Page 12 of 12 FirstFirst ... 289101112
Results 111 to 113 of 113
Thread: Amiga hardware repair, restoration and upgrade service
  1. #111
    Amibayer! hese's Avatar
    Aug 2008
    Finland
    Savo
    111 (100%)
    SirRush's hardware has been repaired and shipped back a while ago. Here's the report.
    Cyberstorm PPC
    The computer hung up when PPC software was run. The PPC CPU was faulty and has now been replaced with a working 400MHz CPU. The PPC was set to run at 390MHz (6*65MHz).
    Amiga 4000T motherboard
    The motherboard didn't boot, it had a few bent/ripped off pins that were repaired. The motherboard works again.
    Amiga 4000D motherboard #1
    The motherboard had a heat related graphics issue which has been fixed. The CPU slot had a bent pin which has been fixed. The power plug had corroded pins, the plug was replaced with a new one.
    Amiga 4000D motherboard #2
    The motherboard did not boot, the board had suffered from a battery leak. The battery damage was repaired. A broken trace near the Kickstart ROM sockets was repaired. A few components were missing at the power input area, the missing components have now been installed. The board had a bad oscillator which has been replaced. The board suffered from a heat related graphics issue which has been fixed. The old SIMM sockets were replaced with new ones and the board was recapped.
    Picasso IV
    The board was recapped with non-leaking polymer capacitors.
    Here are links to the picture galleries.
    Cyberstorm PPC repaired
    Amiga 4000T repaired
    Amiga 4000D #1 repaired
    Amiga 4000D #2 repaired
    Picasso IV recap
    warr8or29's hardware has been repaired and sent back a while ago. Here's the report.
    Cyberstorm MK3
    The card did not boot. The 68060 socket made of pin strips was in a bad condition, several pins were either bent or completely detached from the BGA pads. The 68060 pin strip socket was removed and replaced with a custom made socket. The oscillator had been resoldered earlier and in the process some of the traces and vias had been damaged. The traces and vias have now been repaired. One of the vias was connected to an internal track and tracing that track too some detective work. The detached internal trace had to be repaired with a piece of very thin jumper wire. The board works again.
    Cybervision 64/3D
    The card displayed garbled mouse cursor. The issue has been fixed.
    CD32 FMV Module
    The FMV module produced image with bad colors. The module had been recapped earlier with through-hole capacitors and some of the pads were either missing or in bad condition. Some of the capacitors and other passive components were faulty. The broken pads have been repaired and module recapped with SMD capacitors. The faulty components have been replaced. The module produces image with proper colors again.
    Amiga 1200 motherboard
    The motherboard did not boot. The Alice chip was faulty and has now been replaced with a working one. Also the motherboard had issues with graphics (too bright colors) and that issue has also been fixed.
    Cyberstorm MK3 repaired
    Cybervision 64/3D repaired
    CD32 FMV Module repaired
  2. #112
    Amiga Enthusiast Cozzer79's Avatar
    Nov 2015
    United Kingdom
    Oxfordshire
    38
    59 (100%)
    Could you replace the memory on a BlizzardVision PPC for me please?
    AMIGA A1200, Kickstart 3.1, FZ-357A HD floppy and HxC Rev C (with DF0:/DF1: switch), Internal IDE DVD-RW, CDTV key caps, Blizzard PPC FS Rev 6 68060 @ 50MHz and 603e @ 240MHz with SCSI, 256MB RAM and 16GB SCSI2SD, Indy MK2cr and Blizzard Vision through a Ratte switch, RapidRoad USB, and uprated 60W PSU - Bifrost LEDs and laser mice too!
  3. #113
    Buckers's Avatar
    Nov 2009
    Newcastle
    51
    3 (100%)
    Default Amiga 2000
    Interested in having an Amiga 2000 6.2 motherboard repaired as it does not recognise any Zorro cards
  1. Request Amiga service / upgrade ( UK , Edinburgh )
    By gebes in forum Services
    Last Post: 13th October 2015, 16:16
  2. Found A3640 Repair, Service and Upgrade (x2)
    By Peckmore in forum Amiga
    Last Post: 8th October 2015, 18:17
  3. SERVICE REQUEST: A3640 Repair Service USA
    By Voultar in forum Wanted Hardware
    Last Post: 10th August 2015, 00:24
