Page 86 of 87 FirstFirst ... 3676828384858687 LastLast
Results 851 to 860 of 867
Thread: A500 IDE adapters, PS/2 mouse adapter, A600 CF adapter
  1. #851
    blindguy's Avatar
    Jun 2019
    United States
    AZ
    8 (100%)
    Declaring interest, sending PM.
    Soldered combination v425 ide+ 8MB (low profile for a500, cdtv, others) cpu plugged in 85€,
    Special ide-cf adapter for v4xx for 10 euros or with a v4xx board +5 euros.
  2. #852
    mkl's Avatar
    Jan 2009
    Finland
    Tampere
    107 (100%)
    Hi!
    I got previously (some time ago) sent an installation picture for A1000, but I have not found it since, so if the sender is reading this, please send again.
    http://mkl211015.altervista.org/ide/ide68k.html email&paypal: mlvhct@gmail.com See first post of for-sale thread for up to date availability info
  3. #853
    Hivernaal's Avatar
    Oct 2010
    france
    Normandie
    19 (100%)
    Hello
    payment sent for v425 ide+ 8MB
    Thank you
    Member of the Amiga rescue Team
    Steampunk A4000T, Victorian steampunk A4000T, A1200, A2000, Venom by Dean Bean Zelinsky, Venom home made.
  4. #854
    Brostenen's Avatar
    Nov 2015
    Denmark
    Northern Jutland
    44
    9 (100%)
    I have two small questions, regarding the combined IDE/8mb adaptor that I bought....
    The first question is regarding use of CF card and CF-to-IDE adaptor. What type and combination of card and adaptor is compatible alongside an optical CD-Rom drive, in a Master/Slave setup?
    The second question is if I can disable the 8mb ram, if I need to test stuff on my Amiga500?
  5. #855
    mkl's Avatar
    Jan 2009
    Finland
    Tampere
    107 (100%)
    cf and cdrom? I dont know really, it also has to do with drivers and filesystems. Below 4GB cf shouldn't need extra driver. Cd filesystem? These things should be compatible with A600 setup
    To disable ram, check the config in :
    If it has pull-up resistor, and is grounded with solder, removing solder bridge disables ram.
  6. #856
    Brostenen's Avatar
    Nov 2015
    Denmark
    Northern Jutland
    44
    9 (100%)
    Quote Originally Posted by mkl View Post
    Ahhh...
    Well. I have had different type of drives running with it, with a CD drive in slave. To use the CD drive, I used the AmiCD or something like that. The kickstart that I use, is kick 2 version 37.350. Regarding CF card, then it is running happily with these 512mb cards, yet for some reason they need a slave drive present. So my question was more or less aimed at what type of IDE compatibility a CF card need. You know, PIO mode and stuff like that.
    Regarding Ram. I was just wondering if using a jumper to ground something or using a switch, in order to disable the memory.
  7. #857
    Lukeya's Avatar
    Oct 2019
    United Kingdom
    East Sussex
    5 (100%)
    Express interest in 8mb RAM board to use alongside TF534 in an A2000
  8. #858
    Reqo's Avatar
    Nov 2017
    Hungary
    Ungarn
    2 (100%)
    Interested in one ide board without cpu.
  9. #859
    grayswan's Avatar
    Dec 2018
    United States
    MA
    41
    0
    Hi there,
    I'm interested in two Soldered combination v425 ide+ 8MB for two A500 rev 5s. Email sent as well.
  10. #860
    mkl's Avatar
    Jan 2009
    Finland
    Tampere
    107 (100%)
    Quote Originally Posted by Brostenen View Post
    Ahhh...
    CF card issues... ? I don't know what's causing that with the slave present issue. I have thought CF cards may not "care" about PIO modes, anyway it would be one of the slower ones in 7MHz Amiga. BTW, what kind of cf adapter? is it 3.3 volt or 5 volt?
    You could wire a switch between RAM config in and gnd.
  1. Closed Amiga PSU and PC mouse adapter
    By Puni/Void in forum Found Archive
    Last Post: 4th September 2012, 18:59
  2. Closed Amiga mouse / mouse adapter
    By moijk in forum Found Archive
    Last Post: 3rd February 2012, 11:37
  3. Sold Punchinello III ps2 mouse adapter
    By bazzaq in forum Sales Archive
    Last Post: 25th June 2010, 13:14
  4. Sold Micromys V3 PS/2 Mouse Adapter
    By everblue in forum Sales Archive
    Last Post: 18th June 2010, 22:29
