Assembling AA3000+ boards for matt3k
01.01.2020 - 02.01.2020
I've begun assembling the AA3000+ board set for matt3k a couple of days ago. After two long days of soldering all the passive components etc. (resistors, capacitors [except polymers], ferrite beads, transistors, diodes, ...) and over half of the glue logic chips are in place. Next to solder the small pitched SSOP glue logic chips.
04.01.2020
All SSOP chips soldered, scandoubler/flicker fixer memory chips soldered, sockets added for ATF/GAL chips, ATF chips programmed and installed onto the motherboard. Amiga custom chips and the DSP chip will be soldered next. Photo gallery updated.
11.01.2020
AA3000+ Firebird Daughterboard assembled and programmed. Continuing to assemble the motherboard next.
18.01.2020 - 19.01.2020
All custom chips, CPU and FPU sockets and processors, SCSI and Kickstart sockets and chips, DSP processor, polymer capacitors, most of the connectors and other miscellaneous parts soldered. A few connectors left to install. After that the boards are ready for testing.
28.01.2020
The boards have been fully assembled and passed the tests. The supplied Ramsey-07 was bad and gave all sorts of stability issues with A3640. After swapping the Ramsey-07 with another one, the board ran stable with the on-board 68030 and also with the A3640. The SuperDMAC-04 and Ramsey-07 got socketed in the process.
Photo gallery
here.
