KGC210
I have a batch of Kipper2K designed adapter boards to allow you to plug a normal DIP64 expansions into the Co-Processor slot of the A2000 (A1500) CN600.
This saves having to remove the drive tray if you want to get access to you CPU board and also you don't need to build a socket tower to get the board over a MegaChip.
The adapters are gold plated with beveled edge where it goes into the Slot on the motherboard, also the contact surface of the DIP64 and the two pin header are gold plated. These are brand new Mill-Max Manufacturing Corp and Molex, LLC parts.
Depending on the board you are fitting to the adaptor you may need to remove the 68K CPU from your motherboard.
I have included a pic of the Max board dimensions that will fit with the case closed.
I now have 44 (Was 50) for sale to start with and will order more as needed (Was 25). (Will update this amount as they sell, also for sale elsewhere)
Prices for 1 adapter are as follows:
UK Signed 1st Class £16.50
UK Untracked 1st £15.50
EU Tracked £22
EU Untracked £17
USA / Can Tracked £23
USA / Can Untracked £18
For other locations and for example if you you to buy 3 or 5 etc I will calculate a cost.
Untracked sent at your risk!
I will only except Paypal Gift as this is not a commercial product.
TF530, A508 and A5000 seen in pics not included neither is the A2000.
You can't close the lid with a Compact flash card in the A508, although Kipper2K is redesigning the A508 with this in mind.
I have got permission from Kipper2K to sell these boards.
There may be a delay in you getting these boards if demand is faster than I can produce them.
Other Items for sale:
A500 CPU Relocator ( 90 degree ) Ideal for TF530
Kipper2k CD32 Riser - RGB (DB23) and optional PC Keyboard (PS/2) Ideal for TF328
TF328 & Kipper2K Riser v6.0
EU Tracked £22
EU Untracked £17
