Acill
If you have an Amiga and have never had the caps replaced it needs to be done! I can also upgrade SIMM sockets, replace chips, repair soldering done by others that didnt know what they were doing, trace repairs, upgrade pin headers and hard drive headers, desolder modulators and more. If you have something that needs to be done just ask. I can also do consoles and other computers if required.
ONLINE STORE: http://www.acill.com
1. Parts supplied by you are not guaranteed but I will use them if you request it.
2. Shipping is your responsibility both ways, use a prepaid label for return included in the box you send would be an easy solution.
3. Prices will be competitive with others, doing this to help you, not rip you off. I do need to cover the cost of the materials and my equipment though keep in mind.
4. The job will done right and clean, but its still at your risk. Miracles cant be worked on a bad board if they are eaten up from corrosive electrolytic leakage. Every effort will be made to repair however.
I am in Southern California near the LA area. You can send a PM to me here and I will let you know if the job can be done or not. I can test boards I repair in most cases if I have the ability to get power to the board you send and bench test it. As times goes on I plan to get a few rigs made up depending on how often I get work. Amiga gear is not cheap and I cant go out and just buy kit I may never use more than once or twice.
