Results 1 to 2 of 2
Thread: Amiga 1200 2B Mainboard - Data bus high
  1. #1
    highpuff's Avatar
    Oct 2012
    Sweden
    Västra Götaland
    113 (100%)
    Default Amiga 1200 2B Mainboard - Data bus high
    Got an issue here that is harder than I expected to fix. The problem is that after a while, depending if the PCB is cool or not, all data bus'es gets high after a while. No picture is ever displayed.
    Things to know:
    - The PWR-led stays dimmed.
    - This happened when the owner tried to upgrade from 3.0 to 3.1.
    - I'm using the Dialoga 2.0 ROM's that I verified a few times during my tests that they work.
    - The Caps button works a few pushes then stays off/on.
    I have done the following:
    - All clocks are checked and has the correct frequencies
    - Checked all traces from U6A and U6B
    - Checked for shorts
    - Removed both U7 and U8 (CIA A-B)
    - Removed the 68EC020 CPU and used a working Blizzard 1220
    Any ideas? I cannot see any damage at the ROM sockets but will remove them tomorrow and see if there is something there. Maybe I will try to replace the MPU as well.
    For a short period of time I was suspecting that it could not read from from the ROM's. The exact same behaviour occurs when I remove U6A or both of the ROM's and power on the Amiga.
    Thanks in advance
  2. #2
    Ministry of Retr0bright and Street Judge VIP
    Amibayer!
    Merlin's Avatar
    Nov 2007
    Manchester
    57
    38 (100%)
    Thread moved to AmiOracle as a more suitable place to get a response.
    The future's so Retr0bright, I gotta wear shades.....
    As rkauer said:-
    "Retro computers seems like an orgasm: it is always better to have a real one than fake it".
  1. For Sale CD-Rom for Amiga 600 / 1200 - Alfa Data CD1200-Plus
    By Kunglao in forum Amiga
    Last Post: 3rd May 2016, 16:18
  2. Replies: 3
    Last Post: 25th June 2014, 07:23
  3. Replies: 7
    Last Post: 31st August 2013, 09:37
  4. Closed High Density Floppy Drive Amiga 1200 3000 600 HD FDD Micronik
    By SilkWorm in forum Sales Archive
    Last Post: 3rd July 2010, 08:31
  5. Closed High Density Floppy Drive Amiga 1200 600 A1200 A600 HD FDD Sony
    Last Post: 3rd July 2010, 08:26
