A3660 Rev 1 PCBs (Hidden vias)
Shipping to ab456, dez3, Chance66, mattymuc, Cstich, Svenss0n
If anyone is missing, do tell me as I had a mixup with my sendfile when I was at a businesstrip. I think I have them all covered by now.
sorry currenlty out of boards.. and out of connectors (that I can sell)
aprox 2 weeks to next batch.
Are you keeping a list of people for the next batch? I'm interested when you get some more.
NO! I am not keeping a list,. I will TRY to contact people but might miss there will be a new add up when the boards arrive. but that will be some day after christmas
1- Where can one locate the 74FCT243A IC ? They don't seem to exist... Did you mean 74FCT543A?
2 - are all resistor 1/4 watt?
3 - all caps are ceramic unless specified?
4 - you state all caps are 0805 packaging, but I don't think you can get "
5*22uF Alu-Electrolyte" in 0805 packaging.
I will include a full BOM with the PCBs, gal-file information etc can be found at : http://wordpress.hertell.nu/?p=537
Anyway this is a list of components needed:
Resistors (All 0805 size)
3*1 Ohm
34*22 Ohm
2*33 Ohm
1*100 Ohm
3*470 Ohm
1*100 Kohm
24*1 Kohm
19*2.2 Kohm
16*3.3 Kohm
15*4.7 Kohm
Capacitators (All 0805 Size) (6V or more)
26*100nF
1*10nF
2*10uF
2*220nF
2*220pF
12*330nF
(C400 an 100nF can be replaced with a RH5VA43A)
Filters:
2*80 Ohm / 500mA
ICs:
3*GAL16V8-7
4*GAL22V10-10
3*GAL22V10-15 (Actually I use -10 all over)
9*74FCT243A
2*74F257
7407
74F04
74F139
74F1803 OR 74F803
74F32
74FCT244A
74FCT373A
74FCT374A
EP8700 OR Dallas DS1000-25 - Delayline
50 - 66MHz Oscillator 5V (Remember that above 50MHz overclocks parts of motherboard)
LT1084 3.3 Voltregulator (NOTE the 3.3 IS IMPORTANT!) Only for 060 usage.
CPU Slot Connector:
KEL 8817-200-170S-F
YES! it is a typo there 74F543 is the correct one!
the lectrolytes is not 0805, there I use EEHZA1V220R
Moderators: PLEASE close this thread.. will start a new one to clear stuff up!..
Well the second board arrived like it should, too bad the first shipment never made it. Positive feedback left. Thanks again!
