Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: ZX Spectrum +3 Multiface 3 (Romantic Robot / Hard Micro clone)
  1. #1
    8 Bit Dreams DjCook's Avatar
    Apr 2016
    Germany
    Bavaria
    Age
    41
    166 (100%)
    Default ZX Spectrum +3 Multiface 3 (Romantic Robot / Hard Micro clone)
    [FONT=verdana]Hello!
    Offering here some Multiface 3 Interfaces for ZX Spectrum +3
Name:	2017-10-20 20.46.07.jpg
ID:	127551Click image for larger version.
Name:	2017-10-20 20.48.16.jpg
ID:	127553Click image for larger version.
Name:	2017-10-20 23.32.41.jpg
ID:	127561Click image for larger version.
Name:	2017-10-18 20.45.33.jpg
ID:	127513Click image for larger version.
Name:	2017-10-20 20.47.21.jpg
    https://picload.org/view/dgwrrdir/un...72-x-.jpg.html
    https://picload.org/view/dgwrrdia/un...72-x-.jpg.html
    https://picload.org/view/dgwrrdil/un...30-x-.jpg.html
    https://picload.org/view/dgwrrdii/un...72-x-.jpg.html
    https://picload.org/view/dgwrrdiw/un...72-x-.jpg.html
    transferring games from tape to disk is super easy now!( also may be used on black 128k 2A/2B Spectrum computers)
    Asking 30€ for the ready built fully populated board without case
    or 35€ for cased version
    PayPal as a friend/family or add 4% to cover fees
    Also IBAN payment is accepted
    Postage fees are 6,50€ to any country, with tracking number
    Also available:
    Amstrad / Schneider CPC
    Romantic Robot Multiface II clone 30€/35€
    Amiga A500+ / A2000
    TF530 50Mhz fully assembled accelerator board with extras: 150€
    Commodore C64
    cheap C64 PLA replacement 11€
    MixSID / StereoSID 50€
    nanoSID 15€
    Final Cartridge III PRO 30€
    ZX Spectrum:
    Programmable 10 in 1 ROM cartridge 20€ / 24,50€
    Romantic Robot Multiface 128k clone 35€ / 40€
    Sinclair QL:
    QubIDE - IDE interface for Sinclair QL computers 55€
    Minerva ROM 15€
    MSX:
    Carnivoire 2 Multifunctional cartridge with CF Interface (building and testing phase atm)
    Have also some A500 Amigas with TF530 installed, recapped PSU, and original tank mouse
    perfect for the persons who doesen't have A500, but likes to step in to Amiga world.
    Ask me, if You're interested
    will try to combine postage (max 500g) if several parts are purchased!
    Thanks for watching!
    with kind regards from Bavaria,
    -Viktor
    8 Bit Dreams - computer & hardware repair in Germany
  2. #2
    I Find Your Lack of Fat Disturbing Amibayer! tbtorro's Avatar
    Mar 2011
    Denmark
    Copenhagen
    962 (100%)
    Interested in cased Multiface 3
    cє<
  3. #3
    Apr 2016
    Germany
    Bavaria
    Age
    41
    166 (100%)
    PM was sent
    Quote Originally Posted by tbtorro View Post
  4. #4
    peterb999's Avatar
    Sep 2012
    Yorkshire
    1 (100%)
    Hi DjCook. I'm interested in the cased version.
  5. #5
    dimfil's Avatar
    Dec 2014
    Attiki
    Age
    45
    17 (100%)
    Never had a +3 but that looks interesting!
    Could you please tell me if this has a pass through port and if yes, can it be used together with a divmmc?
    Thank you in advance.
  6. #6
    owen2471's Avatar
    Aug 2011
    england
    cheshire
    49 (100%)
    Can I have more info on the Msx cartridge pls
  7. #7
    Apr 2016
    Germany
    Bavaria
    Age
    41
    166 (100%)
    Quote Originally Posted by peterb999 View Post
    Please check first post (updated pics), and let me know, does these cases, i've choosen, accord Your needs. i know, these are totally different to original, sorry, can't find better, cause space is very limited due power and RGB connectors! These cases are available in five different colours: red, black, blue, green and translucent)
    Quote Originally Posted by dimfil View Post
    original Multiface 3 from Romantic Robot was offered in two versions: with pass through port and without it. My problem is - edge connectors i have does not have long enough pins, so if boxed version is choosen i can not solder pass through port on the other side, however, if You choose bare board - i am able to do it. Second problem is: in this case i need to order additional boards, and here's the point where i schould think twice, as i have two options:
    1. Make simple pin to pin pass through port
    2. add a fixer board (fixes port issue and allows connection of Spectrum's first generation interfaces like Interface 1 & 2, +D and so on..
    Adding a pass through port will add production cost, in other hand (if it works) there will be a possibility to transfer any game to disk easiliy..
    please let me know what do You think about it, need to see how high demand is..
    Quote Originally Posted by owen2471 View Post
    thanks for Your interst, info about Carnivoire 2 MSX cart may be found on youtube, also some info is here:
    https://www.msx.org/news/en/the-carn...-been-released
  8. #8
    dimfil's Avatar
    Dec 2014
    Attiki
    Age
    45
    17 (100%)
    Quote Originally Posted by DjCook View Post
    This should be tested somehow. If it would work transferring from divmmc to floppies then for sure personally I would be interested and I completely understand that the production cost would be higher.
    But, I don't know how possible it is for you to create and test such a prototype in conjunction with the divmmc.
  9. #9
    Apr 2016
    Germany
    Bavaria
    Age
    41
    166 (100%)
    there is no problem to cut that connector out of the veroboard, however, it should be double sided then
    other possibility is to connect IDE interface (that one works for sure:
    https://www.youtube.com/watch?v=0Kl6rTV_s3U
    i am pretty sure divIDE/divMMC will work fine too
  10. #10
    peterb999's Avatar
    Sep 2012
    Yorkshire
    1 (100%)
    Hi DJ Cook. I would be very interested in the multiface 3 with the IDE connector at the back (so I could still use divMMC). It would be even better if it would fit in a case.
  1. Replies: 13
    Last Post: 23rd September 2018, 07:41
  2. Sold Atari ST: Multiface ST - Romantic Robot
    By Puni/Void in forum Atari
    Last Post: 14th August 2014, 07:27
  3. Replies: 13
    Last Post: 25th January 2012, 15:23
  4. Sold Romantic Robot Multiface Two for CPC
    By GingerB in forum Sales Archive
    Last Post: 9th July 2011, 04:17
  5. Closed Multiface for zx spectrum
    By Adix in forum Found Archive
    Last Post: 3rd August 2010, 19:37
Tags for this Thread
