Page 1 of 17 1234511 ... LastLast
Results 1 to 10 of 165
Thread: C128 CGA to RGB adapter
  1. #1
    Pyrofer's Avatar
    Apr 2015
    London
    Age
    45
    9 (100%)
    Default C128 CGA to RGB adapter
    Update - Please place all purchases through my webshop at,
    http://www.pyrofersprojects.com/blog/shop
    I will leave this thread open for now so people can ask questions about the device/installation etc and share their installation photos. There should probably be a proper place for that and any suggestions are welcome as to where!
    I have been making and selling these in small numbers. I just improved my PCB and wanted to judge interest in how many more I could sell.
    Details,
    All Digital processing stage using a programmable logic chip (GAL). This means that there is no loss of quality by mixing signals, also the brown fix is done in logic providing the correct output of brown and yellow instead of 2 yellows.
    6bit DAC output. Each of the output channels, R,G,B is output as 2bits and goes into 2 resistors. There is no "Pull up" or "Pull down" mixing the intensity signal across channels. It's a simple 6bit RGB DAC for the best quality no bleed picture.
    Correctly mixed Composite sync. A very reliable sync signal by using the 'correct' logic for mixing H and V sync inputs.
    9pin CGA plug onboard. Simply plug it directly into the back of the C128, no 9pin cable needed.
    15pin RGB output onboard. It uses a VGA style connector so monitors that support 15khz can plug directly in to it. So called "CGA to VGA" adapters like the Gonbes board also have an input that uses the VGA connector, Somebody tested this and the adapter works fine with the gonbes and a straight VGA cable. The standard VGA pinout is used with composite sync on H sync pin. Pin 9 carries 5v for use in SCART (euro) connector cables that trigger the fast blanking pin to put the display into RGB mode.
    S-Video connector onboard. The signals from the VIC can be passed through this board via a pin header to allow the use of standard S-Video cables.
    3.5mm Audio Jack onboard. As with the VIC video signals the audio signal can be accessed easily with a stanard 3.5mm jack.
    6pin header for VIC DIN connector (not supplied). As the board needs 5v and the 128 supplies 5v via the video DIN output I put a 6 pin header on with inputs for, Ground, 5v, Audio, Composite (not connected), Chroma and Luma (Fed to the S-Vid connector). This allows for a very neat installation with this board plugged directly into the 128 and a single cable to the video DIN plug for all other signals. Output is then out via the VGA plug and S-Video plug for 80 and 40 columns.
    I can't overstate the difference of using a logic system to convert the 4bit input to 6bit output. The high speed GAL used produces an amazing quality output that you really have to see and compare to a lot of other DIY solutions to understand.
ID:	112563Click image for larger version.
ID:	112564Click image for larger version.
ID:	112583Click image for larger version.
    1) The adapter 2)My testcard image 3)how it connects 4) a customer running it through a gonbes adapter.
    The price is £30+post. I have been posting internationally but currently have no stock as I hand assemble them. Please register your interest here.
    UPDATE - Price is £40+post due to an increase in parts costs and assembly difficulty - Apologies for this.
    *The din cable shown cannot be provided as I don't have a source for the plugs. It is up to the buyer to provide a connection between the video out and the pin header. To use 80 col only you simply need 5v on pin2 which can come from the user/tape or video ports.
    Tested direct to a SCART TV, working fine.
    Tested direct to a gonbes VGA adapter (using a normal VGA cable) and works fine.
    Tested with a cheap SCART to HDMI adapter from eBay, works fine.
    Should in theory work with any normal RGB monitor such as used on Amiga.
  2. #2
    Keeper of the Valiant Turtles. Amibayer! thecellartroll's Avatar
    Aug 2011
    Scotland
    Edinburgh
    36 (100%)
    Sweet. Interest declared.
    Commodore VIC20 & SD2IEC, 64x5 & Chameleon, 64Cx4, C128, Plus4 & SIDcard C16, C16@64K, Sinclair Spectrum+ 128K & divIDE2k11 +2 +3 ZX81 &ZonX, Amstrad CPC 464x2 6128x2 6128+, Acorn RiscPC 600 (StrongARM + 586), Electronx3, +1, +3, BBC Master128 + MMC & Valiant Turtle, C64 DTV, Atari 800XL.
  3. #3
    freaktmp's Avatar
    Aug 2012
    Patra
    Age
    42
    60 (98%)
  4. #4
    frakswe's Avatar
    Sep 2016
    Sweden
    Skåne
    Age
    40
    1 (100%)
    Yes,sign me up for one.
  5. #5
    We Will Never Forget.. Amibayer!
    Staff Moderator
    ChrisUnionNJ's Avatar
    Jun 2010
    Union,NJ
    Age
    56
    79 (100%)
    in one please..
    Never Bin or sell your old computer's you will regret it!!
    Vic 20 x3,C64 x2,128D,C128 flat deck,A1000 x2,A500 x3,A2000,A600,A1200,Apple ][e,2x Apple][ GS rom 01,03,Apple ][c x4 with only 1 PSU,2x Laser 128EX EX2,Atari 600XL,2x 800XL,130XE w/320 mod With a MyIDE plus,Atari 1040stf w/2.5meg..
  6. #6
    (Not actually from Tokyo). VIP
    Amibayer!
    tokyoracer's Avatar
    Jun 2008
    Age
    29
    169 (100%)
    Count me in, though could be a month or so before I can afford it so only accept me of that's okay with you!
  7. #7
    Amibayer! storhemulen's Avatar
    Sep 2010
    Sweden
    Gothenburg
    Age
    46
    45 (100%)
    One for me, please!
  8. #8
    kerkyra2007's Avatar
    Aug 2012
    Athens/Glyfada
    43 (100%)
    Interested in one also
  9. #9
    Mega AmiMod
    Staff Moderator
    keropi's Avatar
    Dec 2007
    Ioannina
    Age
    39
    142 (100%)
    this would work with a CGA signal from a PC right? It is the better equivalent of this, correct?
    I have built the one above and it works fine with pc/cga , if the adapter on sale is also the same function-wise I'd like one as well
    Aacheron and slk486 are my heroes
    A1200D mfilos ed. : ACA 1231/42 , Indivision MK2 , IDEfix Express , Subway , PicoPSU 120w custom 3.9 ROM/OS
  10. #10
    Pyrofer's Avatar
    Apr 2015
    London
    Age
    45
    9 (100%)
    Yes, it's a similar function to that circuit but done with a true 2 bit per colour output for the DAC for a better picture.
    It takes RGBIHV in and does RGBs out. I see no reason it wouldn't work with PC CGA cards.
    I would love to see somebody using it on an original CGA card on their PC photos must be provided !
  1. For Sale C128 CGA to RGB adapter - Custom case now available
    By COREi64 in forum Commodore
    Last Post: 8th May 2017, 06:04
  2. Replies: 1
    Last Post: 20th April 2016, 08:37
  3. C128 PSU Advice - Suitable 9vAC 1a Adapter
    By wmsteele in forum AmiOracle
    Last Post: 26th September 2014, 13:23
  4. Sold C128 RGBi to RGB adapter
    By unholy in forum Sales Archive
    Last Post: 19th March 2014, 15:01
  5. Closed Working C128 or only C128 PSU
    By Sallinen in forum Found Archive
    Last Post: 31st October 2012, 00:50
Tags for this Thread
