Sold ZX Spectrum +3 Multiface 3 (Romantic Robot / Hard Micro clone)
DjCook
8 Bit Dreams
Germany
Bavaria
Hello!
Offering here some Multiface 3 Interfaces for ZX Spectrum +3
2017-10-20 20.46.07.jpg2017-10-20 20.48.16.jpg2017-10-20 23.32.41.jpg2017-10-18 20.45.33.jpg2017-10-20 20.47.21.jpg
https://picload.org/view/dgwrrdir/universal-gehaeuse-124-x-72-x-.jpg.html
https://picload.org/view/dgwrrdia/universal-gehaeuse-124-x-72-x-.jpg.html
https://picload.org/view/dgwrrdil/universal-gehaeuse-124-x-30-x-.jpg.html
https://picload.org/view/dgwrrdii/universal-gehaeuse-124-x-72-x-.jpg.html
https://picload.org/view/dgwrrdiw/universal-gehaeuse-124-x-72-x-.jpg.html
transferring games from tape to disk is super easy now!( also may be used on black 128k 2A/2B Spectrum computers)
Asking 30€ for the ready built fully populated board without case
or 35€ for cased version
PayPal as a friend/family or add 4% to cover fees
Also IBAN payment is accepted
Postage fees are 6,50€ to any country, with tracking number
Also available:
Amstrad / Schneider CPC
Romantic Robot Multiface II clone 30€/35€
Amiga A500+ / A2000
TF530 50Mhz fully assembled accelerator board with extras: 150€
Commodore C64
cheap C64 PLA replacement 11€
MixSID / StereoSID 50€
nanoSID 15€
Final Cartridge III PRO 30€
ZX Spectrum:
Programmable 10 in 1 ROM cartridge 20€ / 24,50€
Romantic Robot Multiface 128k clone 35€ / 40€
Sinclair QL:
QubIDE - IDE interface for Sinclair QL computers 55€
Minerva ROM 15€
MSX:
Carnivoire 2 Multifunctional cartridge with CF Interface (building and testing phase atm)
Have also some A500 Amigas with TF530 installed, recapped PSU, and original tank mouse
perfect for the persons who doesen't have A500, but likes to step in to Amiga world.
Ask me, if You're interested
will try to combine postage (max 500g) if several parts are purchased!
Thanks for watching! :smile:
with kind regards from Bavaria,
-Viktor
Never had a +3 but that looks interesting!
Could you please tell me if this has a pass through port and if yes, can it be used together with a divmmc?
Thank you in advance.
Interested in cased Multiface 3
Hi DjCook. I'm interested in the cased version.
Please check first post (updated pics), and let me know, does these cases, i've choosen, accord Your needs. i know, these are totally different to original, sorry, can't find better, cause space is very limited due power and RGB connectors! These cases are available in five different colours: red, black, blue, green and translucent)
original Multiface 3 from Romantic Robot was offered in two versions: with pass through port and without it. My problem is - edge connectors i have does not have long enough pins, so if boxed version is choosen i can not solder pass through port on the other side, however, if You choose bare board - i am able to do it. Second problem is: in this case i need to order additional boards, and here's the point where i schould think twice, as i have two options:
1. Make simple pin to pin pass through port
2. add a fixer board (fixes port issue and allows connection of Spectrum's first generation interfaces like Interface 1 & 2, +D and so on..
Adding a pass through port will add production cost, in other hand (if it works) there will be a possibility to transfer any game to disk easiliy..
please let me know what do You think about it, need to see how high demand is..
Can I have more info on the Msx cartridge pls
thanks for Your interst, info about Carnivoire 2 MSX cart may be found on youtube, also some info is here:
https://www.msx.org/news/en/the-carnivore2-cartridge-has-been-released
This should be tested somehow. If it would work transferring from divmmc to floppies then for sure personally I would be interested and I completely understand that the production cost would be higher.
But, I don't know how possible it is for you to create and test such a prototype in conjunction with the divmmc.
there is no problem to cut that connector out of the veroboard, however, it should be double sided then
other possibility is to connect IDE interface (that one works for sure:
https://www.youtube.com/watch?v=0Kl6rTV_s3U
i am pretty sure divIDE/divMMC will work fine too
Hi DJ Cook. I would be very interested in the multiface 3 with the IDE connector at the back (so I could still use divMMC). It would be even better if it would fit in a case.
Multiface 3 in black enclosure was assembled and sent to peterb999
today, november 7, 2017
I picked up the multiface from the post office this morning.
It looks great in the case and works really well. Many thanks DjCook. :)
I want to mount the pcb internally,so no need for the case or the bus expansion connector.The red push button will be located at the spectrum´s case...and i will mount all the chips in a socket so i ask only for the pcb...
Thank you
Thank you
PM answered
