Has anyone successfully used a 64040 to 68060 adaptor on a GVP 4040 TREX-1 accelerator card? Which 68060.library works with it?
I have one that either fails to boot if I have any kind of 68060.library in LIBS:, or the library seems to have no effect and while it boots, it is flaky and slow as if the library isn't present. An exception is the 68060.library found in MMULib. It seems to partially work, but I constantly get recoverable alerts (3F02803E 08031CD0). The machine is also very crash prone with this library.
I have tried it on an A3000 and an A4000, and with three different adaptors and 060s. The adaptors work fine in other 040 cards. Also tried with OS 3.9 and a freshly installed OS 3.1. As an 040 card it works perfectly.
Kickstart has the modified exec to allow use of an 060.
One thing I have noticed is that when used as standard with an 040 processor, this card will only work with the Commodore 68040.library as supplied with 3.1, or the updated version supplied with 3.9. The library provided on the GVP install disk is the same Commodore 3.1 version.
Phase 5 libraries all fail to boot. Same with GVP 060 library as supplied with their 060 accelerators.
Any ideas?
Any ideas?
