Boards usually supplied without documents. For online information (about kickstart and needed wiring for A500,1000,2000, CDTV) see http://www.mklboards.fi/index.html
2 available: Ide + 8MB combo units. 85€ includes also: CF-adapter, 1GB CF (this model 'fixed disk' in HDToolBox), and a CPU of choice: low power new old stock MC68HC000P10 or nos MC68000P12.
Low profile combination for A500 and CDTV(which need cpld reprogrammed)
Shipping 100g 7.50€ Europe, 17.50€ world (registered mail +16.10€ signature, tracking not available to every country)
A number of IDE only boards will be available, 45€
3 RAM boards listed in its thread.
Message: If you have a ram board from me sold before september 14. 2018, your board probably has a malfunctioning RAM controller. It can be fixed by reflashing the CPLD using 6-pin pogo pins and whatever tools you use for Xilinx CPLDs. I have no guide for the process now.
Jedec files and other info: http://www.mklboards.fi/ram68k
Old pictures and text below:
A2000 can fit separate ram and ide boards stacked. A1000 maybe can fit this stacked set? A1000 needs also KS-ROM adapter to boot.
IDE v425i 50€
0 pcs
Special ide-cf adapter for v4xx for 10 euros or with a v4xx board +5 euros. CF-card will be against the 68000 cpu chip and upside down. Female header or female header with extended pins on other side for connection of other ide bus device. Photo at post #461)
a few: with clearance for v4xx+v6x ram combo. 5 pcs for v4xx without ram board, 0 pcs with clearance for soldered combination ide+ram units, 0 with extended pins.
PCB: 5€ ram v67, 6€ ide v425i
RAM homepage --- www page not available at the moment
8MB v59 and (v6x) (/ with ide board) info: a posting in this same thread.
Ide info below in this post.
(link to old thread for ram )
Might include wires and pin header for int2 and ovr connection.
Pin 20 on ide board has same voltage as cpld, 3.3 volt regulator on v425 board max. 300mA. Some CF adapters have diodes on supply lines, the floppy power input can be used on those (maybe jumper diodes to drop +5v to +3.3v).
Pin 20 can be removed for 80-wire ide cables.
Summary: Plugs to 68K socket, one 40-pin (or 39-pin) connector, "cf" versions also have cf connector
Autoboots using A600's KS-ROM with driver for A600's ide interface (40.063/37.350/37.300)
User needs to connect two (3 in 'cfidecp') signals to Amiga mainboard. A ground wire alongside with signal wires is recommended if the signal wires are not short and following ground trace on amiga pcb to reduce EMI caused by loop inductance.
Cyberfred91's picture of placing a v402 board and cpu on A500 board (R8A1).
(Click the following attach link if the thumbnail doesn't show up)
Some pictures:
A600 cf adapter
-a few pcs: A600 Internal CF-card adapters to IDE connector 15 eur/pce.
Version with also a extension header on top (for hard-disk cable or other adapter) 15€ /pce. Other guide "wing" of cf socket is removed to make space for top header connector.
Mouse adapters
-0 pcs stock Amiga ps/2 mouse adapters with 10pin header, 15€
-upto 7 pcs, without header, long body right angle db9 connector, 20€
PS/2 mouse adapter, Version for Atari ST for sale at Atari ST section.https://www.amibay.com/showthread.p...pters-for-Atari-ST-(-quot-PS2M-quot-firmware)
Other items, Riser cards
LINK 68000 cpu:s
LINK SOJ RAM to DIP-20 footprint adapters with 1M x 4 drams
LINK "riser" cards for 68000 socket, a500 side slot 86-pin edge
LINK adapter board TV-frequency-VGA-in+stereo-in -> SCART-socket-connector-out
LINK 27c4096 to 27c400/800/160, plcc denise to dip socket adapter
LINK 2x 29f040 flash plcc to 27c800 dip socket
LINK ps2 mouse adapter for Atari ST
LINK DCN-2692 (cbm-1581 'clone') v0.15 boards, without cia,wd1772, or rom
Payments
1. Paypal "gift" (send your shipping address by PM) or add fees for (ordinary) paypal.
1B. if sending usd, check that both sending and receiving amounts are in usd (not receiving to euro balance)
2. "Euro transfer" to bank account with IBAN (+ BIC) number (and other needed data.)
IDE v425i 50€
0 pcs
Some pictures:
A600 cf adapter
Mouse adapters
LINK 68000 cpu:s
Payments
