Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: GOTEK and HXC FIRMWARE on ATARI STE
  1. #1
    braincell1973's Avatar
    Apr 2015
    england
    norfolk
    6 (100%)
    Default GOTEK and HXC FIRMWARE on ATARI STE
    So, After buying 2 HXC units recently for my STE and amigas i found the cortex firmware for GOTEK.
    I bought 2 and soldered in the pin headers , I had a spare usb - serial adapter and flashed the cortex firmware, dropped on my adfs and it worked great in my 600 & 1200...... Well, Execpt for the massacre i had to do to the case ........*facepalm*
    After spotting a forum post saying the HXC firmware would work on a GOTEK i spent the 10 euro and got a link to install it.
    After installing the HXC serial bridge software the fun began.
    I plugged in a GOTEK hooked up the serial adapter and put the password and contact details into the serialbridge software and it took many attempts over 20 minutes to read - device detected.
    It kept saying "LINK IS UP!" - "LINK IS DOWN!"......
    I hit program and it said "STARTING!".... And it sat there.
    After 2 reboots / resets it finally programmed.
ID:	88022Click image for larger version.
    Once programmed with the bootloader then the firmware *.UPG can be uploaded on a USB stick and holding both buttons at powerup.
    The GOTEK unit fits well into the ATARI and there is just enough room to flip the floppy cable over to plug it in.
    The HXC firmware (At the moment) means the need to convert to *.HFE Images which isnt so bad.
    The GOTEK then behave exactly like a HXC unit, The directory list speed is identical and everything works the same.
    As a bonus the GOTEK fits so nicely into a ST that onbly a small cut is needed to remove the floppy button hole.
    My units are even the same color as an ST
    So, Is it worth the greif flashing a GOTEK with HXC firmware ????
    Yes, But only if you have patience as it was NOT straightforward.
    Lee
    UPDATE 16/05/15 **********
    Bought 3 more units with intention of loading HXC firmware into them , Sent a payment for 1 unit and quickly got a reply saying my account had been credited with 1 license.
    So i hooked up my drive and ........ Wont recognise.
    OK , so i fired up the ST programming software and blasted in the cortex firmware..... NO errors , Verified OK.
    So we know all connections are good, unit tests OK in amiga.
    reconnect fire up HXC serial bridge again , Nope , Just sits at "Link is UP!" , no error nothing, reset GOTEK, Still nothing.
    Reflash cortex again and yet again completes without error.
    Update CH340 drivers , no effect , 3rd time i flash cortex flawlessly.
    boot into XP machine , same as above, goto PC number 3 , YET AGAIN cortex OK , HXC just waits there at "Link is UP!"
    UPDATE. was server problem at their end. Quickly fixed by Mr Hxc.
    Tried to flash and got what happened at top of this post.......
    Moved over to win XP machine and flashed without issue..
    Bought 2 more licenses and flashed those too smoothly
    3 x atari st kitted out and have spare unit for 1200. .Adf support is ip
  2. #2
    Beaps's Avatar
    Apr 2011
    Essex
    35 (100%)
    Blog Entries
    1
    I would love to see a step by step guide with any links required
  3. #3
    Jeff_HxC2001's Avatar
    Aug 2010
    France
    France
    0
    http://hxc2001.free.fr/floppy_drive_....html#download
    http://hxc2001.com/download/floppy_d...rialBridge.zip
    http://hxc2001.com/download/floppy_d..._V3_0_0_0a.zip
    Anyway by correctly copy/past the password provided and using the right driver for your usb serial adapter to avoid the BSOD, this can be done in 4 minutes
    BTW the device can be get from amigastore with the HxC bootloader flashed. Once the bootloader is inside the device, any update can be done with a simple USB stick
    http://amigastore.eu/en/323-usb-flop...strad_spectrum
    https://www.youtube.com/watch?v=MTzDDrLOKkQ
    https://www.youtube.com/watch?v=JQRd-dC5x5Y
    https://www.youtube.com/watch?v=JBScK_wDBCk
    https://www.youtube.com/watch?v=BjNUWYEOnNY
  4. #4
    Jameson's Avatar
    Jan 2015
    Queensland
    10 (100%)
    Hi Jeff,
    interested as I already have several Gotek units (and incidentally, HxC units), but just wondering - is the registration/account locked to a single Gotek unit, or can I install on several once an account is purchased/set up?
  5. #5
    Apr 2015
    england
    norfolk
    6 (100%)
    Quote Originally Posted by Jeff_HxC2001 View Post
    I didnt have any BSOD's it simply kept switching to link is down / up then when i did get "link is up!" stable i pressed program and it froze at "starting!"..... twice.
    too be fair it may be my cheap-as-chips serial adapter from ebay, but i think most people will probably have similar devices.
    lee
  6. #6
    Allen1's Avatar
    Dec 2009
    Northumberland
    73 (100%)
    I tried downloading the files and thought I had succeeded until I opened the STM32_SerialBridge.zip, it was only 50.0kb and comes up with unexpected end of archive. Any other attempts to re-download the file comes up with :-
    "The connection was reset
    The connection to the server was reset while the page was loading.
    The site could be temporarily unavailable or too busy. Try again in a few moments.
    If you are unable to load any pages, check your computer's network connection.
    If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web."
    Is anyone else having a problem downloading the file or is it just me or my provider stopping it?
    Cheers,
    Allen
  7. #7
    We Will Never Forget.. Amibayer!
    Staff Moderator
    ChrisUnionNJ's Avatar
    Jun 2010
    Union,NJ
    Age
    57
    79 (100%)
    Quote Originally Posted by braincell1973 View Post
    lee
    I tried it on my win7 pc and the PC went blue screen a 49 both times so I moved to my XP PC and it and no problems downloading the firmware..
    Now my problem is it will not run the image I pick but I did not convert it to hfe so i'll give that a shot..
    Update:
    Yep had to convert them to hfe and that's going to be a big job...
    Never Bin or sell your old computer's you will regret it!!
    Vic 20 x3,C64 x2,128D,C128 flat deck,A1000 x2,A500 x3,A2000,A600,A1200,Apple ][e,2x Apple][ GS rom 01,03,Apple ][c x4 with only 1 PSU,2x Laser 128EX EX2,Atari 600XL,2x 800XL,130XE w/320 mod With a MyIDE plus,Atari 1040stf w/2.5meg..
  8. #8
    Apr 2015
    england
    norfolk
    6 (100%)
    Quote Originally Posted by ChrisUnionNJ View Post
    lee
    Update:
    Nah the HXC software is very good and has a batch mode
  9. #9
    Allen1's Avatar
    Dec 2009
    Northumberland
    73 (100%)
    Well today I can download the file but it is always less that 50.0kb and "unexpected end of archive" every time!
    Can anyone upload the full file here so that I can have a look at it (STM32_SerialBridge.zip).
    Cheers,
    Allen.
    Edit
    Aha the problem was with Avast internet security, I switched off the shields and tried to download and it was fully successful
  10. #10
    Beaps's Avatar
    Apr 2011
    Essex
    35 (100%)
    Blog Entries
    1
    Which Goteks are the best ones to use SFR1M44-U100K or SFR1M44-U100 or are they both the same. Are there models to avoid?
  1. Replies: 4
    Last Post: 28th October 2017, 07:05
  2. Replies: 4
    Last Post: 7th July 2014, 20:12
  3. For Sale PS2 > Atari mouse adapter kits/parts PeST firmware.
    By exxos in forum Atari
    Last Post: 9th June 2014, 11:07
  4. Gotek firmware updating.
    By mjnurney in forum Photo Booth
    Last Post: 1st March 2014, 02:14
Tags for this Thread
