Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Using a SCSI2SD V6 board...
  1. #1
    Inactive Member britlord's Avatar
    May 2013
    usa
    Michigan
    45 (98%)
    Default Using a SCSI2SD V6 board...
    Hi.All.. I've just received a SCSI2SD V6 board (To use in my A2000) But I have notice that there's no SCSI ID jumper header on the board.. Will that be a problem getting it to work, as I like the idea of using a mini SD card to use as a hard-drive (No noise). I have already partitioned, and installed ClassicWB onto the card (in Winuae), so it's ready to go (32GB)...
    If anyone has any info using this board in an Amiga. Please let me know..
    Thanks..
  2. #2
    comraider's Avatar
    Mar 2014
    United States
    California
    33 (100%)
    There's a GUI based utility that configures your SCSI2SD and lets you set SCSI IDs. Infact you can logically partition the SD card and expose multiple devices if you want!
    http://www.codesrc.com/mediawiki/ind..._Configuration
  3. #3
    joethezombie's Avatar
    Sep 2015
    United States
    Idaho
    2 (100%)
    Also note that the firmware just left beta for the v6 boards, with an update on Aug 14 that fixes some pretty severe problems. You'll want to make sure to update the firmware to the latest. I had a bit of an issue doing this, and had to force the board into update mode with a shunt on BOOTLDR. I also couldn't get my Mac to update the firmware using the utility, and had to resort to DfuSe on Windows. Good luck.
  4. #4
    eslapion's Avatar
    Jul 2015
    Canada
    Quebec
    100 (100%)
    I checked the Wiki and it doesn't say if this neat device will work ok with CMD HD drives or good ole' Windows 95/98 PCs with Adaptec AHA-2940 SCSI controllers.
  5. #5
    May 2013
    usa
    Michigan
    45 (98%)
    [QUOTE=joethezombie;794502]Also note that the firmware just left beta for the v6 boards, with an update on Aug 14 that fixes some pretty severe problems. You'll want to make sure to update the firmware to the latest. I had a bit of an issue doing this, and had to force the board into update mode with a shunt on BOOTLDR. I also couldn't get my Mac to update the firmware using the utility, and had to resort to DfuSe on Windows. Good luck.[/QUOTE
    Ok. But how do I update the firmware, as I do have STMicroelectronics DfuSe for windows (What is needed)
    Quote Originally Posted by eslapion View Post
    Its going on a Oktagon 2008...
  6. #6
    Inactive Member rootboy's Avatar
    Apr 2014
    United States
    Tennessee
    39 (100%)
    I went through a bit of pain getting mine set up in my 2000. Michael, the creator of the SCSI2SD was a huge help. This was the advice that he gave to me:
    "Try 15 heads, 63 blocks per cylinder (I think this is the same as 'sectors per track) and 8876 cylinders. This is a little less than 4gb, and the sector count in scsi2sd-util should be updated to match (15 * 63 * 8876).There is an option in scsi2sd-util to save the config to an XML file. This file has additional settings for heads and sectors per track which aren't in the gui. You can change the defaults (15, 63) then load the XML file back into scsi2sd-util and save to the device."
    That worked once I downgraded from a 16G SD card to a 4G SD card.
    Edit: I see that he has made some fixes to the "SD
    card compatibility issues", maybe it will handle a 16G card now.
    As for updating the firmware:
    http://www.codesrc.com/files/scsi2sd/latest/
    No special hardware is needed, just a USB cable if I recall correctly.
  7. #7
    Sep 2015
    United States
    Idaho
    2 (100%)
    CAREFUL! Rootboy linked to files for version 5 of the board. You have a version 6, so don't use that firmware!
    As far as updating the firmware, it depends on what firmware came with your card. If you have one of the early betas, you'll probably need to use DfuSe.
    The files for v6 boards are here:
    http://www.codesrc.com/files/scsi2sd-v6/latest/
    Load up the util6 for your OS, and then plug the card in with the USB cable. It should report what version of firmware. You can download the firmware.dfu file from the previous link and attempt to use the built-in updater from the util6 utility to upgrade. If it fails, let me know and we can work through the manual update using DfuSe.
  8. #8
    May 2013
    usa
    Michigan
    45 (98%)
    Quote Originally Posted by rootboy View Post
    Ok Thanks so much. Though should I stay with the good old 33GB SCSI hard-drive..
    Oh Do I need a programmer or not...
  9. #9
    comraider's Avatar
    Mar 2014
    United States
    California
    33 (100%)
    Nope no need for a programmer, the SCSI2SD board has a micro usb port, so just connect it to your PC like you would a smartphone.
  10. #10
    May 2013
    usa
    Michigan
    45 (98%)
    Quote Originally Posted by comraider View Post
    Ok Thanks.
  1. Replies: 14
    Last Post: 21st May 2016, 01:24
  2. Simple solution for mounting a scsi2sd in an A2000
    By vtwinsuzuki in forum Photo Booth
    Last Post: 12th April 2016, 11:20
Tags for this Thread
