For sale many pieces Expansion Port Adapters for Commodore C64 machines, both breadbin and C64C. Originally designed for Easyflash3 cartridges, but you can use with any cards! It can change machine's the expansion port degree with 90º, or with other words: it can be angled the expansion port! The final pcb's color are black with white labels, as always. At the right side it has an OMRON momentary button which is a built-in reset for the C64. This way you can do a hard-reset with no card inserted (or inserted of course) and also no need to drill your original commodore case for ugly reset buttons. The other side contains a power led (color: warm white) which can be brightnessed with the trimmer potentiometer.
Expansion port adapter working well with 1541 Ultimate II+ and Easyflash3! Tested, 100%!
Panel assembled with high quality EDAC connector, OMRON momentary press button, tantalum electrolytic capacitors, and other quality parts. It has a double brass hexagon standoff underneath to prevent connecting your cartridge and/or pressing the reset switch if attached to your machine. Expansion Port Adapter is compatible with all types of cartridges... (tested also with 1541 Ultimate II+ and Easyflash3)
These pictures are from the actual items from the 2nd batch:
Expansion Port Adapter price: €34 (was €32) (was €29.9) (+shipping)
