Page 1 of 112 123451151101 ... LastLast
Results 1 to 10 of 1111
Thread: Amiga VIDEO - VGA Adapters & Cables DELUXE (real 23pin conns)
  1. #1
    a.mi.goun's Avatar
    Jan 2012
    Czech Republic
    Prague
    404 (100%)
    Default Amiga VIDEO - VGA Adapters & Cables DELUXE (real 23pin conns)
    CURRENTLY STILL AVAILABLE
    As I managed to buy limited amount of an old stock of expensive real 23 pin female connectors I intend to use them to build my Amiga Video - VGA Adapters and Cables.
    I call them "DELUXE" because the Adapters feature real 23 pin connectors and metal coated covers. The Cables use 23pin conns and also 23pin covers.
    As bonus I can offer also buffered Adapters built with the exact same components as Commodore VGA Adapters. Please note that for BenQ BL912 and 702A buffered is not needed and these monitors accept unmodified Amiga sync perfectly. Generaly you need buffered adapter/cable only in case you use bigbox Amiga (such as 1000/2000/3000/4000 and other monitor than BenQ BL702A/912).
    All adapters should fit all Amigas fine, but in case of A4000 desktop, there is little space between audio and video conns, in that case it is needed to cut small part of the case - I can do for you, just let me know when you intend to buy for A4000 desktop - or choose mini adapter that fits perfect. Cables fit A4000 perfect without any modification as they use 23pin case and 23pin conns. Update: Now there is also a mini adapter that fits perfectly all amigas including A4000D, because it uses 23pin case.
    More info about these adapters/cables and compatible monitors you can find in my original thread here.
    Don't forget to set the monitor settings Pixel Clock between 90-94 for BenQ BL702A, BL912 or BL2205PT and finetune with Phase to have perfect picture without any distortions.
    For help easy setup your BenQ monitor I provide Amiga Floppy Disk ADF with picture showing B/W pattern and instructions for download here.
    * I was asked how those BenQ BL* monitors (in addition to PAL) performs at Dbl* resolutions on AGA. Among all those modes I can recommend using Euro72-Productivity (640x400) or Multiscan-Productivity (640x480) that apart from DblPAL or DblNTSC can fill nearly the whole screen. Moreover Euro72 can be tuned to give perfect clear picture like PAL (see the pattern picture here). Do not forget to load VGAonly monitor before loading other monitors.
    ** Few helpful tips about BenQ BL* monitors from user LjL can be found at the posts here and here.
    *** I had several reports that vga adapters bought from one amiga eshop do not work reliably with BenQ's. This is caused by a bad design of their adapters. I can guarantee my adapters and cables will work fine. I do test every piece I made on the real hardware before shipping.
    **** In addition to supported monitors bellow, the cables work great with OSSC too (as it has vga input) and give you perfect picture. Do not forget to set your ossc H. sample rate to 908 for perfect clear PAL picture.
    (If you intent to use this cables or adapters with GBS 8200 video converter, its not possible because GBS do not accept 15kHz video on VGA input. You have to use a special cable listed on my other thread).
    Monitors tested and found working in 15kHz mode (PAL) with these adapters / cables: (Please report other working monitors here in the thread or by PM to me, thanks!)
    Acer K202HQL (tested by LoneWolf)
    Acer K242HYL
    BenQ BL702A
    (tested by me and many others)
    BenQ BL912 (tested by me and many others)
    BenQ BL2205PT (tested by me. This monitor is widescreen, and also has integrated speakers. Picture fills entire screen and can not be stretched to 4:3 ratio. Wired adapter works fine with A500/A600 and 1200 for bigbox amigas you need buffered adapter.)
    BenQ G2420HD (tested by radiokida. Widescreen display)
    BenQ G922HDL (tested by vladimpaler. Can change aspect to 4:3 on this widescreen display. squareeyes reported this monitor not working, so likely not all revisions are compatible)
    BenQ GL955A (18.5" 16:9 screen, can change aspect to 4:3. Tested by J.T.Kirk)
    BenQ MS510 Digital Projector (Tested by me. Projector shows good picture, but Pixel clock cannot be tuned - some vertical banding appears. Also no overscan is shown.)
    ACER H236HL (tested by 5kb)
    ACER S242HLCbid
    ACER v226hql (tested by Zavuch. Only some revisions may work, recent 2018 model from US reported not working.)
    ASUS VE247 (tested by suave)
    ASUS VE248h (tested by madej)
    ASUS VW227D (tested by ancalimon)
    ASUS VX24A (tested by TeamBlackFox / also compatible for Sync-on-Green)
    DELL 2001FP (tested by nifmus. Please note that not all revisions of this monitor work in 15kHz. On other internet forums they say, that DELL 2001FP made up until June 2005 is working, monitors from September 2005 don't).
    DELL P2314H (tested by powaking)
    DELL SE2717H (tested by alpine9000)
    DELL ST2210 (tested by uigiflip)
    DELL Ultrasharp 2311h (tested by kulichbulich)
    DELL U2311Hb (tested by proch)
    DELL U2410
    DELL U2412M (tested by joftek)
    Epson H416B Digital Projector (tested by PedroZlin)
    Fujitsu B23T-6 (tested by PedroZlin. Widescreen display. Picture fills entire screen and can not be stretched to 4:3 ratio. 15kHz capability stated even in users manual.)
    GeChic 1303H (tested by vladimpaler)
    LG Flatron M1721A (tested by Madowax686). Only late 2006 and early 2007 EU models work. (They got rgb-dtv choice in inputs menu).
    Magnavox 17MD255/17 (tested by boratintheuk)
    NEC 1970NXp (tested by doboy. Wired adapter works fine with A500/A600 and 1200 for bigbox amigas you need buffered adapter.)
    NEC Accusync 71V (Wired adapter works fine with A500/A600 and 1200 for bigbox amigas you need buffered adapter.)
    NEC MultiSync EA190M (tested by mattsoft. This monitor also features built-in speakers)
    NEC MultiSync EA192M (tested by me. This monitor also features built-in speakers)
    NEC MultiSync EA241WM (tested by MikeroChip)
    Panasonic TH-42PWD6UY Widescreen Professional 42" Plasma Display (tested by Kremlar with buffered cable)
    Planar 1520M (tested by eslapion)
    Waitec Shining 181T (does sync to 15khz but picture is a bit off center to the right and on-screen position settings cannot completely compensate)
    According to various internet sources it seems that these monitors also work in 15kHz:
    ACER G206HQL
    ASUS 24" LED FreeSync VG245Q, Asus 27" LED FreeSync VG275Q
    BenQ G610HDPL, BenQ VW2430H
    DELL U2211H, DELL U2711, DELL U2913wm, DELL SE2717H, DELL SR2320L, DELL ST2320L, DELL ST2420L, DELL SR2320L, DELL ST2410
    NEC 1550M
    LG 1921A2, LG 22LS4R, LG 19LS4R, LG M228WA, LG M198WA
    For reference 15kHz incompatible monitors listed here.
    Payment by Paypal (gift or if needed to pay for goods add 6% for fees) or SEPA BankTransfer. Prices (excluding shipping):
    Options:
    1/ Adapter (metal coated case and 23pin conn) - 13 €
    2/ Adapter (metal coated case and 23pin conn with buffered Sync like Commodore VGA Adapter) - 15 €
    3/ Adapter (metal coated case and 23pin conn with H/V or C-Sync Switch) - 16 € (Why you might need C-Sync? Check this)
    4/ Cable (23pin conn and plastic case) - 16,5 €
    5/ Cable (23pin conn and metal coated case) - 17 €
    6/ Cable (23pin conn and metal coated case with buffered Sync like Commodore VGA Adapter) - 22,5 €
    7/ Cable (23pin conn and metal coated case with H/V or C-Sync Switch) - 21 €
    NEW: 8/ Adapter Mini (23pin conn & case for perfect fit with every amiga including A4000D) - 15,5 € (plastic gray case), 16,5 € (silver metal coated case), option +2 € (for buffered version)
    I emphasize on best possible build quality. All ground wires connected, shielding, cable wires well fixated for best durability. Cables feature ferrite beads.
    UPDATE:
    Adapters (except mini-adapter) can be in black color too. If you want black one, notice it by PM.
    Cables can be in white color too. If you want white one, notice it by PM.
    For Apple IIGS and BenQ BL702A or BL912 owners I now offer RGB-VGA adapters too. Price is 12€.
    For other cables / adapters check my thread here.
    EU shipping costs (registered priority delivery w. tracking):
    for 1 adapter: 4,5 €, 2 adapters: 5,5 €, 3 or more adapters: 7 €
    for 1 cable: 7 €, 2-3 cables: 9 €
    overseas shipping costs are +2 €
    - cheaper ordinary untracked shipping also possible if needed (ask by PM)
ID:	98625Click image for larger version.
ID:	98626Click image for larger version.
ID:	100932Click image for larger version.
ID:	119510Click image for larger version.
ID:	123750Click image for larger version.
    and few photos how good is the image on BenQ BL702A monitor (click to enlarge):
    Last edited by a.mi.goun; 7th February 2019 at 17:02. Reason: More working monitors added to the list.
  2. #2
    Flash951's Avatar
    Dec 2014
    Norway
    Lier
    Age
    43
    2 (100%)
    How much is shipping to Norway?
  3. #3
    uunek's Avatar
    Feb 2011
    Czech Republic
    Trebic
    56 (100%)
    Declare interest. PM sent.
  4. #4
    Pgovotsos's Avatar
    Nov 2015
    United States
    WV
    60 (100%)
    Interested in buffered/sync adapter but with questions.
    How much would shipping to the US be? Do you have a discount for multiple units purchased?
    Could you build one like PreVue Technology's Sync Strainer? I don't know if there's enough information here to build one. I could probably lend one to you to study.
    http://amiga.resource.cx/exp/syncstrainer
    http://www.bigbookofamigahardware.co...t.aspx?id=1639
  5. #5
    everblue's Avatar
    Dec 2008
    MALTA
    51 (100%)
    Interested in 1 x cable unit, shipped to Malta. Thanks!
  6. #6
    a.mi.goun's Avatar
    Jan 2012
    Czech Republic
    Prague
    404 (100%)
    All PM's hopefully sent.
  7. #7
    konpat's Avatar
    Apr 2015
    Fthiotida
    Age
    46
    18 (100%)
    interested in:
    1xAdapter metal case and real 23pin con + inverted sync like real Commodore VGA Adapter
    1xCable real 23pin con and case
  8. #8
    Gouky's Avatar
    Oct 2011
    Edinburgh
    54 (100%)
    Blog Entries
    1
    interested in one for use with my A4000, sending pm
  9. #9
    konpat's Avatar
    Apr 2015
    Fthiotida
    Age
    46
    18 (100%)
    Payment sent!
  10. #10
    a.mi.goun's Avatar
    Jan 2012
    Czech Republic
    Prague
    404 (100%)
    Payment received from Gouky and konpat - thank you, I will send your items ASAP.
  1. For Sale Useful Amiga Cables & Adapters
    By a.mi.goun in forum Amiga
    Last Post: Yesterday, 19:10
  2. For Sale Amiga Video - SCART Cables DELUXE (real 23pin conns)
    Last Post: 14th February 2019, 11:27
  3. For Sale video cables/adapters
    By skromny in forum Other
    Last Post: 18th October 2015, 19:34
  4. Sold Boxed Deluxe Paint IV & AGA and Real 3D
    By flip in forum Sales Archive
    Last Post: 28th August 2011, 10:27
  5. Closed Amiga RGB to S-Video adapters
    By scole in forum Sales Archive
    Last Post: 8th November 2010, 08:21
Tags for this Thread
