Results 1 to 7 of 7
Thread: Floppy Disk Drive - Storage
  1. #1
    Retro Computer Fan Retro-mania's Avatar
    Jul 2012
    East Sussex
    1 (100%)
    Default Floppy Disk Drive - Storage
    Hello there
    When storing a machine for long periods of time (in its box) should the floppy drive be left empty or is it a better idea to leave a disk inserted?
    To be specific, I'm referring to an A1000 if that helps. I dont have the cardboard insert that would have originally been in the drive.
    So what is the best approach? Leave a disk in, or leave the drive empty?
    Retro-mania
  2. #2
    Amibayer! Bryce's Avatar
    Aug 2012
    Germany
    Nordrhein Westfalen
    68 (100%)
    Leave it empty. Aging disks tend to start loosing their magnetic surface and would deposit this crap on the heads. When no disk is in the drive the heads are floating mid-air.
    Bryce.
  3. #3
    silverdr's Avatar
    Oct 2016
    Poland
    Szczecin
    2 (100%)
    Quote Originally Posted by Retro-mania View Post
    Hello there
    Leave it empty. The way it came from the factory. The cardboard that was typical for 5.25" drives (luckily) didn't make it to 3.5" drives. Moreover, you don't want a diskette, which is not rotating for a long period of time to "stick" its surface to the magnetic head(s) of the drive. The only reasonable alternative to leaving it empty would be if you had a so-called cleaning diskette, made of non-magnetic fiber. But even then I wouldn't bother.
    Hello there
    Was it there? Did you see it being there? Admittedly I never had a brand new A1000 but none of the later models had anything in their drives when shipped from the factories.
    Hello there
    Leave it empty. You don't risk damaging, magnetising, staining, whatever of your magnetic heads.
  4. #4
    Jul 2012
    East Sussex
    1 (100%)
    Ok thanks for the replies and advice!
    The chap I bought the system from placed a didk in the drive on Saturday for transportation and I took it out today. Will my drive head be ok? I cant set it all up to test just yet, hence my question.
    Thanks again
  5. #5
    silverdr's Avatar
    Oct 2016
    Poland
    Szczecin
    2 (100%)
    If the diskette looks good (clean) inside - it shouldn't do anything bad to the drive during such relatively short period.
  6. #6
    ElectroBlaster's Avatar
    Aug 2010
    Exeter, Devon
    Age
    43
    15 (100%)
    Been there and had it! I once snagged an amiga 600 with a disk still in the drive! the seller stated it was as is, as found and nothing was done or tested.
    So when it arrived I instantly went to eject the disk carefully, would not budge! In the end I pulled the top cover and keyboard out, lifted the cover on the floppy drive and discovered the heads were stuck to the disk. managed to unstick without messing things up but it was a bit touch and go lol. Could have easily torn the heads out on that
  7. #7
    Aug 2012
    Germany
    Nordrhein Westfalen
    68 (100%)
    Those heads are actually much robuster than you think. Chemicals are bad news, but physically they are difficult to damage.
    Bryce.
    Gesendet von meinem Motorola DynaTAC 8000x mit Tapatalk
  1. For Sale 3.5" floppy disk storage box
    By Konrad19 in forum Amiga
    Last Post: 20th April 2016, 05:30
  2. For Sale Brand new 3.5" floppy disk storage boxes
    By christopherpm in forum Other
    Last Post: 23rd December 2015, 17:32
  3. Found Floppy disk drawer storage box
    By J.T.Kirk in forum Found Archive
    Last Post: 13th January 2012, 23:18
  4. Sold Amitek Floppy Drive Case (No disk drive)
    By lopos2000 in forum Sales Archive
    Last Post: 11th October 2011, 02:46
Tags for this Thread
