For Sale Amiga VIDEO - VGA Adapters & Cables DELUXE
a.mi.goun
Czech Republic
Prague
NEWEST UPDATE: Adapter with RGB Amplifier (sometimes called VLR) now available (thanks to internal filtering of the AMP it helps to eliminate vertical lines that appear on some monitors such as DELL).
I have for sale Amiga Video - VGA Adapters and Cables Deluxe. I call them "DELUXE" because the Adapters feature original dsub 23pin connectors and metal coated hoods. The Cables use original dsub 23pin connectors and original db23pin hoods.
I offer also buffered Adapters built with the exact same components as Commodore VGA Adapters. Generaly you need buffered adapter/cable only in case you use bigbox Amiga (such as 1000/2000/3000/4000). Please note that for BenQ BL912 and BL702A buffered sync is not needed and these monitors accept unmodified Amiga sync perfectly.
All adapters should fit all Amigas fine, but in case of A4000 desktop, there is little space between audio and video connectors, in that case it is needed to cut small part of the case - I can do for you, just let me know when you intend to buy for A4000 desktop. Cables fit A4000 perfectly without any modification as they use original db23pin hoods.
More info about these adapters/cables and compatible monitors you can also find in my original thread here.
Don't forget to set the monitor settings Pixel Clock between 90-94 for BenQ BL702A, BL912 or BL2205PT and finetune with Phase to have perfect picture without any distortions.
For help easy setup your BenQ monitor load Workbench open WBPattern prefs and choose Checkerboard pattern. Tweak the picture with pixel clock abd phase controls until white and black rectangles look equal without waves on the screen.
* I was asked how those BenQ BL* monitors (in addition to PAL) performs at Dbl* resolutions on AGA. Among all those modes I can recommend using Euro72-Productivity (640x400) or Multiscan-Productivity (640x480) that apart from DblPAL or DblNTSC can fill nearly the whole screen. Moreover Euro72 can be tuned to give perfect clear picture like PAL (see the pattern picture here). Do not forget to load VGAonly monitor before loading other monitors.
** Few helpful tips (for example how to disable resolution notice) about BenQ BL* monitors from user LjL can be found at the posts here and here.
*** I had several reports that vga adapters bought from one amiga eshop do not work reliably with BenQ's. This is caused by a bad design of their adapters. I can guarantee my adapters and cables will work fine. I do test every piece I made on the real hardware before shipping.
**** In addition to supported monitors bellow, the cables/adapters can be used with OSSC too (I recommend buffered for OSSC). I also recommend using SCART cables with OSSC, because OSSC has some filtering present on Scart input. I offer Deluxe Scart cables in my thread here. Do not forget to set your OSSC H. sample rate to 908 for perfect clear PAL picture (in Line2x mode).
(If you intend to use these adapters or cables with GBS 8200 video converter, its possible with the sync switch option. Adapter or cable with sync switch will work with both 15kHz monitors (HV sync) and GBS8200 converter (C-Sync). Useful for BenQ too - check this)
You can find other useful cables or adapters listed on my other thread).
Monitors tested and found working in 15kHz mode (PAL) with these adapters / cables: (Please report other working monitors here in the thread or by PM to me, thanks!)
ACER G206HQL (reported 15kHz working on other site(s))
ACER G226HQL (reported 15kHz working on other site(s))
ACER G276HL (reported 15kHz working on other site(s))
ACER H236HL (tested by 5kb)
ACER K202HQL (tested by LoneWolf)
ACER K242HYL(reported 15kHz working on other site(s))
ACER S242HLCbid (reported 15kHz working on other site(s))
ACER V193 (reported 15kHz working on other site(s))
ACER v226hql (tested by Zavuch. Only some revisions may work, recent 2018 model from US reported not working.)
AOC 24G2U
ASUS PA248QV (reported 15kHz working on other site(s))
ASUS PB248Q (reported 15kHz working on other site(s))
ASUS VE247 (tested by suave)
ASUS VE248h (tested by madej)
ASUS VG245Q (24" LED FreeSync, reported 15kHz working on other site(s))
ASUS VG275Q (27" LED FreeSync, reported 15kHz working on other site(s))
ASUS VW227D (tested by ancalimon)
ASUS VX24A (tested by TeamBlackFox / also compatible for Sync-on-Green)
ASUS VZ249HE (reported 15kHz working on other site(s))
BenQ BL702A (tested by me and many others)
BenQ BL912 (tested by me and many others)
BenQ BL2205PT (tested by me. This monitor is widescreen, and also has integrated speakers. Picture fills entire screen and can not be stretched to 4:3 ratio. Wired adapter works fine with A500/A600 and 1200 for bigbox amigas you need buffered adapter.)
BenQ G2420HD (tested by radiokida. Widescreen display)
BenQ G610HDPL (reported 15kHz working on other site(s))
BenQ G922HDL (tested by vladimpaler. Can change aspect to 4:3 on this widescreen display. squareeyes reported this monitor not working, so likely not all revisions are compatible)
BENQ GL2023 (19,5" 16:9 screen)
BenQ GL955A (18.5" 16:9 screen, can change aspect to 4:3. Tested by J.T.Kirk)
BenQ MS510 Digital Projector (Tested by me. Projector shows good picture, but Pixel clock cannot be tuned - some vertical banding appears. Also no overscan is shown.)
BenQ VW2430H (reported 15kHz working on other site(s))
DELL 2001FP (tested by nifmus. Please note that not all revisions of this monitor work in 15kHz. On other internet forums they say, that DELL 2001FP made up until June 2005 is working, monitors from September 2005 don't).
DELL 2414H (tested by Storm. Works well, aspect ratio can be changed.)
DELL P2214H (tested by acer)
DELL P2214Hb Rev A01, Manufactured March 2014 (tested by ath768.)
DELL P2314H (tested by powaking)
DELL SE2717H (tested by alpine9000)
DELL SE2722H (tested by me, recommended to use adapter or cable with RGB amplifier)
DELL SR2320L (reported 15kHz working on other site(s))
DELL ST2210 (tested by uigiflip)
DELL ST2320L (reported 15kHz working on other site(s))
DELL ST2410 (reported 15kHz working on other site(s))
DELL ST2420L (reported 15kHz working on other site(s))
DELL Ultrasharp 2311h (tested by kulichbulich)
DELL U2211H (reported 15kHz working on other site(s))
DELL U2311Hb (tested by proch)
DELL U2410 (tested by many users)
DELL U2412M (tested by joftek)
DELL U2711 (reported 15kHz working on other site(s))
DELL U2913wm (reported 15kHz working on other site(s))
Epson H416B Digital Projector (tested by PedroZlin)
Fujitsu B23T-6 (tested by PedroZlin. Widescreen display. Picture fills entire screen and can not be stretched to 4:3 ratio. 15kHz capability stated even in users manual.)
GeChic 1303H (tested by vladimpaler)
iiyama ProLite X2474HS (reported 15kHz working on other site)
Lenovo Q24i-10 (reported 15kHz working on other site)
Lenovo Q24i-1L (reported 15kHz working on other site)
LENOVO ThinkVision T22i (tested by Dr_Pyst)
LENOVO ThinkVision T2324p (reported 15kHz working on other site)
LG 1921A2 (reported 15kHz working on other site)
LG 19LS4R (reported 15kHz working on other site)
LG 22LS4R (reported 15kHz working on other site)
LG Flatron M1721A (tested by Madowax686). Only late 2006 and early 2007 EU models work. (They got rgb-dtv choice in inputs menu).
LG M198WA (reported 15kHz working on other site)
LG M228WA (reported 15kHz working on other site)
Magnavox 17MD255/17 (tested by boratintheuk)
NEC 1550M (reported 15kHz working on other site(s))
NEC 1970GX (reported 15kHz working on other site(s))
NEC 1970NXp (tested by doboy. Wired adapter works fine with A500/A600 and 1200 for bigbox amigas you need buffered adapter.)
NEC Accusync 71V (Wired adapter works fine with A500/A600 and 1200 for bigbox amigas you need buffered adapter.)
NEC MultiSync EA190M (tested by mattsoft. This monitor also features built-in speakers). Only some revision may work.
NEC MultiSync EA192M (tested by me. This monitor also features built-in speakers). Only some revision may work.
NEC MultiSync EA241WM (tested by MikeroChip)
Panasonic TH-42PWD6UY Widescreen Professional 42" Plasma Display (tested by Kremlar with buffered cable)
Planar 1520M (tested by eslapion)
Waitec Shining 181T (does sync to 15khz but picture is a bit off center to the right and on-screen position settings cannot completely compensate)
Viewsonic VA2732-H (tested by me)
For reference some 15kHz incompatible monitors listed here.
Payment by Paypal (gift or if needed to pay for goods add 6% for fees) or SEPA BankTransfer. Prices (excluding shipping):
Options:
1/ Adapter standard - 15 €, Adapter buffered - 17,5 €, Adapter with Sync Switch - 17,5 €, Adapter with RGB amp. buffered (VLR - Vertical Line Remover) - 24 €
2/ Cable standard - 19 €, Cable buffered - 24 €, Cable with Sync Switch - 23 €
3/ Cable Amiga RGB-BNC (for connecting to SONY PVM monitors with BNC connectors, high-quality branded OFC cable used) - 29,50 €
NEW2: For cables I can also supply heavy duty hi-quality 8mm robust cables, OFC conductors and gold plated vga connector with huge ferrite (interference) filters for extra 4 €. Optionaly black amiga connector cover/hood is for extra 3 €.
NEW3: For cables I can also supply luxury Home Theatre branded High Quality cables for demanding users with metal and gold plated vga connectors, oxygen free copper conductors and huge ferrite (interference) filters for extra 11 €.
NEW4: For Sync switch cables (adapters) I now use the resistor on C-Sync as recommended for GBS8200.
NEW5: For Amiga CD32 with FWSI Floppy expansion board I have now RGB-VGA Adapter available too. Price is 11 €.
I emphasize on best possible build quality. All ground wires connected, shielding, cable wires well fixated for best durability. Cables feature ferrite beads.
UPDATE:
Adapters can be black color too.
If you want black one, notice it by PM.
Cables can be white color too. If you want white one, notice it by PM.
For Apple IIGS and BenQ BL702A or BL912 owners I now offer RGB-VGA adapter too. Price is 12€.
For other cables / adapters check my thread here.
_avga_adapter_23.jpgavga_adapter_black.jpgavga-cable-dell.jpgavga-cable-hiq-gold.jpgrgb-vga-cable-deluxe-ht.jpgrgb-vga-cable-deluxe-hq-ht.jpgargb-bnc-cable-1.jpg
and few photos how good is the image on BenQ BL702A monitor (click to enlarge):
interested in:
1xAdapter metal case and real 23pin con + inverted sync like real Commodore VGA Adapter
1xCable real 23pin con and case
Interested in Adapter (metal case and real 23pin con + inverted sync like real Commodore VGA Adapter), PM on the way
Adapter sent for Gouky, others will follow tommorow.
@Pgovotsos: Before sending please send me PM how the IC's are labeled.
@1NOM155: PM sent.
@everblue: Payment received, your Cable will be shipped tommorow.
Interested, how much would shipping to Italy cost? Thanks.
@1NOM155: PM sent.
Hello a.mi.goun,
Payment made for Adapter (metal case and real 23pin con + inverted sync like real Commodore VGA Adapter) - 15 €
