to PS2 connector. For example A2000 and A3000 keyboard to A4000.
    2,5 €
    PS2 - DIN Adapter
    - With this adapter you can connect PS2 keyboard to DIN connector. For example A4000 keyboard to A2000.
    2,5 €
    FDD round cable
    - With this cable you can connect internal floppy drives. This is standard PC floppy round cable modified for direct connection, that is used by Amiga internal floppy drives DF0. UV glow cable red (pink) color 45cm.
    6,5 €
    Floppy power cable
    - Used to power floppy drives on A500/600/1200 etc. On request I can make other custom power cables, for example cable with three small plugs to power also CF adapters etc.
    6 €
    Amiga M1438 Microvitec RGB monitor - VGA adapter
    - Allows connecting Amiga (Microvitec) multisync monitors (that come with 23pin RGB cable) to VGA port (15pin) such as graphics card on Amiga or PC. Features genuine 23pin connector.
    13 €
    Amiga - ATX Power Supply Adapter
    - With this adapter you can connect standard PC ATX Power supply to Amiga 500/500+/600/1200. As there is no supply of original square DIN connector, I use my modified round connector, that work well. Comes with ON-OFF switch.
    17 €
    Amiga 2000 - ATX Power Supply Adapter
    - With this adapter you can connect standard PC ATX Power supply to Amiga 2000 and thus replace the old, noisy and failing original PSU.
    16,5 €
    Amiga 3000 - ATX Power Supply Adapter
    - With this adapter you can connect standard PC ATX Power supply to Amiga 3000 and thus replace the old, noisy and failing original PSU.
    17 €
    Amiga 3000T - ATX Power Supply Adapter
    - With this adapter you can connect standard PC ATX Power supply to Amiga 3000T and thus replace the old, noisy and failing original PSU.
    21 €
    Amiga 4000 - ATX Power Supply Adapter
    - With this adapter you can connect standard PC ATX Power supply to Amiga 4000 and thus replace the old, noisy and failing original PSU. Especialy well suited for desktop A4000.
    16,5 €
    Amiga CD32 - ATX Power Supply Adapter
    - With this adapter you can power your CD32 (or A590 harddrive or Commodore 1541-II floppy drive) from a standard PC ATX power supply.
    14 €
    Amiga CD32 - Molex Power Supply Adapter
    - With this adapter cable you can power your CD32 (or A590 harddrive or Commodore 1541-II floppy drive) with a standard molex connector of the AT/ATX power supply.
    9 €
    Amiga CD32 - Cisco Power Supply Adapter Cable *NEW
    - With this adapter cable you can power your CD32 (or A590 harddrive or Commodore 1541-II floppy drive) with CISCO ADP-29EB power supply.
    13 €
    Floppy Port - USB Power Cable
    - This cable can be used to power low-power devices such as SDBox or Plipbox directly from Amiga external Floppy Drive Port. USB connector can be miniUSB or microUSB at your wish. Default length is 20cm. Can come with cut connector for 11 € or genuine 23pin connector for 13 €.
    11 €
    Amiga-PC Serial Nullmodem Adapter
    - With this adapter you can make serial connection between Amiga-PC (and viceversa) for example to transfer data with Amiga explorer or other similar software. If your PC does not have serial (COM) port you can use USB-RS232 Converter (I can supply one for 4 €).
    9 €
    Amiga 4000 IDE Splitter cable
    - This cable enables you use both CF-Card Adapter and CDROM on A4000 internal IDE controller. You may have noticed that when directly connecting CF-Adapter and CDROM to A4000 the CDROM is not recognized. This special cable works similar way as 4xIDE splitters (I integrated the capability directly into the cable), and enables another channel for the CDROM thus making it available. With the help of IDEFix software you can then access the CDROM thru atapi.device on unit 3.
    11 €
    68030 or 68040 / 68060 Heatsink (standard or low-profile)
    - Hi-quality anodized aluminium heatsink for 68060 or 68040 CPU (Dimesions L:45,7mm, W:45,7mm, H:16,5mm) for 6€ (photo). Also available Low-Profile version (photo) (Dimensions: L:42,5mm, W:45mm, H:6mm) for 4 €. Also available low-profile heatsink for 68030 CPU (Dimesions L:35mm, W:35mm, H:6mm) for 3,5 € (photo). Heatsinks cover whole CPU and are high-efficient. I can also include quality adhesive tape for the heatsink for additional 1 €.
    6 €
    Crystal Oscillator 70 Mhz
    - Useful when you want to experiment with overclocking your Blizzard / Cyberstorm Accelerator. Take care of proper processor cooling when operating overclocked.
    3 €
    SCSI Stuff
    SCSI SCA80 to 50pin or 68pin SCSI adapter (10 €)- Converts a SCA 80 Pin Hard Drive Interface to SCSI I/II/III (UW) HD 50/68 Pin Connector
    SCSI DB25 Active Terminator (15 €)- External active SCSI terminator, very useful for A3000 to terminate the external port. If you want proper and reliable termination on A3000, remove internal scsi resistors, make sure the harddisk has terminator jumper inserted and put this external terminator on external port.
    For other computers I offer:
    COMMODORE 8-bit
    Commodore Hi-quality Video Cables thread here
    Commodore 64 Power Adapter Cable (14 €) (photo1) (photo2)
    - This cable adapter allows you to power-on your C64 by two separate power adapters. Just connect 5V AC-DC 1,5Amp and 9V AC-AC 1Amp power adapters and you have a replacement C64 power supply.
    Commodore 128 Power Adapter Cable (16 €)
    - This cable adapter allows you to power-on your C128 by two separate power adapters. Just connect 5V AC-DC 1,5Amp and 9V AC-AC 1Amp power adapters and you have a replacement C128 power supply.
    XE1541 Cable (11 €) (photo)
    - Allows connecting Commodore 1541 (and compatible) drive to PC with parallel port to transfer files (Star Commander runs from DOS environment). Cable can be also used to simulate 1541 drive from PC by 64HDD software.
    1541EMU Cable (15 €)
    - This cable and 1541EMU software for PC (DOS) can emulate full Commodore 1541 Floppy drive. With the fact full 1541 is emulated, means fastloaders can work. Depending on the PC parallel port some tweaking may be necessary. How it works I demonstrate here.Pi1541 Cable opt.A (14 €) (photo) *NEW- With this cable you can use your Raspberry 3B or (3B+ 3A+) to emulate Commodore 1541 Floppy drive. Full emulation of the drive makes even fastloader work.
    OTHERS
    Apple IIS GS - RGB Scart Cable - Hi-Quality OFC based cable - 15 €
    ATARI 520ST(M) - ATX Power Adapter - Allows powering ATARI 520ST(M) from standard PC ATX Power supply - 15 €
    ATARI ST - Amiga Mouse Adapter - Allows using Amiga mouse with ATARI ST computers - 5 €
    GOTEK external Floppy Cable for ATARI ST in my thread here
    PC MIDI Cable - MIDI Cable for PC soundcards with DB15 MIDI/GAME port. Midi In and Midi Out. 2xDIN5M and 2xDB15MF connectors. Optocouplers integrated in the cable - 10 €
  2. #2
    Inactive Member bcmdesign's Avatar
    Jul 2011
    Germany
    Bavaria near Munich
    Age
    42
    101 (100%)
    Interested in:
    PM is on its way ...
  3. #3
    Sautebroussailles's Avatar
    Jan 2014
    Belgium
    Brussels
    Age
    44
    17 (100%)
    Interested in Amiga SCART cable
    PM sent.
    A1230-A1260T-A3040D-A520(ACA500+1221)-A600-΅AOne-CPC464/6128/6128+/PCW8256-C64/128-Msx Sony-Thom. T08D/T09/M05-Sinclair 48/+/+2A/QL-Atari 1040STF/Falcon030-Apple II clone-GX4000-Atari 2600/7800/Jaguar- Intellivision -Sega MS/MD/MegaCD/32X/Saturn/DC-Nintendo Nes/GBA/SNes/N64/Gamecube/Wii-PCengine/SuperGrafX/Duo-RX -Sony PS 1/2/3-XBox-Amiga CD32-NeogeoCD-3DO
  4. #4
    a.mi.goun's Avatar
    Jan 2012
    Czech Republic
    Prague
    563 (100%)
    @bcmdesign: PM sent
    @ Sautebroussailles: Payment received, sending your cable tommorow.
  5. #5
    Inactive Member CrazyBob's Avatar
    May 2013
    The Netherlands
    Limburg
    136 (100%)
    Interested inADTWin kit and sega adapter, sending pm
    [COLOR=#ff0000][B]=> [/B][/COLOR][COLOR=#808080][B]Commodore A600HD/40 [/B][/COLOR][COLOR=#ff0000][B]<=
    [/B][/COLOR][COLOR=#0000cd][B]3D Amiga Gotek frames: [/B]http://www.thingiverse.com/_CrazyBob_/designs[/COLOR][COLOR=slategray]
    [/COLOR]
  6. #6
    Jul 2011
    Germany
    Bavaria near Munich
    Age
    42
    101 (100%)
    PM and payment sent ....
  7. #7
    May 2013
    The Netherlands
    Limburg
    136 (100%)
    Payment has been sent.
    [/COLOR]
  8. #8
    Jameson's Avatar
    Jan 2015
    Queensland
    10 (100%)
    Interested in several of the Megadrive to Amiga controller adapters, however need to ask first...
    Will these work with ALL Megadrive compatible controllers? The reason I ask is that I have done the simple "swap lines 5 and 7" on many controllers and it does not work on many of the newer 3rd party 6 button Megadrive controllers.
  9. #9
    a.mi.goun's Avatar
    Jan 2012
    Czech Republic
    Prague
    563 (100%)
    @ Jameson: I have only original SEGA 3 button pad, so I cannot tell, how about 6 button ones. If I have one, I would certainly test. But I would think they should work if they claim to be compatible..
  10. #10
    Lead Moderator
    Administrator
    Sardine's Avatar
    Mar 2012
    Merseyside
    237 (100%)
    Please put the prices back in the thread.
  1. For Sale Amiga VIDEO - VGA Adapters & Cables DELUXE
    By a.mi.goun in forum Amiga
    Last Post: Today, 00:55
  2. For Sale video cables/adapters
    By skromny in forum Other
    Last Post: 18th October 2015, 19:34
  3. For Sale Mouse and keyboard adapters/extension cables
    By Exilent in forum Other
    Last Post: 23rd January 2014, 20:14
  4. Sold Mac LocalTalk adapters and cables / Modem
    By AndyLandy in forum Sales Archive
    Last Post: 14th December 2010, 19:56
Tags for this Thread
