Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: 8375 AGNUS for A500 rev6a mod
  1. #1
    unbrain's Avatar
    Oct 2017
    Blackpool, Lancashire
    Age
    40
    0
    Default 8375 AGNUS for A500 rev6a mod
    Ongoing attempts to revive some of my amigas, I am looking for a 8375 AGNUS chip (318069-16).
  2. #2
    8 Bit Dreams DjCook's Avatar
    Apr 2016
    Germany
    Bavaria
    Age
    40
    31 (100%)
    it is pin uncompatible to 8372, hope you know it
    repairs of retro computers & hardware in Germany
  3. #3
    Minter's Avatar
    Aug 2015
    Spain
    Palma de Mallorca
    2 (100%)
    Quote Originally Posted by unbrain View Post
    HI!
    I have some used Fat Agnus (318069-16), if you are interested. (Not tested, sorry)
  4. #4
    unbrain's Avatar
    Oct 2017
    Age
    40
    0
    Thanks for your reply, I was under the impression that the 318069-16 model number of the 8375 should be pin compatible with the 8372A that was in there from the factory?
  5. #5
    Minter's Avatar
    Aug 2015
    Spain
    Palma de Mallorca
    2 (100%)
    According this page:
    http://www.pmsoft.nl/amiga/amiga-parts-chips.html
    Agnus (2MB) 8375 (390544-xx) is not pin compatible with 8375/8372AB/8372B (318069-xx) !!
    But I just read here:
    http://theamigamuseum.com/the-hardwa...chipset/agnus/
    ++ 318069-16 (PAL) or -17 (NTSC). Vbb replacement to the 8372A. 1 MB support, pin compatible to the 8370/71/72A family.
    Typically found on very late Amiga 2000-B systems (some require a small fix for stable operation with these chips – same when using them as a replacement to an existing 8370/71/72A).
    Them, depends of your A500 revision.
  6. #6
    Math inside Amibayer! BLTCON0's Avatar
    May 2011
    Hellas (Greece)
    Chania, Crete
    Age
    42
    87 (100%)
    @Minter
    Yep, I wrote that entry for theamigamuseum.
    The rework necessary is documented in the amigawiki webpage.
    What puzzles me is the OP mentions a "mod", I suppose he means the 1 MB chip RAM mod, in which case the usual request is for the quite common 8372A (318069-29) and not for the 8375 substitute (318069-16 or -17), let alone that applies to the very few rev6A's which shipped with the earlier 8371 Agnus. The rest already have the 8372A.
    Maybe it's the 2 MB chip RAM mod for the rev6A (which uses either the quite rare 318069-03 Agnus (8372B) or the Vbb substitutes 318069-18 or -19 from the 8375 series) and the OP got the -16 (1 MB version) and -18 (2 MB version) mixed up.
    (*) -16 PAL, -17 NTSC
    (**) -18 PAL, -19 NTSC
  7. #7
    Apr 2016
    Germany
    Bavaria
    Age
    40
    31 (100%)
    Quote Originally Posted by BLTCON0 View Post
    if i got You right: 318069-18 and also 8372B/AB can be placed instread of standard a 8372 giving 2Mb of chipRAM? If so - i am looking for one of these too
  8. #8
    unbrain's Avatar
    Oct 2017
    Age
    40
    0
    @Minter
    Ah, my bad, yes, I'm after doing the 2MB chip conversion for my A500, got the wrong part number, sorry!
  9. #9
    May 2011
    Hellas (Greece)
    Chania, Crete
    Age
    42
    87 (100%)
    Quote Originally Posted by DjCook View Post
    8372AB is probably no different from the 8372B silicon - all AB chips seem to have the B printed as an afterthought, which implies it was a batch of "B" versions fitted in "A" packaging and later the designation was "corrected" with the additional "B".
    As to the question, the 8372(A)B and its Vbb 8375 equivalent actually are not drop-in replacements for the 8372A.
    If you only have a single bank of RAM (that is, the default 512KB) then it'll still work, but if you have 1 MB of RAM (onboard + trapdoor) then the extra 512KB will disappear. This new Agnus only has a single RAS line, so it doesn't support two RAM banks.
    So if you wish to install this Agnus on a rev6A A500, it should best be done at the same time with upgrading the RAM to 2 MB. The process is 4-step:
    1. replace Agnus
    2. change jumper blocks
    3. remove the four 256Kx4 chips from existing RAM bank
    4. install four 1Mx4 chips in the other (previously empty) RAM bank
    It must be pointed out again that the whole 2 MB forms a single RAM bank now, so the trapdoor is rendered useless for RAM purposes. You can remove the RAM chips from a standard 512 KB trapdoor expansion however and have it work as an RTC-only card.
    Finally, while technically the requirement is a rev6A board, as it has the necessary provisions (suitable jumper blocks and trace support for 1Mx4 chips), there's a way out with using a rev5 board, but you must get an A501 rev6C trapdoor card, replace the chips with 1Mx4 chips there, change some jumpers on the A501 and a couple on the rev5. That way the onboard 512 KB will be bypassed and the Amiga will use the (now) 2 MB on the A501, naturally as chip RAM.
  10. #10
    Apr 2016
    Germany
    Bavaria
    Age
    40
    31 (100%)
    1. replace Agnus
    3. remove the four 256x4 chips from existing RAM bank
    seems You have a lot experience in it.. Respect!
    i have two amigas here, first is a standard A500 rev.6A and other is A500 with rev.8A board, 8375 Agnus, and (initially) 512kb of RAM. I have added TTL logic and 512kb onBoard, modded the jumpers JP2 & JP7A to add expansion to chipRAM, and now i have 1.5Mb, hope will get 1Mb expansion soon and then it will be 2Mb. My question is same as the topicstarter has:
    how can i reach 1.5 - 2Mb on a standard rev.6A board without purchasing expensive MiniMega? propably, the best way is just to lookin for rev.8A board, and do same upgrades i've done on my machine, cause the price for 8375 Agnus (or miniMega) is pretty high, and You'll end up with same price You A500 rev.8 can get!
  1. For Sale Agnus 8375 chips Agnus (1MB) (318069-16) new
    By tbtorro in forum Amiga
    Last Post: 13th January 2017, 22:17
  2. Replies: 144
    Last Post: 21st August 2016, 16:23
  3. Closed OR SWAP: Amiga 500, rev6a, MegaChip Agnus 8375PAL, KS3.1, 68000
    By kronuz in forum Sales Archive
    Last Post: 3rd October 2013, 12:09
  4. Agnus 8375 318069-18 (A500+) or 8372B (A3000)
    By clusteruk in forum Amiga
    Last Post: 1st August 2013, 21:56
  5. Closed DKB MegaChip A500/A2000 8375 Agnus
    By save2600 in forum Sales Archive
    Last Post: 17th May 2010, 19:46
Tags for this Thread
