Results 1 to 9 of 9
Thread: Help with Cyberstorm Mk1 not working
  1. #1
    tihopop's Avatar
    Feb 2010
    Canada
    Ontario
    28 (100%)
    Default Help with Cyberstorm Mk1 not working
    Hello to all Amibayers,
    I'm sure there are many knowledgeable people in here who can help with my situation. Anyhow, I've purchased Cyberstorm Mk1 060/50 late February from eBay in US. I had it shipped to my PO box right at Canadian Border, and finally went yesterday to pick it up. Item was in the original box, modules were of course disassembled, end everything looked nice except there was yellow smd component (tantalum capacitor apparently) broken off at the corner of the Simm socket (picture attached). So I decided to skip testing whole memory module initially.
    I carefully went over online manual, and did following:
    • Set Mobo jumpers both to EXT (it's Rev B)
    • Removed A3640 spacers as they were to high (otherwise carrier module wouldn't sit correctly inside the socket, would be angled)
    • Enabled IPEND and disabled CBR (no CPU on the mobo, motherboard is rev B).
    • ROM Size set to 2-3 (there is one booth rom installed at 0 location)
    • ROM CNT to 2-3 (one chip installed)
    • CLK jumper was enabled, I tried booting with both ON & OFF
    Motherboard is in excellent condition, recently recapped. I installed necessary libraries using my CF under UAE, so thats out of question. Even if system files (libraries) are not installed I'm assuming Amiga should at least boot, I should be able to enter boot menu (holding two mouse buttons). Even floppy doesn't react, video does turn on however it outputs empty gray picture (using Indivision AGA). I'm only able to do reset via keyboard, that's it. I'm really out of idea at this point of time. I have no reason to distrust seller, as it was advertised as "working pull". I can return it via ebay sellers protection ($700 US), but it is my intention to do whatever to make it work. My A3640 works just fine after being reinstalled. Help would be greatly appreciated. Thanks!!!
ID:	119604Click image for larger version.
  2. #2
    volker's Avatar
    Feb 2016
    Germany
    Nordrhein-Westfalen
    Age
    43
    5 (100%)
    Try to set mobo jumpers to int
  3. #3
    tihopop's Avatar
    Feb 2010
    Canada
    Ontario
    28 (100%)
    No difference. Indivision boots, screen goes to dark grey and nothing happens afterwards. I tried holding mouse buttons for boot menu, nothing. i can only do a reboot via keyboard, nothing else works. Diag roms, should they be enabled or disabled? As per this page:
    http://relay.pp.fi/Amiga/A4000/Cyberstorm/
    I have the jumper on 1-2 set for 060.
    As per manual, "DIAG Enable Pos 1-2 enable DIAGROM Pos 2-3 disable DIAGROM", so no mention of 040/060 CPUs, opposed to the linked page. What is correct setting?
    Also, does actual DRAM Board has to be installed for proper functioning or not, if of course motherboard RAM is installed?
  4. #4
    screemo's Avatar
    Nov 2017
    Denmark
    Zealand, Naestved
    Age
    39
    23 (100%)
    Any change you would sell that borked memory expansion ? - I'm in dire need, so I will try to repair it.
  5. #5
    tihopop's Avatar
    Feb 2010
    Canada
    Ontario
    28 (100%)
    Quote Originally Posted by screemo View Post
    It wasn't broken, it was unfortunate combination of improper jumper settings combined with Bigram+ which isn't compatible with the Mk1.
  6. #6
    screemo's Avatar
    Nov 2017
    Denmark
    Zealand, Naestved
    Age
    39
    23 (100%)
    Quote Originally Posted by tihopop View Post
    Oh, glad you got it working, but sad i still don't have any memory expansion to buy 😯
  7. #7
    tihopop's Avatar
    Feb 2010
    Canada
    Ontario
    28 (100%)
    Oh, glad you got it working, but sad i still don't have any memory expansion to buy 
    Be patient, something will surface up eventually.
  8. #8
    screemo's Avatar
    Nov 2017
    Denmark
    Zealand, Naestved
    Age
    39
    23 (100%)
    Yep, sure hope it will - I'm buying all possible for my newly purchased A3000D.
    It almost surpasses my new ryzen pc in cost by now... Oh those memories cost you 😄
  9. #9
    ElectroBlaster's Avatar
    Aug 2010
    Exeter, Devon
    Age
    43
    15 (100%)
    Can you please tell me what memory is on the riser board and what settings you used? Sorry... I need to RTFM on mine but I am gathering as much info as I can
  1. Replies: 19
    Last Post: 18th October 2015, 21:09
  2. Sold Cyberstorm PPC (working as MK III)
    By Sveta in forum Sales Archive
    Last Post: 23rd June 2015, 01:52
  3. Closed Cyberstorm MKII 060 or other working in A3000
    By Rotzloeffel in forum Amiga
    Last Post: 13th September 2013, 12:10
  4. Sold NON WORKING - CyberStorm MKIII 50MHz 060
    By domb in forum Sales Archive
    Last Post: 21st November 2012, 22:55
  5. Closed Cyberstorm MKI 040 - not working!
    Last Post: 2nd April 2012, 06:55
Tags for this Thread
