Results 1 to 3 of 3
Thread: Does anyone have an ACA500 Recovery Disk ADF to hand?
  1. #1
    gurthuk's Avatar
    Nov 2013
    Sowerby Bridge, Halifax
    7 (100%)
    Default Does anyone have an ACA500 Recovery Disk ADF to hand?
    My ACA500 (not the plus) has died and now fails to boot. I'm hoping it's a firmware issue and all I need to do is refresh the firmware from a recovery disk...
    Does anyone have an ACA500 Recovery Disk ADF to hand they could email me please?
  2. #2
    Amibayer! demolition's Avatar
    Oct 2012
    Denmark
    Copenhagen
    Age
    38
    57 (100%)
    The latest firmware can be found here:
    http://wiki.icomp.de/wiki/File:Menu500V0111.zip
    However, it relies on the built-in flash tool. The older version here contains a tool called 'flashload' which can be run from dos:
    http://wiki.icomp.de/wiki/File:Menu500_ChipMap.zip
    I put the two together on a bootable disk that I have attached, so hopefully that should work. Do not have an ACA500 but I tried booting it in WinUAE and the tool seems to accept the firmware but obviously fails to find the ACA.
    FlashACA500.zip
    A1200 (NOS) : 030 33MHz 128MB fast RAM (ACA1232) : Indivision AGA MkII : 8GB CF : RR USB : Ethernet
    A600 #1 : 080 V2 : 128MB fast : 2MB chip : Indivision ECS : 32GB CF : RR USB
    : Ethernet | A600 #2 : 010 : 2MB chip
    A500 : 68000 42MHz : 1MB chip : 8MB fast : 4GB CF | A500+ : 080 V2+ : 128MB fast : 2MB chip : 32GB CF
  3. #3
    gurthuk's Avatar
    Nov 2013
    7 (100%)
    Thank you sir!
  1. Replies: 0
    Last Post: 9th February 2016, 03:06
  2. Password recovery in IE8
    By McVenco in forum AmiOracle
    Last Post: 11th January 2011, 17:26
Tags for this Thread
