Elbox Spider II USB
Zetr0
Ya' Like it Retr0?
Norfolk
Hello my fellow AmiBay'ers
Today I have on offer the Elbox Spider II USB - PCI Adaptor Card
Stock Photo, thanks to Elbox
The Spider II USB 2.0 Hi-Speed PCI card features:
  • Five USB 2.0 Hi-Speed ports: four external and one internal
  • Compatible with both USB 2.0 (480 Mbps) and USB 1.1 (12 Mbps) devices
  • Compliant with EHCI, OHCI and PCI 2.2 standards
  • All ports can handle high-speed, full-speed and low-speed transaction
  • One EHCI (Enhanced Host Controller Interface) and two independent OHCI (Open Host Controller Interface) controllers integrated
  • Supports up to 127 downstream USB devices
  • Supplies 500 mA power to each USB port
  • Supports PCI-Bus Power Management Interface
  • Hot Plug Capability
Compatible Turbo Card Models
  • Spider II USB 2.0 Hi-Speed card is compatible with all USB devices compliant with USB 2.0 standard and with all devices compliant with USB 1.1 standard.
  • The software support for particular USB device is provided by appropriate Poseidon class driver. All USB devices tested with Poseidon stack work with Spider.
  • The complete list of tested models of the USB devices (hubs, keyboards, mice, printers, scanners, ZIPs, HDDs, CDROM drivers and others) will be available in the Spider USB Devices Guide.
*NB
This is in fact a PCI card for the Elbox Mediator PCI - equipped range of Amiga's - It should also be noted that you will need atleast an 030 processor to run this adaptor.
Sadly there is no software bundled with this adaptor, but I am sure a good Google can make some magic happen.
Now all that goodness is your for the princely sum of £25
Postage within the UK is about £5 and about £9 for Europe -
I can also take this up to the Cheltenham meet tonight =)
Thanks for looking
Thanks for your interest guys - just hit me up here and or a PM if you have any questions or queries :)
