Closed FS: SaV64 - Round 4
SkydivinGirl
Retro Girl
Raleigh, NC
Round 4 of SaV64 sales have begun! I have already ordered parts for this round so kits will ship within a week and fully assembled devices will ship right after i am able to get them assembled.
The SaV64 was designed and created in collaboration with e5frog, based on his OVG64 over voltage protector. It uses an over voltage protection controller to allow you to safely use your original Commodore power supply or an alternative power source with your Commodore computers.
User Guide: http://www.hookturn.com/files/SaV64 User Guide.pdf
Here’s the complete list of features:
- Protect your Commodore 64(C/G/GS/Aldi), Commodore MAX, Commodore VIC-20 CR, or Plus/4 (with an adapter) from overvoltage on the 5VDC line.
- 5VDC and 9VAC Barrel connectors to allow easy use of alternative power sources. 5VDC barrel input is also protected from overvoltage.
- Use an external 5VDC power source and continue using your Commodore power supply for 9VAC even when its 5VDC has failed.
- Designed to handle 3 Amps in order to protect and power your system.
- High quality relay that disconnects both DC and AC lines in the case of an overvoltage condition.
- Dual color LED indicating the 5VDC status: Normal (Green) or Tripped (Red)
- Can be reset with the recessed reset button or by unplugging the power source.
- LED indicator shows when voltage is safe or tripped.
- Four possible trip point settings to customize the protection to your system.
- A high quality aluminum enclosure with factory cut openings. The case is quite small at around 2.5 Inches Wide by 2.8 Inches Deep and 1.5 Inches tall.
- 3M Rubber Feet and a professionally printed SaV64 logo are also included to complete the device.
$45.00 – One complete kit. ** Everything you need to assemble one SaV64. I will solder the surface mount components for you if you are not capable of attaching those yourself.
** Kits are guaranteed to have all the parts and they will be shipped in a new box with adequate packing material to protect the parts. I cannot be responsible if a device you assemble does not work. I will work with you to perform troubleshooting and help in any way I can.
$85.00 - One fully assembled and tested device. ***
*** All fully assembled devices now have the output cable coming out of the case on the opposite side from the inputs.
Please send me a PM with your Full Name and Full Shipping Address as well as the number of devices so I can give you an accurate shipping quote. Also let me know if you want fully assembled devices or kits.
Shipping Notice: Each device is about 8 Ounces. Shipping up to three devices to most countries outside the USA will cost around $22.50. Please send me your mailing address via PM along with the number of kits you want so I can get you an accurate shipping quote. Shipping to Canada is less expensive than other International destinations. Shipping up to two devices within the USA is $7.15. If shipping prices change between the time you place your pre-order and the actual shipping date, you will be responsible for the difference.
I also have the C8D Joystick Switcher available for sale. These can be added to your order without additional shipping charges.
www.lemon64.com/forum/viewtopic.php?t=62026
PAYPAL NOTICE: Payment must be made via PayPal Gift/Friends/Family payment.
Please read the following before contacting me to buy:
Please be courteous of my time. If you do not contact me after I take the time to get a shipping quote and send it to you then I will not sell anything to you in the future. All I ask is that you respond, even if the shipping quote is too high or something comes up and you can't afford it.
Thanks!
Heather
Package sent to fuzzybad earlier this week.
Payment received from Terppa.
Heather
Buzzer's SaV64 is shipping today. Terppa's SaV64 is assembled and will ship at the same time as his Final Expansion 3.
I have several SaV64s that are 95% assembled. It's a good time to buy if you are looking for a fully assembled device as the turnaround will be fast. :)
Heather
Please send me a PM with your full name and shipping address then I can send you payment information. (y)
Heather
Hi Heather,
I also noticed that I have to post twice before I can send a PM. Sorry for the delay.
Regards,
Erik ��
