hi, help!
"indiana jones and the search for the NTSC Crystal for apple" or similar here.
my apple ii needs a new crystal, but I cannot for the life of me find a supplier in uk or in europe for the right part. Anyone who knows where to find this particular component, please could they help! Its NTSC hence needs to be the right freq. 14.31818 MHZ and has to be a series resonant part.
its a particular part apparently - some crystals work but the apple only then outputs monochrome. I have bought some off ebay and the apple works perfectly, the display is rock solid but dammit, no color, just B&W. I need the right type and part.
14.31818 MHZ
series resonant
2 pin/ through hole type
i quote from an apple ii site:
It is 14.31818 MHZ. However not all 14.31818 MHZ crystals are the same. You need a series resonant crystal. Even then, not all series resonant crystals will generate the correct frequency in an Apple II circuit. For an Apple II to generate correct color burst, the only part that I have found that consistently works is Vishay/Dale part number XT9UNLANA14M31818. This is available from Mouser (part number 73-XT49U1431-S)."
Mouser list the 73-XT49U1431-S as obselete and its out of stock. ebay wont turn it up and i may be searching element14 wrongly..
apparently CMAC HC49 part works, but I cant find that either.
please help!
cheers all, iain
