FastCache040+ 1.0 ©SpeedGeek 2017
INTRODUCTION:
FastCache040+ is a patch to replace the CachePreDMA() and
CachePostDMA() functions of most 68040/060 libraries. While
the old functions are adequate they are far from optimal.
These old functions have 3x more code then the new ones
provided with this patch!
Also, the new functions implement a much more efficient method
of managing the Copyback cache for DMA. While every system
will have some CPU performance loss under DMA conditions, the
new functions keep this performance loss to a bare minimum.
FEATURES:
- Replaces CachePreDMA() and CachePostDMA() with smaller
and more efficient code
- Replaces complex MMU code with simple and fast DTTR code
- Temporarily changes Copyback mode to Write Through for DMA
(but only when required!)
- Never flushes the ATC!
- Never flushes the DC for Chip RAM DMA!
- Uses 68040/060 library detection code
- Will not patch itself
- 100% Assembler code
CODE SIZE COMPARISONS:
- FastCache040+ 1.0 (NewFunc 132 bytes)
- 68060.library 46.7 (OldFunc 304 bytes)
- 68040.library 44.2 (OldFunc 414 bytes)
REQUIREMENTS:
- Amiga with 68040 or 68060 CPU and MMU
- 68040.library or 68060.library
WARNING:
Do NOT use this patch with GigaMEM, VMM or any similar
virtual memory software! Do NOT use this patch with any
code which uses the MMU to write protect or remap modified
data structures!
NOTES:
Remapping a mirror image of the Kickstart ROM with the MMU
is OK! The new functions still have one thing in common with
the old functions. They do NOT translate virtual addresses
as specified in the Amiga RKRM! For more info on the old
functions see the Enforcer.guide by Michael Sinz.
HISTORY:
v1.0 - First release
Here is the link:
http://eab.abime.net/showthread.php?...90#post1189690
INTRODUCTION:
FEATURES:
REQUIREMENTS:
WARNING:
data structures!
NOTES:
HISTORY:
Here is the link:
