Results 1 to 9 of 9
Thread: OSSC (Open Source Scan Doubler) Discussion
  1. #1
    BubbaMc's Avatar
    Jan 2015
    Perth, WA
    Age
    38
    0
    Default OSSC (Open Source Scan Doubler) Discussion
    I've recently got one of these and was absolutely blown away! Didn't see a dedicated thread here apart from a member which recently offered some available for sale, so I thought I'd make this one. If you're looking to connect your Amiga (or any system designed for 15khz CRT) on pretty much any modern display, I think this solution is the best we could ever hope for.
    OSSC Wiki: http://junkerhq.net/xrgb/index.php?title=OSSC
    There are some photos in this thread showing what it can do for your Amiga, along with verified settings: http://eab.abime.net/showthread.php?t=84788
    If current owners could chime in with their experiences with the device, that'd be great
    Additionally, if there are any questions regarding the use of the device, post them here and I'll do my best to answer them.
  2. #2
    cugar124's Avatar
    Feb 2011
    Age
    47
    51 (100%)
    interesting very expensive no reason to swap over if you have an Indi but tell me if I am wrong?
    Kind regards
    Al
    ZX Spectrum Plus;Gaming I7 PC; A4000 Cyberstorm MK2 128MB, Big Ram Plus, Ariadne 2, DCE Cybervision 64/3D, Indi Mk2 CR Fast ATA Vortex 386 16mb. Commodore 128D, Sam460ex
  3. #3
    Amibayer! demolition's Avatar
    Oct 2012
    Denmark
    Copenhagen
    Age
    38
    57 (100%)
    It is better than the Indivisions for several reasons in my opinion. Indy ECS and AGA MkI are similar and by many considered the best of the Indivisions, however they can only provide VGA output. They are also not without issues. The AGA can be tricky to install and can tend to pop out and the ECS does not remember all its settings properly every time it boots (I am not sure if the AGA have the same issue). The AGA MkII has the DVI output but the scanline emulation is quite bad on my opinion and it is hard to make it do proper 50 Hz throughput to a monitor/TV. I cannot make the MkII provide a picture at all on my TV using a DVI-HDMI adapter.
    The OSSC provides very low latency conversion (one scanline), very nice looking scanline emulation for those who like to use that, and proper 50 Hz output for stutter-free motion. Also, since it is external, you only need to buy one to be able to use it with all your Amigas and other retro-devices, so in the end it could very well be cheaper if you like to use several different computers like I do. Contrary to the Indivision, the OSSC works well with the HDMI input on my TV, so I certainly do not regret buying one.
    A1200 (NOS) : 030 33MHz 128MB fast RAM (ACA1232) : Indivision AGA MkII : 8GB CF : RR USB : Ethernet
    A600 #1 : 080 V2 : 128MB fast : 2MB chip : Indivision ECS : 32GB CF : RR USB
    : Ethernet | A600 #2 : 010 : 2MB chip
    A500 : 68000 42MHz : 1MB chip : 8MB fast : 4GB CF | A500+ : 080 V2+ : 128MB fast : 2MB chip : 32GB CF
  4. #4
    GurúMeditating trixster's Avatar
    Apr 2014
    Yorkshire
    30 (100%)
    I have an OSSC which I use with my consoles. I currently have a Megadrive, SNES, Jaguar, PS1, PS2 and Saturn hooked up to one through a scart switcher, and all look absolutely fantastic.
    Totally rexommended.
    A1200 B1260 80Mhz + Indi AGA2 + Ide-fix Express | A3000 A3660 50Mhz + CV64 + Deneb + 486SLC | 2xA500
    A4000 CSMk2 66Mhz + G3 PPC 800Mhz + Voodoo3 + Indi AGA + Deneb | Saturn | PS1&2 | C64 | SNES | 3DO
    A3020 | A3000 | BBC B | BBC Master | Atom | CPC6128 | Jaguar | G5 2.7Ghz MOS | Atari Falcon CT60e | 2600
  5. #5
    BubbaMc's Avatar
    Jan 2015
    Perth, WA
    Age
    38
    0
    Quote Originally Posted by cugar124 View Post
    Kind regards
    Al
    Some advantages of the OSSC:
    • Framebufferless design so there's almost zero latency, fractions of a millisecond (Indivision uses a scanbuffer so the minimum latency it could achieve is 16ms)
    • 50Hz refresh rate is fully supported, so there is no stuttering with a moving picture - most Amiga games are 50Hz, not 60
    • Audio is converted to PCM and carried over the HDMI cable
    • Many different line multiplication modes are available, so there's more chance of getting a pixel perfect/integer scaled display on your particular monitor or TV. For example, with 5x output fed into a 1080P TV, it's possible to get an integer scaled picture which is perfectly sharp. Some lines on the top and bottom will be cropped, but Amiga games don't use the full display anyway.
    • Regular firmware updates adding new modes and features.
    Basically what demolition said. Plus there are a whole lot of other settings and tweaks available which I doubt are possible with the Indivision. Refer to the Wiki for details on these.
  6. #6
    Apr 2014
    Yorkshire
    30 (100%)
    It is worth mentioning that not all tv's can handle the 3x 4x and 5x modes, so some research might be necessary before purchasing to avoid disappointment. That said, my 1080p tv (a Panasonic GT50) will only handle 2x and I still think the quality is amazing and still heartily recommend the OSSC.
  7. #7
    Oct 2012
    Denmark
    Copenhagen
    Age
    38
    57 (100%)
    True, I also have a Panasonic GT50 but even with 2x mode it is worth noting that the picture is still more or less full screen since the TV will scale it up to 1080p, so it is not like you have to play on a tiny 24" rectangle on your large TV.
  8. #8
    Asking the questions because I DON'T KNOW Amibayer!
    Staff Moderator
    slk486's Avatar
    Apr 2010
    Denmark
    Sealand
    134 (100%)
    I have had the Indivison, the Framemeister Mini, and the OSSC blows them both out of the water - event at x2 and much more compatible. The Framemeister has an advantage in scaling sharpness at x2, but the OSSC more than makes up it with 0 lag (yes, it is effectively 0).
    I heartily recommend investing in a DVDO Edge to sit after the OSSC. It handles bloody anything (well except x5)
    I do believe Samsung 4K tv's do accept x5, btw.
    ^^^ IMHO... Always IMHO ^^^
    r0jaws is my hero
    Keropi is my supreme being
  9. #9
    jdryyz's Avatar
    Jul 2014
    Los Angeles
    3 (100%)
    It is a shame about 5x being so cropped on my 60 Vizio TV because it is pixel-perfect. 2x is the only way to get the whole image out of my A1200 on the screen but it is a bit blurry. x3 and x4 are not compatible at all.
  1. Replies: 67
    Last Post: 13th January 2018, 21:52
  2. Sold Scan magic scan doubler flicker fixer 1200/4000
    By Justin in forum Sales Archive
    Last Post: 28th December 2012, 09:12
  3. Sold Scan Magic Scan Doubler Flicker Fixer -1200/4000
    By Bastich in forum Sales Archive
    Last Post: 31st October 2012, 16:33
  4. Closed SOLD: Scan Magic Internal (Scan Doubler Flicker Fixer)
    By Zetr0 in forum Sales Archive
    Last Post: 30th January 2008, 16:49
Tags for this Thread
