Results 1 to 8 of 8
Thread: AT128 -- PC keyboard -> C128D/DCR adapter
  1. #1
    CodeKiller's Avatar
    Dec 2014
    Hungary
    Nógrád
    Age
    34
    5 (100%)
    Default AT128 -- PC keyboard -> C128D/DCR adapter
    AT128 is a PC AT or PS/2 keyboard to Commodore 128D/DCR* adapter.
    Compatible with any speed of keyboard with scan mode 2 as default**. (DIN type can be used with regular DIN->PS/2 adapters)
    *C128DCRs require a wire to be installed for this adapter to work (+5V from C71 to pin4 of the keyboard connector) -- also the adapter may not stay flat but bends up a bit to have space for the PS/2 connector on desk but should connect without problem
    **keyboards with excessive pull-down resistors (rare) may not work but the adapter can be modified to handle them (i can help if needed)
    Disclaimer: Yes, I'm aware the presence of the C=Key adapter, but this project does not use any design or code from that. It's built entirely from scratch.
    Price: 30€
    Shipping: 7€ world wide flat rate
ID:	119205Click image for larger version.
ID:	119204Click image for larger version.
  2. #2
    CodeKiller's Avatar
    Dec 2014
    Hungary
    Nógrád
    Age
    34
    5 (100%)
    price drop: 25€ / piece
    (shipping the same)
  3. #3
    larry9's Avatar
    Nov 2017
    Northamptonshire
    0
    I am interested
  4. #4
    zorro66's Avatar
    Feb 2015
    Germany
    Hessen
    Age
    53
    0
    Just bumped into this piece of hardware. I am interested to buy one.
  5. #5
    CodeKiller's Avatar
    Dec 2014
    Hungary
    Nógrád
    Age
    34
    5 (100%)
    PM sent
  6. #6
    larry9's Avatar
    Nov 2017
    Northamptonshire
    0
    Can confirm that the adaptor does a good job. Mine is working without the extra wire which I had forgot to add until I saw the picture above again tonight.
    I did find that it would not go into the keyboard socket with the screws at the front so I removed them then after plugging the board in screwed them back in from the rear which also attaches the board to the keyboard socket .
  7. #7
    CodeKiller's Avatar
    Dec 2014
    Hungary
    Nógrád
    Age
    34
    5 (100%)
    The wire only needed in DCR (metal cased) computers.
    The screws may be a little bit big, but usually the adapter makes good contact even if the screws are not removed.
    This is the last one of the adapters for sale.
  8. #8
    CodeKiller's Avatar
    Dec 2014
    Hungary
    Nógrád
    Age
    34
    5 (100%)
    Item sold out.
  1. Wanted C128D Keyboard !
    By TheMaster in forum Commodore
    Last Post: 9th August 2017, 02:38
  2. Wanted C128d keyboard
    By daloway in forum Commodore
    Last Post: 8th March 2016, 09:37
  3. Wanted C128D Keyboard
    By Aysel in forum Commodore
    Last Post: 11th October 2015, 20:11
  4. Closed US C128D Keyboard
    By BeLucid in forum Found Archive
    Last Post: 4th December 2014, 11:49
  5. Closed C128D keyboard
    By Kris in forum Sales Archive
    Last Post: 2nd September 2012, 15:06
Tags for this Thread
