Hi!
I think it's time to let go my second V6Z80P. It's a 1.0 version, but upgraded professionally by Phil Ruston to the latest version of the board. Includes the Pendulum add on board to run the latest cores, cycle perfect from Alessandro Dorigatti. It's working perfectly and includes a plastic case and a SD Card with all the needed software to plug & play
You can get it run with any power adaptor from 7,5V to 9V.
Tape simulator, scanlines, ESXDos, ULA+, cycle perfect ZX Spectrum 128k and 48k, PS/2 keyboard and mouse inputs.
Updated to the latest version of firmware and software.
Here some pictures:
The case has a hole for the power switch upper than it's real location, (as you can see in the right side in picture 2) but I've never used it, as I always keep the power switch in the on position, and turn off the V6 when unplug the power supply.
Price: 110€ + P&P. (EU only) (Paypal as gift or bank transfer).
Regards.
You can read more info at: http://www.retroleum.co.uk/electronics-articles/v6z80p/
Some information of the V6Z80P board:
Here some pictures:
Regards.
- 1 x MMC/SD/SDHC card slot (OS supports FAT16 file system)
- 2 x Joystick ports (Atari-standard, the original Megadrive pads are compatible too)
- 1 x PS/2 Keyboard Port (PC standard)
- 1 x PS/2 Mouse Port (PC standard)
- 1 x Serial Comms Port (4 pin mini-DIN: RX,TX,GND) – A PC compatible null modem adapter cable is supplied.
- 1 x RGB VGA video port (SCART RGB TV adapter cable supplied for TV-out)
- 1 x 3.5″ Stereo out socket
- 1 x 2.1mm DC power jack socket (7.5 or 9 volt mains adapter capable of supplying around 800mA is required)
- PCB dimensions: 116mm x 123mm.
