Page 1 of 10 12345 ... LastLast
Results 1 to 10 of 96
Thread: 8MB RAM to 68000 socket
  1. #1
    Inactive Member mkl's Avatar
    Jan 2009
    Finland
    Tampere
    110 (100%)
    Default 8MB RAM to 68000 socket
    Please post interest to the linked thread instead (in order to keep lists 'linear'): http://www.amibay.com/showthread.php...600-CF-adapter
    I will make a list of interested, perhaps to first post of thread.
    0 available.
    Options for config out, in, or ram on even without autoconfig( use addmem program)
    Info http://www.mkl211015.altervista.org/ram68k/
    Please post interest post including IDE board (RAM board soldered to same pins) to the linked thread: http://www.amibay.com/showthread.php...600-CF-adapter
    V59 boards will be for sale. 40€ + postage,which is 2.20€ to Europe / 3.30€ world. (50 grams priority untracked letter postage, packaged in small shipping carton, antistatic bubble bag for memory card.) Registered (signed-for) tracking service for +9.80€ extra.
    2 pcs v59 blank pcbs with postage 10€
    A500, A1000, A2000, (CDTV with addmem-command OR hacking autoconfig signal from or to mainboard?).
    v59 cpld config signal options: "O582" out (drives led for indication), old version in "I582", new config in version with ram always enabled regardless of autoconfig ".583" to use with autoconfig or addmem-command, to be made.
    Also 4meg config options by programming the cpld code via jtag.
    V58/59 doesnt need riser socket, when placed on top of v402/418 style ide boards, but it maybe tight with the polarising tab of idc cable connector or maybe not fit with boxed ide header.
    About dram refresh:
    To refresh, the cpld uses cas before ras refresh when 68000 address strobe(/AS) is negated. I dont know if 68010 will release /AS in loop transfer mode? Refreshing can be delayed perhaps.
    Old V40,42,43 with 5 volt dram,: V42 with 3.3v xc9572xl, 5v 4m x 16 edo dram, v40 5volt parts
    Combination with v4x ram, v402 ide board requires a riser socket in between the boards.
    Ide v402 low profile and v4x ram wont attach to each other directly. Cpld chips "collide" preventing complete insertion. Ram on top will not fit because of ideconnector. Riser socket adds height.
    part list for v43 pcb
    edo dram KM416C4104 (suffix can be 'C')
    XC9572XL tqfp-100 (tq/tqg100) (
    regulator LM3480 - 3.3 volt (i have some for sale if needed)
    led size 1206 (or 0805) + 330 ohm series R 1206
    connectors. pin headers (not necessary).
    64 pcs 'socket pins' (I bought new one at aliexpress, search mx cherry led)
    capacitor notes in picture at www.mkl211015.altervista.org/ram68k/
    http://mkl211015.altervista.org/ide/ide68k.html email&paypal: mlvhct@gmail.com See first post of for-sale thread for up to date availability info
  2. #2
    Inactive Member Gravislord's Avatar
    May 2016
    United States
    CA
    Age
    49
    8 (100%)
    Interested
    Sent from my Robin using Tapatalk
  3. #3
    OXCOM's Avatar
    Dec 2012
    Slovakia
    Stredoslovensky
    93 (100%)
    Declare interest, if this is still available. Next batch?
    PM sent.
  4. #4
    Inactive Member bagpuss22's Avatar
    Jan 2011
    East Sussex
    Age
    52
    73 (100%)
    I too am interested for my CDTV if there are any available OR another batch.
    Collector of most retro things 8/16 Bit :cool:
  5. #5
    fery1200's Avatar
    Jul 2012
    Czech republic
    Plzensky kraj
    Age
    43
    13 (100%)
    Declare interest.
  6. #6
    jochen's Avatar
    Dec 2011
    Germany
    Saxony
    76 (100%)
    Interested if you have new ones for my CDTV.
    Does it autoconfig?
  7. #7
    Jan 2009
    Finland
    Tampere
    110 (100%)
    Autonfig out signal.
  8. #8
    Fook42's Avatar
    Sep 2016
    Germany
    Niedersachsen
    35 (100%)
    i've one of these (in an older version).. but i am wondering if it is possible to switch off autoconfig but still use "addmem" or similar to use the memory?
  9. #9
    Jan 2009
    Finland
    Tampere
    110 (100%)
    It would require change in cpld code, now ram output at least disabled when autoconfig not done.
    It is possible to change the cpld config.
  10. #10
    Jan 2009
    Finland
    Tampere
    110 (100%)
    A couple of V58 for sale for a few days, then no sale for a few weeks. ( V40 and v42 one each available, but at the moment in other bay)
  1. Replies: 7
    Last Post: 8th December 2017, 13:28
  2. Replies: 9
    Last Post: 21st June 2015, 20:18
  3. Closed Collective order: Turbocard for 68000-socket with 2MB RAM and IDE
    By MatthiasH in forum Sales Archive
    Last Post: 31st October 2012, 11:18
  4. Closed 68000 IC Socket for an Amiga 2000
    By Brataccas in forum Found Archive
    Last Post: 2nd May 2009, 01:33
Tags for this Thread
