Page 3 of 12 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 113
Thread: Amiga A1200 Tower Project.
  1. #21
    Ya' Like it Retr0? VIP Zetr0's Avatar
    Nov 2007
    Age
    44
    137 (100%)
    @Ed.D
    you did all that with pretty much hand tools!!!!
    Thats pretty awesome metal working right there!!!
    8)Flux Mastah' Zee8)
    50 L337 1'M W1R3FR4M3
  2. #22
    Amiga user since 1989 Amibayer!
    Staff Moderator
    merlinkv's Avatar
    Oct 2009
    Spain
    Madrid
    Age
    55
    84 (100%)
    @Ed.D
    Starting search of aluminium plates...... I will try to "emulate" your professional job on my A4000 tower project.
    Crossing fingers .... Itīs my first serious mod ....
    I don't know how it will be the third World War. But I do know how it will be the fourth: With sticks and stones.
    Here lies a brave, a formidable adversary and a true man of honor. Rest in peace. 04/21/1918
  3. #23
    Ed.D's Avatar
    Aug 2010
    Bristol
    Age
    54
    8 (100%)
    Blog Entries
    1
    Thanks Zetr0
    @MerlinKV, I bought my aluminium from the dark side as a BIN (buy it now) item:
    http://shop.ebay.co.uk/ukfab12/m.htm...&_trksid=p4340
    These were the cheapest I could find in the UK (price driving comment?) and I know you're located in Spain, but to be honest you could probably get a piece of 'ally' at a local scrap merchant or similar for next to nothing. ...somewhere in Spain there'll be a satellite dish with a gaping hole in it!!
    1.5mm was the minimum thickness I wanted to use for strength. You may want to go thinner but I'd advise adding some right-angled strip down its length to make it stronger. Unless you have a fly-press or bending tool to add strengthening points.
    Although I can't make it for you, if you need some help, ask away or PM me. As a tip (something I didn't do) it might be useful to make an accurate cardboard template of the back face first so you'll have an idea of where everthing might go, then transfer that to your metal.
    All the best and Good luck.
  4. #24
    Staff Moderator
    merlinkv's Avatar
    Oct 2009
    Spain
    Madrid
    Age
    55
    84 (100%)
    @Ed.D
    Don't worry my friend. In two or three days I have the plate. Not far I have a nice market with alot of materials.
    Because, my case is PC Server case, I'm thinking to use a 2mm or 2.5mm plate.
    If I have any doubth I contact with you.
  5. #25
    Amiga Rules Amibayer! HeZoR's Avatar
    May 2010
    Nomos Pellis
    Age
    41
    33 (100%)
    I could design this . Creating an autocad file for the back panel when I'll get a case on my hands, and then send it for laser cut on inox aisi 304 material. Thickness should be not thinner than 1.2mm Satin, or 1.5mm - 2.0mm mat optimal. Mass quantities could follow if successful
    :Commodore:Amiga:rainbow:Rulez:boing:
  6. #26
    Ed.D's Avatar
    Aug 2010
    Bristol
    Age
    54
    8 (100%)
    Blog Entries
    1
    Hi Hezor,
    I'm hopefully going to be creating a drawing soon. Maybe other folks can use or change it if they have the same case and want to do a similar mod. I can maybe convert and upload it here if you wanted to make it into a professional format.
    Only thing is my panel is custom made to the parts I used. I'll try to indicate that on the drawing.
    Some things to watch out for:
    The thickness of material used will matter. The thicker the plate, the more it will move the side and top panels backwards and away from the front bezel. So a slight gap will be evident. I'm probably just going to spray the 1.5mm gap on my case in black paint. Hmmm, might look nice in orange too. ...or green ...or blue!
    By removing the rear panel, all the fixings for the outer panels are also lost so I need to find a way to add captive nuts back into the case. I was thinking possibly those things they use on aircraft with 2 rivets and a thread in the center.
  7. #27
    May 2010
    Nomos Pellis
    Age
    41
    33 (100%)
    That's great news. I can redesign it to DXF or DWG autocad drawing. I have some aluminum A1200 plates here, so for a start I can make the amiga holes.
    I'm sure it will be very well documented when done.
    I would recommend to use a plate of AISI 304 1.2mm Satin for smaller gaps, and nice machined finish.
    I was concerned about those connections. It looks like my Darth Vader rivets are going to be usefull!
  8. #28
    Ed.D's Avatar
    Aug 2010
    Bristol
    Age
    54
    8 (100%)
    Blog Entries
    1
    Post Corel Draw drawing added.
    Added a basic drawing in Corel Draw format version X3, for conversion of the Commodore gaming case, linked below and at the start of this thread.
    Trying my best to convert it to other file formats.
    Anyone is welcome to use this drawing but use at your own risk. I accept no responsibility for inaccuracies etc.
    http://www.webed.pwp.blueyonder.co.u...eRearPanel.cdr
    Regards,
    Ed.
  9. #29
    Amibayer!
    Staff Moderator
    johnim's Avatar
    May 2010
    birmingham
    Age
    43
    149 (100%)
    you can use a trial of coraldraw it will let you convert to many formats
    thanks ed for file
    A1200T 1d4:blizzard 1260/50/64mb:fastata-iv:amiga to ps2 mouse:80gb hd:zip100 ide:a4000 keyboard
    A1200D 1d4:blizzard1230mk4/50/64mb:indy mk ii:fastata mk ii:40gb*A1200 rev 2b*2 x A1200 1d4*A1200 1b*A600 2mb 4gb*A500
    PC:8700k@4.8ghz, Msi sli plus mobo, Corsair 32gb ddr4 3000mhz, Evga 1080ti ftw hybrid, Evo 970 m2 500gb.
    sfs cf guide http://www.amibay.com/showthread.php?t=19953 cwb3.9 guide http://www.amibay.com/showthread.php?t=20315 mediator drivers http://www.amibay.com/showthread.php?t=11993 p96 newres guide(radeon install) http://www.amibay.com/showthread.php...905#post325905
  10. #30
    Ed.D's Avatar
    Aug 2010
    Bristol
    Age
    54
    8 (100%)
    Blog Entries
    1
    @ Johnim,
    ur welcome.
    Trouble is I've created the drawings in the full Corel Draw X3 package but when exporting to DXF or DWG it leaves out some details e.g. all the dimensions and arrow pointers. I'll keep trying.
    I just noticed I missed out a dimension between the RF modulator and PSU ports, now added. Pls re-download if needed.
    Cheers,
    Ed.
    Just added encapsulated postscript although a bit large at 5.28MB.
    http://www.webed.pwp.blueyonder.co.uk/pics/CaseRearPanel.eps
    ...if opened in Adobe Illustrator you'll need to resize your art board.
  1. Fitzsteve's A1200 Tower Project =)
    By fitzsteve in forum Photo Booth
    Last Post: 30th May 2012, 18:15
  2. Closed Amiga A1200 in tower case with accessories!
    By woodycool in forum Sales Archive
    Last Post: 1st August 2011, 21:13
  3. My A4000D PC tower project
    By merlinkv in forum Photo Booth
    Last Post: 10th October 2010, 13:05
  4. Closed Amiga A4000 European (220/30V) PSU for tower or mod project
    By da9000 in forum Sales Archive
    Last Post: 9th September 2010, 11:49
  5. Found 1200 Tower project bits (Mediator / Case / PC-Key etc)
    By Megatron-UK in forum Found Archive
    Last Post: 11th August 2010, 21:48
Tags for this Thread
